TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Advice: Doing Meth with Cobb or go back to JB4? Arizona
      09-14-2013, 11:37 AM   #1
Murph335
Murph335's Avatar
Drives: '07 N54 e90, '10 N54 e93, TBSS
2015 Tesla P85D  [0.00]
Background: Warranty is expiring on 9-22 (1 week!) so I am planning mods now, looking for used parts or things on sale where possible. I love driving this car cant part with it but liked the power of my CTSV(sold) 550rwhp trapped at 121mph.
GOAL: I would like to see 450rwhp on 91 or trap 117mph or higher!
Initially looking at RB or Vargas turbos. My turbos were just replaced under warranty about 5kmi ago. Realizing I can add some boltons and reading about methanol advancements it looks automated once everything is tuned and dialed in and i can get over the 400rwhp mark.
I had a friend that ran cp-e DP, BMS SCI, + 100oct and JB4 map7 and the car was a blast to steer!! Thats the minimum high I am chasing. Guessing that was 400rwhp.
So I have searched for Cobb and Methanol Injection found some stuff from 2012.
Thinking some advancements have been made.
*Located in AZ and I couldnt find any ProTune shops so I might have to drive to SoCal for installation and tuning?
*AZ recommendations for meth install done right?
  1. I already own a Cobb AP it looks like the only solution is $850 through PTF HFS-4 and do the E-tune method $250. Add BMS charge pipe $239 = $1339
  2. BMS FSB kit $529 + JB4 off the forum $350 + BMS charge pipe $239 =$1,118
Not interested in looking at proceede at this time.
@Jake@PTF
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq
      09-14-2013, 11:39 AM   #2
hemi to e90
dat boost doe
hemi to e90's Avatar
Poland
238
Drives: 10 335i 21 740li
u stack with cobb, i tried that with my jb4 and a cobb tune and i wasnt pleased.
the jb4 with meth, its been flawless in my experience, and headache free.
      09-14-2013, 12:09 PM   #3
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
I like the HFS-4. It's arguably the best kit. So I would stick with that route.
      09-14-2013, 12:14 PM   #4
///M3NACE
///M3NACE's Avatar
168
Drives: E36 M3, E36 Vert , E90 N52
Never do meth. #BB
      09-14-2013, 12:15 PM   #5
135Pats
135Pats's Avatar
Drives: A few BMWs
HFS-4 + protune
F30 N55 XDrive EBII
      09-14-2013, 12:18 PM   #6
Btw you will want to add a tank. You can get away with other tanks but the Aquamist tank is one of the best. So add another $300 to your bill.
      09-14-2013, 12:58 PM   #7
illrider
Drives: 08 E90
My vote is for Jb4. Make sure you get a trunk mount tank. I used to run the WW kit in the AZ heat, and constantly had issues with getting air bubbles. I converted to a trunk mount kit will full SS 4an lines and havent had a single issue.
Keep the COBB and load the BMS backend flash with it. Throw some E85 in the mix and you will easily be able to make your power goal.
      09-14-2013, 01:42 PM   #8
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Interested in a Cobb + meth solution too, for 91 Colorado pump gas. At first would just want to run enough meth to use stage 2+ aggressive map, at high altitude. Get the bugs sorted then go protune remote. Maybe circumvent the built in limits on HA boost.
Does that make any sense?
So far the HFS-4 approach looks good.
      09-14-2013, 01:43 PM   #9
kboss335
Drives: 08 335i e90
I'm running JB4 G5 and meth here in Arizona. I had to install mine myself since no one around here can do the install. However DynoComp up in Scottsdale does good pro tuning if you decide to stick with Cobb
      09-14-2013, 05:08 PM   #10
Murph335
Murph335's Avatar
I dont understand the need to run both tunes?
Yes trunk mount for sure. BMS trunk mount looks clean! Did you self install?
      09-14-2013, 05:52 PM   #11
Murph335
Murph335's Avatar
Dyno comp is no longer on the cobb pro tune site, and no cobb products on their site. Maybe they stopped doing cobb?
