H8 Angel Eye (Reflector?)
08-08-2013, 10:57 AM | #1 |
Rep 10
Drives: 2006 325XI
Simple question.
Is the reflector attached to the OEM reusable for any H8 bulb upon replacement? I am not interested in buying sole aftermarket angel eye upgrade bulbs/kits. I have to run into my B&M to replace tail light bulb and would like to replace the angel eye bulbs. After doing some research, every DIY I have come across is for an aftermarket kit. My question is if any H8 bulb can can be used to insert into the reflector/condenser part that is SCREWED into the housing for the light source to the angel eyes? e90 2006 325xi |
08-08-2013, 11:15 AM | #2 |
469
Rep 4,939
i believe the answer would be yes. if you are trying to replace a H8 bulb with a different H8 bulb then it should be perfectly fine.
If you have a 2006 325xi then your car doenst use H8 bulbs for the angel eyes however, they use a unique bulb that you cant find a simple replacement for.
angel eye, angel eyes, cosmetic, diy, lighting |
