PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Deciphering the tire jargon (help!)
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
02-19-2013, 08:03 PM | #1 |
Rep 5
Hey All,
As you can read I'm new to the forum. I've been trying to wrap my head around getting some new shoes for the whip; but, really I get lost in all the associated jargon. I'm reading about milimeters, offsets, fender rolls, tire stretches, etc. and I just feel like saying Is there a noob guide you guys could point me towards where I could learn a little more about the whole world of wheels/tires for the bimmer. Thanks |
02-20-2013, 05:00 PM | #3 |
2038
Rep 25,989
Looking at wheel and tire info seems daunting at first, but after you understand it you won't even have to think twice really. Wheel specs will comprise of the wheel diameter, width, and offset. The offset of the wheels is basically the spacing between the centerline of the wheel and the backpad/mounting surface, in millimeters.
For instance: 19x8.5 ET35 - 19" in diameter x 8.5" in width with an offset of +35mm 19x9.5 ET33 - 19" in diameter x 9.5" in width with an offset of +33mm Tire specs are the tire's width, profile/aspect ratio (percentage of the width), and diameter. For instance: 235/35/19 - 235mm wide / 35% of the width / 19" in diameter 265/30/19 - 265mm wide / 30% of the width / 19" in diameter Different cars require different diameter, width, and offsets. In general you want to keep the same overall diameter of your wheel and tire combo as your stocks. Wheels/tires have specified recommended width ranges, so ideally you would choose a wheel and tire combo that both fits, and is the right "size" for your car. The wheel specs I posted above will work without any issues on an E92. The diameter, width, and offset of the wheels will fit under the fenders, and the tire sizing will fit on the wheels as well without causing any issues. Other tire sizes will fit on the wheels too, for instance a 245/35/19 and 275/30/19, however those sizes may require you to roll the fenders. This is literally taking a fender rolling tool (some people use a baseball bat though - I would not recommend this method), and rolling the inner fender lips flat to give you more clearance. Tire stretching is where you run tires too narrow for the wheels, to give you additional clearance. No tire manufacturer will recommend doing this though, and some feel that it is unsafe. We don't recommend it either, however it's pretty common in the modified car scene these days. One last quick tip to you is that while there are a large number of tires all available in sizing for your car, not all tires are comparable in size. What I mean by that is, even though you compare two tires of the same size (lets say Hankook Ventus V12 vs. Bridgestone Potenza RE-11), they will fit differently on the wheel. The Hankooks run somewhat narrow, while the Bridgestones run fat. So while tire shopping, you may want to verify that the tires you are buying aren't going to cause you any sort of clearance issues. If you stick to recommended specs you should be fine with most/all brands, but if your clearance is very limited it's pretty crucial to do your homework.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram Last edited by VMRWheels; 02-21-2013 at 12:45 PM.. |
02-20-2013, 07:14 PM | #5 |
2038
Rep 25,989
You're welcome.
Now that you have a better idea, you can kind of look at other people's setups and get a feel for what it took to run something similar.
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
02-20-2013, 08:02 PM | #7 |
Shake and Bake
32
Rep 494
02-21-2013, 12:44 PM | #8 |
I plead the 5th.
523
Rep 1,519
Great post VMR!
-Matt
02-21-2013, 12:52 PM | #9 | |
2038
Rep 25,989
02-22-2013, 05:58 PM | #10 |
Rep 6,092
that explanation post should be a mandatory read by every new person in this forum.
02-22-2013, 08:18 PM | #11 |
2038
Rep 25,989
Haha not everyone needs the extra guidance though. Hopefully people will stumble upon this thread though and find my post helpful.
noob, tires, wheels |
