08-24-2012, 11:29 AM | #23 |
Rep 5,040
Anyone try the injen N55 intake for the 1/3 series? It looks like it may fit but alot more piping is replaced
http://www.e90post.com/forums/showth...ighlight=injen |
08-24-2012, 12:20 PM | #24 | |
Rep 432
Drives: F10 535i M-sport
08-24-2012, 02:18 PM | #25 |
Rep 5,040
Im tempted to try - the injen kit replaces all of the piping, all the way to the cone element. I assume the piping connection has to be same size (it is still an N55 at the end of the day)....
08-24-2012, 09:27 PM | #26 |
Rep 432
08-25-2012, 12:07 AM | #27 |
16
Rep 71
Drives: BMW F10 535i
08-25-2012, 07:53 AM | #28 |
Rep 5,040
True - the intake is different. But my point was that the injen replaces all of that piping. Im debating if the source connection point is the same size or not.
08-25-2012, 08:57 AM | #30 |
Rep 26
I had that set up on my 335i and to be honest, when the engine gets hot, you really suck up alot of hot air from the compartment. I am waiting for something a little more forward and something that seals the cone off a little better.
09-01-2012, 05:06 PM | #32 |
Rep 432
found out from terry today that BMS is developing an intake for the F10 535i, development will start in the next few weeks.
09-03-2012, 09:01 AM | #33 |
Rep 5,040
11-10-2012, 05:57 PM | #34 |
58
Rep 2,014
11-10-2012, 09:35 PM | #35 |
BMW Enthusiast
25
Rep 303
2022 X5 sDrive 40i Carbon Black | Ivory White Vernasca Leather | Aluminum Tetragon Trim | ZMP | ZPP | ZLS | ZPK | 337 | 4NB | 3M2 | 4HB | 7M9 | Black Kidney Grills |
11-10-2012, 10:03 PM | #36 |
Rep 400
I agree. It sits open and draws all the heat in from around the engine. I want one too. But, would prefer to wait for a better design.
11-14-2012, 10:00 AM | #37 |
13
Rep 81
Burger CAI - Dyno'd??
Seen this?: http://burgertuning.com/N55_BMW_Performance_intake.html
It doesn't list our F10 535i / 535i xdrive, but I'm gonna assume it works on our car unless someone corrects me. I agree with the heat comments above, but has anyone looked into this or spoken with Terry at Burger about a dyno on this? Trying to see if it's worth it...
"Not everything that counts can be counted, and not everything that can be counted counts."
11-14-2012, 10:09 AM | #38 |
Rep 8,801
Pretty sure that doesn't fit because if you look at the engine/intake covers they are different in the F10 compared to the 135/335.
The only one that looks like it could possibly fit is the one from INJEN if we don't use the full intake and just use the last section but wouldn't know for sure unless someone test it out. Injen is in cali so it would be easy for someone local to drop by to see if it would work. I'm not about to drop 3-400 on it just so it doesn't fit. Alan
11-16-2012, 09:08 AM | #40 |
Serious About Shine
Rep 7
Indeed not,
Also the current intake still sucks the same temperature air as any replacement would, but the benefit is from MORE air being sucked in at a faster rate over stock. That being said, the HP gains would be minimum if any at all. I'd still like one though
11-16-2012, 09:38 AM | #41 |
Rep 8,801
I am only interested in one for the sound and don't expect any measurable HP gains. When i removed my air box to install the JB4, i started the car up and the car sounded aggressive and had a blow off valve noise to it.
Alan
11-16-2012, 10:00 AM | #42 | |
Serious About Shine
Rep 7
Great Mods BTW! FUNNY! I noticed the same thing when I installed my JB4 S1….it sounded pretty good and got me thinking, first thing I did was get in the car to see if I could hear it and second I closed the hood both while the airbox cover was off and the filter removed. You could hear it a little while inside the car, when the hood was both open and closed, but you couldn’t really hear it outside of the car (hood down). Just thought you’d like to know. I even tried an experiment by not tightening the torx screws completely down on the airbox cover …LOL.. it didn’t work for any noticeable sound improvement. For now the drop-in K&N filter is what’s next (JB4 S2 is in the mail on the way…*drooling*) Brad
11-28-2012, 05:52 PM | #43 |
Rep 494
Drives: BMW 2011 M3
How did you hook. Up your S2 my 2011 535i F10 did not have the CANBUS located on the left Side of the engine. Is there another location that I can run wires too?
12-02-2012, 01:01 PM | #44 |
Rep 6,653
Actually, this is very accurate info. Oiled air filters have definitely been known to coat the wire in the Mass Air Flow (MAF) sensor in oil, resulting in all kinds of screwed up operations. Definitely be very careful when oiling the filter. Don use too much and let it dry completely.
Oh, and these things add zero hp by the way, but they do sound good. |
535i, cold air intake, engine, m-5 |