I hit up ESS tuning right here in chandler for the meth install they do them all the time on blown e90 M3, shouldn't be too much diff?
Looks like going back to JB4 + the trunk meth kit is easiest and cleanest solution, and the 2 systems talk to each other for safety.
      09-14-2013, 05:55 PM   #12
Murph335
Murph335's Avatar
AR design is local in Colorado doing vargus turbo pkg, fuel pump, oil change, other misc parts with protune for about $4600 includes labor bc u already have the cobb. seems like a great deal if i were in CO.
      09-14-2013, 07:13 PM   #13
illrider
Drives: 08 E90
I did install myself. Not very difficult to do. By running both tunes you get the best of both worlds. The flash will control fuel, timing, Vanos, Etc. the jb4 is used to control boost, meth, auto tuning, easy map changes, logging, etc.
You get the best of both worlds. The backend flash will make the biggest difference though if you are running high concentrations of e85.
      09-14-2013, 07:40 PM   #14
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
...from what I read there is fueling issues etc that the JB4 by itself cannot resolve with higher performance.
Edit. illrider above pretty much highlighted the issues
      09-14-2013, 08:20 PM   #15
jayzF30
34
Drives: '07 335i, '09 M3
Hfs4 and cobb, match made in heaven
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock
      09-17-2013, 09:49 PM   #16
Murph335
Murph335's Avatar
What map on the cobb do u run? JB4 would be autotune map.
      09-17-2013, 10:02 PM   #17
Marcadelic
Instagram: @Marcadelic
Marcadelic's Avatar
Drives: 335is
You stack the cobb on top of the jb4 so that you can run the backend e85 flash from BMS, if you're looking to get the most out of your car you're going to want it so you can run higher than a 40/60 e85 mix. That plus 100% meth and you'll be putting up numbers a good amount higher than 400
However the flash is also easily uploaded using a BT tool and some software, it's a little more work but it's a lot cheaper
| New: 2018 F80 M3 | Old: 335i / 335is | Instagram: Marcadelic |
      09-18-2013, 03:06 PM   #18
MrNeef
Drives: 2008 535i FBO
My car ran better with the Cobb alone with 100pct e85 then with the Jb4 stacked with the backend flash.
I am contemplating adding meth to my 100pct e85 for the cooling.
Would love to have the car always run like its 65deg and cool out
2008 535i 451whp/485wtq
FullBlown Motorsports: Cobb v3, DCI, Dr. Euro DP's, ER CP, TIAL BOV, ER FMIC, Magnaflow catback, NEW OEM HPFP, FBM340 e85 fuel kit, 100pct e85
      09-18-2013, 03:15 PM   #19
zeel
Drives: 08 AW e92 335i
My car likes the cobb/jb4 stack. And I am currently running e60 + 100% meth with fsb cm12 and a 2.2 gal tank on compression fittings. Has worked perfect so far.
11.76 @ 124mph (123.9) full weight/street tires/no meth.
      09-18-2013, 03:45 PM   #20
Allen@MOTIV
38
Drives: 135i
The HFS-4 kit combined with our e-tunes has proven to be awesome combo, both in terms of reliability and power.
      09-18-2013, 04:54 PM   #21
Murph335
Murph335's Avatar
Guys this is great information!! Wife took over the N54 while i messed around with the LSA world for a little over a year. Running dual tunes is completely new to me. Am I missing an FAQ thread on dual tunes?
I also need to figure out cobb logs so i can have some baseline data and see overall health. (ill read the cobb site instructions)
My JBD (X5D) came with a bt cable but havent used it.
HFS-4 $900 + $200 eflash kit doesnt seem as integrated and double the cost of BMS?
Regarding E85 - this reminded me why I want to stay away... http://www.1addicts.com/forums/showt...2#post14679572
      09-18-2013, 05:59 PM   #22
Myrder
Myrder's Avatar
Drives: 2010 E92 335i MSport 6MT LMB
Did you read the responses in the thread you posted?
It has no basis for the argument that E85 caused the fuel injectors to fail.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56|
-I will look on your treasures, gypsy. Is this understood?-
bms, cobb, fsb, hfs-4, methanol
