Coilover installation cost
03-07-2011, 01:32 PM | #1 |
Loading...
341
Rep 2,187
Drives: 91' E30 318is
So I did a search and couldn't find anything. I just bought H&R street coilovers via Tirerack and shipped them to a local install center that has great reviews. I called them up today as they received the coilovers, and are asking ~$630 to install them THEN another 4170 for a 4-corner alignment. I thought it would be around $300 to install (labor) + the alignment... Should I just take the parts elsewhere? I feel like that is WAY to much.
03-07-2011, 01:53 PM | #2 |
Rep 523
Take elsewhere and check out the regional forums here for some shop recommendations. Most in the northeast charge 250-350 plus alignment. I got a quote from an indy BMW shop here for $1100 and just laughed.
03-07-2011, 02:20 PM | #3 |
Loading...
341
Rep 2,187
I was in the North East (New York) and knew a few good shops there. Now in Phoenix I don't know any good shops plus in the regional section there is very little going on, I will ask again though. I just wanted to make sure that was overpriced.
03-07-2011, 02:36 PM | #5 |
Midlife Crises Racing Silent but Deadly Class
1820
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Some of you are very confused on the whole installation process...
SOME coil overs are easy to install. They come pre-assembled because they include camber plates. These take about 2 hours to install, tops, since the entire front end comes out, you plop in the new parts, and VOILA! Done plus alignment. Some of the "pro-sumer" type that comes with new strut hats or camber plates can be cheaper to install. Most coil overs are harder, especially if it requires the use of the OEM front strut hats. It means having to take the front suspension off, put the springs on a compressor, disassemble the strut hat, compress the coil-over springs, then re-installing the front strut hat. On a coil over without existing strut hat assembly it can EASILY take 1.5x the work time, especially if the shop only has one set of spring compressors. So anyone here telling you that any coil over installation should only take $200-$300 doesn't know what they're talking about. It'll range from $200-$500 depending on the complexity and what came with the coil overs and if they're already pre-assembled. HUGE difference in the amount of labor involved. That and it'll take another $100-$200 for proper alignment.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
03-07-2011, 03:20 PM | #7 | |
Rep 776
03-08-2011, 01:46 AM | #8 | |
Loading...
341
Rep 2,187
03-17-2011, 09:53 AM | #12 | |
Rep 1,794
With that said, I've paid $200 for a suspension install that required the oem top hats on all four corners. I watched the install and the guy didn't even use a compressor. Dangerous, but he knew what he was doing. This was not a BMW so no BMW tax applied... Last edited by bimmertt; 03-17-2011 at 09:58 AM.. |
03-17-2011, 10:41 AM | #13 |
Professional Moose Racer
316
Rep 7,509
If I were a shop i wouldnt touch a coil over install for under 400-500.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
03-17-2011, 11:10 AM | #14 |
Rep 13,583
Drives: JB E92 335i
Going rate here in California does vary from $250-$450. If you're getting charged more than that, I'd recommend you look for another shop for the install!
03-17-2011, 11:48 AM | #15 | |
1820
Rep 5,337
And I have a feeling the guys with the fancy hydraulic spring compressors will probably charge more for his/her time.
03-17-2011, 12:02 PM | #16 | |
Rep 1,794
I borrowed a spring compressor from my local auto parts store. It was the cheap $40 kind that uses two bars with hooks to compress the spring. Takes five minutes (or less) to compress the spring, loosen the nut(s) at the top of the hat, remove the hat, and then decompress the spring. I did not need to use the compressor to transfer the hats since the aftermarket springs were already shorter than the stock springs. Just had to push down with a little force. If a shop is going to charge you $300 more for this (your $ range was $200-$500 based on complexity), then that is a complete joke. |
03-17-2011, 12:14 PM | #17 | |
1820
Rep 5,337
Not trying to come across as a know-it-all, but I have done just about every combination of suspension install you can possibly imagine on a MacPherson strut. That's why I say it's not as simple as most of you may think, and the time to install may vary heavily on the type of tools you have on hand and the type of suspension you're installing. Any shop quoting $120 for an install without finding out what brand of suspension and what condition the car is actually in, are going to be in for a big surprise.
03-17-2011, 08:42 PM | #18 |
Rep 6,103
Check your regional forums. Maybe there is someone local who can help you out. I ended up getting someone local with great results!
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
coilover, cost, installation, price |
