Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Replacing rear RFT
      02-18-2013, 09:56 AM   #1
BMdubya
Drives: 09 328i
2009 BMW 328i  [0.00]
Replacing rear RFT
I went to the dealership over the weekend and they told me my back tires need to be replaced on my 09 e90. They gave me a quote of $970 for 2 run flats. My question is if I replace the rears with non run flats and the fronts are still run flats, will their be any issues?? Also what non run flats would you recommend?
      02-18-2013, 10:18 AM   #2
jonmaceng
15
Drives: 2009 E92 335i
You probably shouldn't mix and match tires. As for brands, try continental dw or Michelin pilot super sport.
      02-18-2013, 11:44 AM   #3
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
Avoid mixing run flat and non run flat tires due to unstable handling, especially at highway speeds and when cornering and any speed.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      02-18-2013, 01:33 PM   #4
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
You have two sensible choices. Assuming the fronts have about 1/2 tread remaining, you could follow the dealer's suggestion and replace the rears with the exact same tire; but check TireRack's prices before purchasing from a dealer. Or you could buy 4 new non RFTs and discard the still good fronts.
I found the latter course was actually cheaper, but you should do some shopping.
Also, buy a good tread depth gauge so you will be able to monitor your tire wear in the future.
Tom
      02-18-2013, 02:47 PM   #5
abhishriv
Drives: 2007 335i Coupe (Space grey)
buy 4 new non rft and sell your current front ones on the forums, im sure someone would want them. thats what i am going to do this coming spring.
      02-18-2013, 02:56 PM   #6
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
To be fair, the price quote at the dealer usually includes the super expensive full alignment job.
      02-19-2013, 11:16 AM   #7
Gary@TireRack
Moderator
Tom
+1 . Tread depth gauges are cheap and simple tools that will last forever.
      02-19-2013, 02:12 PM   #8
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I would not mix and match non-RFTs with RFTs. That being said, if you make the switch to non-RFTs I think you'll be happy. Michelin Pilot Super Sports are awesome summer tires that you really can't go wrong with.
      02-22-2013, 09:44 AM   #9
BMdubya
Drives: 09 328i
Thanks for everyone's input. Looks like I'll be switching the non-rft.
      02-22-2013, 01:22 PM   #10
Bronze
Bronze's Avatar
Drives: 2008 335i sedan
2008 BMW 335i  [0.00]
FYI, I took my OEM runflats off my wheels in November when I mounted my winter tires. My new summer wheels are 19s, and so I have no need for my OEM run flats. If you want to hold off on a new set of tires, and just want one or two rear tires, I'll break up my set of tires and sell to you what you want. I can send you pictures/tread depths if you're interested. Say $50 per tire + shipping? I think you could easily get one more year of driving out of them (12-15k miles, depending on how you drive).
Bronze
2008 335i sedan | black/black | Sport | Premium
rft, tires
