      03-07-2013, 09:53 PM   #1
Hondamxracer51
Drives: 2012 135i dct zmp
2012 135i  [0.00]
dct tranny and idle problems
i saw a thread on this but it had like 6 pages of responses and i couldnt go through and read it all. i know that i have seen other people with this problem and i think mine has been fixed.
so the original problem with my car was fluctuating idle and delayed power. i would be sitting at a light or stopped and my idle would either jump up maybe 500 rpms or it would dip down almost to a stall. also if i would come to a stop pretty quick after driving fast my car would almost stall. i was also having a problem where i would be stopped and i would go to pull out into traffic (turning right for example) and i would push the throttle and nothing would happen untill like half to 3/4 throttle.
so i work at a dealer and i had brought the problem up to my buddy that is a tech and he said to bring it in and he would look at it. he scanned the car and didnt find and faults but he found a test plan on re calibrating the clutches. he said it was a pain and a long process that took him forever. he ended up clearing all the settings and re calibrating the clutches and doing some other stuff.
so far ive had the car back for almost a week and it seems to have fixed it. i havent driven super hard but it doesnt seem to be doing what it was before. if anyone is having this problem i can try to find out exactly what he did.
i hope this helps someone i just thought i would share it because i know ive seen the problem out there before.
      03-07-2013, 10:14 PM   #2
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
Mine does this as well, I would really appreciate that information. Good to know I am not the only one with the issue.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      03-07-2013, 10:23 PM   #3
Hondamxracer51
2012 135i  [0.00]
my inbox is going crazy. apparently this problem is common. i will update this post tomorrow with more info.
      03-08-2013, 02:35 AM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10523
Drives: N54 e82
It is basically a SW issue - we think. A simply SW upgrade seems to fix this problem. Go visit your BMW dealer.
I'm sorry you can't read thru six pages... or even post an update.
Throttle response problems
http://www.1addicts.com/forums/showthread.php?t=735136
      03-08-2013, 05:46 AM   #5
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Must be a real bitch for him not getting the answer spoon fed.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      03-08-2013, 11:07 AM   #6
Hondamxracer51
2012 135i  [0.00]
right? i thought i was trying to help people in a more simple way than reading every post on 6 pages and not finding an answer.
also i did post in there i just didnt think anyone would ever read that far in to find it.
      03-08-2013, 11:13 AM   #7
dicker
dicker's Avatar
Drives: F80 6MT
It seems like you can't read a thread either?
      03-08-2013, 11:21 AM   #8
bogart
bogart's Avatar
Drives: E82 N55 DCT
2011 BMW 135i  [7.06]
thanks for the info!
      03-08-2013, 12:51 PM   #9
Hondamxracer51
2012 135i  [0.00]
ok here is a copy of the techs notes to bmw. i think it should be enough info. but if anyone needs more info i can ask him
Complaint: CLIENT STATES THE VEHICLE IS CUTTING OUT UNDER ACCELERATION FROM A STOP -
Cause: TRANSMISSION CALIBRATION AND DSC PERFORMANCE LIMIT.
Correction: TEST DROVE AND WAS ABLE TO DUPLICATE A SHORT HESITATION WHEN ACCELERATING FRM A COMPLETE STOP.SHORT TEST VEHICLE,FOUND FAULT STORED FOR THE DSC,PERFORMANCE DEDUCTION.WENT THROUGH TEST PLAN FOR FC 5DEC,TEST PLAN CAME BACK INCONCLUSIVE,CLEAR FAULTS N FOUND
Technician Notes: FAULT DID NOT RETURN.AS A PRECAUTION FOR THE TRANSMISSION (DUAL-CLUTCH TRANSMISSION).PERFORM A CLUTCH SLIP-POINT TEACH-IN,AND TRANSMISSION ADAPTATIONS RESET.AFTER TRANSMISSION CALIBRATIONS,TEST DROVE,ALL NORMAL.
      03-08-2013, 04:26 PM   #10
davefromfla
Drives: 2021 M440ix
Thanks man. Taking mine in in 2 weeks for the same problem.
      03-08-2013, 06:58 PM   #11
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Thank you very much
Follow my builds:
      03-17-2013, 08:49 AM   #12
Zombie1
Drives: BMW 135i 2010
So true
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
clutch, dct, idle, n55, transmission
Search this Thread:
