Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Car shifts rough from 2nd gear to 1st.
      09-25-2012, 07:51 PM   #1
gm325xi
Drives: 325XI
Exclamation Car shifts rough from 2nd gear to 1st.
i have a 2006 325xi auto trans with 55000 miles and ive noticed as im slowing down from speed of 50mph the car will shift hard from 2nd gear to 1st. it feels as if the car wants to lurch forward. Any idea as to whats causing this?? thanks.
      09-25-2012, 07:56 PM   #2
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
The car should not be shifting down to 1st at 50mph...
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      09-25-2012, 08:00 PM   #3
Affify11
Drives: 2006 BMW 330i
2006 E90 330i  [5.00]
LOL exactly what i was thinking!
      09-25-2012, 08:00 PM   #4
ndog14
Drives: E90 328xi 6MT
Maybe 3rd to 2nd?
OP, need more info. What are you doing? Paddle shifting?
      09-25-2012, 10:47 PM   #5
username604
username604's Avatar
Drives: bmw
2008 BMW 335i  [10.00]
your story doesn't add up
most of the time, the car doesn't even use first gear
you'll notice that downshifts take place around 1000rpm and so they should be pretty smooth
if you want a diagnosis via the interwebs, we're gonna need more details!
      09-26-2012, 05:15 AM   #6
EQUANT
28
Drives: 320d
Had similar issue when slowing down at a stop, step changing 2-1 with a big bump, sometimes.
Had the steptronic adaptations reset at the dealer, issue never returned since.
BMW 320 dA LCI, BMW PPK - 197HP, 2010, sapphire black, steptronic
      09-26-2012, 05:35 AM   #7
Bimmer84
Guardian of the Night
Bimmer84's Avatar
Drives: 2010 335i M Sport Coupe
2010 335i E92  [7.50]
Probably because you are shifting from 2nd to 1st at 50mph... I'm not a mechanic though.
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
      09-26-2012, 09:01 AM   #8
Turb0Surge
Turb0Surge's Avatar
Drives: BLACK e90 335i
like everyone else says... 1st should not come at 50mph.
      09-26-2012, 10:02 AM   #9
ndog14
It's funny, your name is gm325xi and your car has a GM transmission. LOL.
Joking aside, how do you know your in 2nd gear at 50? Are you in M mode being a pretender? If you are, why the fuck are you shifting to 1st at 50mph in M mode? Are you trying to break your car?
      09-26-2012, 10:15 AM   #10
gm325xi
Drives: 325XI
I apologize, i worded the situation wrong...when im slowing down from 50mph to a complete stop it will jum when it down shifts from 2 to 1.
      09-26-2012, 12:00 PM   #11
ndog14
What are you doing? Down shifting in M mode? How do you know it is 2nd to 1st? What exact speed does it happen? Exactly at 50mph? Then it isn't 2nd to 1st.
      09-26-2012, 12:37 PM   #12
Cali_Creez
Cali_Creez's Avatar
Japan
26
Drives: E92 M3 DCT; BNR34; S1000RR
You Dont Shift To First Gear While In Motion!!!
From California, but currently living in Japan.
2001 Bnr34 vspec2
2011 e92 m3
2013 s1000rr
      09-26-2012, 01:54 PM   #13
EQUANT
28
Drives: 320d
@Cali - why? The car's an automatic, it will not allow shifts that will potentially break it.
@gm325xi - if you feel the bump at very low speeds, nearing complete stop, then read my other post here and go get your tranny adaptations reset!
      09-26-2012, 02:26 PM   #14
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
If it's from 2nd to 1st.. I'm pretty sure it's any MPH and not 50mph specifically. However, do these cars even shift into 1st when slowing down? I'd assume it'd just go into neutral instead of hopping onto 1st. Then when you stop or you're at a slow enough pace then accelerate, it'll hop into gear. If it's in manual mode, totally different situation. haha.
      09-26-2012, 03:37 PM   #15
gm325xi
Drives: 325XI
Major Confusion!
ok just to clear thigs up, i dont shift the car into 1st at 50 mph im not a moron. when i am decelerating while the car is in DRIVE, not M, the car will jump when comping to a complete stop. At high speeds the car does NOT go into 1st gear! its in either 5th or 6th,im not sure which being that its in DRIVE.
      09-26-2012, 03:39 PM   #16
gm325xi
Drives: 325XI
NO the car is in D. And it happens at really any speed i just put 50 as a reference. And I THINK its 2nd to 1st, it could be 3rd to 2nd, im not 100% sure, i just know the car jumps when coming to a full stop.
      09-26-2012, 03:40 PM   #17
gm325xi
Drives: 325XI
do u think im a moron, who on earth would do that....
      09-26-2012, 04:59 PM   #18
ndog14
Is that first part unintended sarcasm?
Ok, so this jump is when you're about to come to a complete stop, not at 50mph. Now this jump, is it high enough to dunk a basketball? JK, you mean it is a slight jerking motion. That is common of the GM slushboxes.
      09-26-2012, 05:29 PM   #19
gm325xi
Drives: 325XI
Yes it was lol, and the jerk is sudden, as if someone lightly rear ended me.
      09-26-2012, 05:46 PM   #20
MrZ
MrZ's Avatar
Belarus
19
Drives: 330i
5er ZF transmission is know to do crazy things on 2-1 downshifts, but it's more violent than what you are describing. Some have solved it with a software upgrade, for some transmission fluid change was enough and some had transmissions replaced. Since it's a different tranny, I doubt you have the same issue.
I would start by getting a mechanic to check the AT fluid level, maybe it's low. And changing the AT oil is probably a good idea (many debates about it, but it's up to you).
Try downshifting with steptronic, does it also happen? Sport mode?
      09-26-2012, 06:16 PM   #21
ndog14
Try "resetting" the transmission. Put the car in accessories mode (?), hold the gas to the floor for 30sec, and 'Poof'! I think that is how it goes.
Yeah, transmission fluid change.
      09-26-2012, 06:24 PM   #22
gm325xi
Drives: 325XI
Im going to start with a trans flush,and see if that works if that doesnt then i will do what equant has suggested and have the dealer reset the adaptations reset. Ill let u know wha works.
bmw e90, hard shifting, jerks, transmission
