TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > THUMP from rear end. Just had Wavetrac on
      10-19-2014, 08:51 PM   #1
Joey911
Joey911's Avatar
Drives: 2011 E92 335i MT w/ M Sport
Hi guys,
I have a 2011 BMW 335i M Sport 6MT. I got the whole wavetrac pumpkin from Diffsonline and installed on to my car following Bentley Manual and Torque precisely.
Timeline:
1. Got the the LSD pumpkin and installed the same day, THUMP is loud, thought it's what LSD does normally.
2. The THUMPs was way too annoying, and I could actually feel a delay between my foot and tires (power won't go to the ground until the THUMP occurs, gap in drivetrain??)
3. Took the whole pumpkin off the car (since I haven't return the core yet), and brought it too Diffsonline and have him inspect it, no problem, so he tighten the already perfect backlash to a even tighter spec because I requested it.
4. Put it back on the car, THUMP the same, didn't become softer, so probably not from the ring gear.
We discussed and I researched. dzenno from this forum had a big thread about it and said the thump goes away once he put in a new half shaft (cause the old one cracked)
I assumed the pumpkin has NO PROBLEM at all, what could be the problem? Half shaft? drive shaft? how do I inspect them?
**THUMP when pushing in gear**
I have my car lifted in the shop, clutch in and hold, push in first gear. There's a THUMP from the rear right at the 'push in' moment and the tires will actually rotate maybe 10 cm and stop.
Is it normal that power through driveshaft BEFORE clutch out? It's like the system want to load the gaps or something.
Tests:
I test it when the car was off the ground and have some one look at it under the car. My right foot hold the brake tightly, left foot play with the clutch. 1st, release clutch half way just to engage and make that THUMP, reverse, and release half again and THUMP. *Notice* tires weren't moving.
He said the pumpkin goes up and down around 6mm from top to bottom. Is it a normal range?
My car is getting destroyed by this violent THUMP slowly... I can feel something get loose whenever the THUMP happens.....
Thoughts?
UPDATE 1 (Feb 9, 2016):
Hello guys, sorry that I never posted an update. I will make it short. Basically, I complained about it to Wavetrac right after I had it installed. After a long time, they sent me the REVISED version of the same unit. They claimed they used different gearing, to reduce the backlash.
I was satisfied with the test-drive after the installation, the "gap (backlash, noticeable backlash by driver..)" wasn't a "gap" anymore, I would just called it a.. well still a thump but not entirely super annoying anymore.
skip to the day I changed my front control arms to M3 spec:
(my control arms were worn as f, when i brake, steering wheel would shake left and right, cause the toe angle changes)
The first thing I noticed when I started moving my car was not how much tighter the steering became, it was the weaken "thump"!!
So I concluded to myself, that any weak or worn rubber part on the car (from driveshaft guibo, to diff mount subframe mount, to engine mount, control arms, all kind of rubbers) will amplify the thump, since it allows the shock to keep moving around the car.
And recently, I did the first oil change after a long time, I put in Motul Gear FF Competition 75W140, overload it a little by tilting the car forward, just a little.. it came out good, thump was somewhat weaken again.
Now I am at the point that if no one points out the thump, or unless it's too cold that the thump is amplified, I don't notice it anymore. Maybe I get used to it or upshift and downshift smoother to avoid the thump, but it does not annoy me anymore
Will report after upgrading other rubber parts.
      10-20-2014, 04:10 AM   #2
CrustyNoodle
Australia
Drives: 135i DCT
I can't offer any solutions but I'm very interested to hear what you find. I also have a Wavetrac and "the thump". I'm not entirely sure it is the Wavetrac but I have my suspicions.
If you can afford the time, you could put the old diff back in and see if the clunk disappears - that would definitely indicate that the issue is inside the diff not outside (driveshafts or bushes etc.)
BMW - 135i DCT
Audi - Q5 3.0TDI
      10-20-2014, 08:23 AM   #3
Joey911
Joey911's Avatar
I actually did put in the old diff twice. I wasn't aware if the THUMP was there from the beginning probably because it was very soft.
Both the first and second time when I put the Original Diff back on, the can notice a THUMP but very soft (you become sensitive for that THUMP after a loud one)
It has to be somewhere on the rear drivetrain section, but present less with open diff... less stress?
      10-20-2014, 08:43 AM   #4
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Have either of you though of getting the diff brace that is over on N54tech forums? People are raving about it and it sounds like it may help you guys out. This sounds like drivetrain movement.
      10-20-2014, 09:40 AM   #5
Joey911
Joey911's Avatar
I've seen thread about spending tons of money but still can't get the THUMPing fixed.. I am more interested in pinpointing the exact problem and replace the parts, and the money for JB4 lol
BTW, when I am doing 40 MPH+ slight right, my left side wheels will hum, it's getting louder lately, starting to sound like grinding, does this wheel bearing problem indicate anything?
      10-20-2014, 10:59 AM   #6
JETmn
2011 335Xi  [0.00]
The brace is $200 and would really help narrow down the problem. Lots of guys saying they are getting much better traction and less wheel hop also.
      10-20-2014, 05:23 PM   #7
Joey911
Joey911's Avatar
I emailed Wavetrac tech and they said it could be the "preload of the driveshaft", he said if the driveshaft center bearing is not correctly loaded (I'm still not quite sure) it will have the symptoms even you put the original diff back, now I remember my car was perfect before the first pumpkin swap.
NOISE:
I notice a new noise on my 335i, same noise my old E46 made after the Diff installed. It's like, on flat ground, no ebrake, put in first gear, and let go half of the clutch till in JUST engage, something goes make a loose sound. Push in the clutch, sound is gone, let go half way again, li li li li li noise (don't know how to describe lol)
I will have a video of the noise up soon! I suspect it's what Wavetrac told me, the driveshaft!
      10-21-2014, 07:06 AM   #8
Dan_Q
Dan_Q's Avatar
117
Drives: F80 M3, F15 X5 50i
2018 M3  [9.50]
2015 X5 xDrive50i  [10.00]
Man what a nightmare. I can imagine the thrill of getting this after shelling out probably close to $3k then you install it and no go. Talk about a PITA. You will get it sorted out but I feel for you. I know that when you encounter stuff like this it feels like it is ruining your life until it is resolved.
I am seriously having second thoughts about ordering an LSD and doing the install myself. I previously had thought it would be an easy install and the crux of the event would be figuring out how to ship back the old pumpkin. Perhaps not...
      10-21-2014, 07:57 AM   #9
MadToy
64
Drives: '18 340i Xdrive
I believe his car has the small diff, which the brace doesn't work on.
If you have a GoPro camera, stick it under the car pointing at the pinion where the driveshaft meets the diff. If you see excessive rotation of the diff when it makes that clunk, then a brace would definitely help - if you can find one that fits.
2018 340i F30 Xdrive
      10-21-2014, 08:12 AM   #10
JETmn
2011 335Xi  [0.00]
Joey is 6MT, so it should be the large diff. I think only the AT's have the small diff.
      10-21-2014, 08:29 AM   #11
MadToy
64
Ah - Then I would definitely start with the brace.
      10-21-2014, 10:18 AM   #12
Joey911
Joey911's Avatar
Supposed to be very happy like my old E46
There's no official post of people who got it all sort out.. I don't know..
      10-21-2014, 10:21 AM   #13
Joey911
Joey911's Avatar
Well the diff go top to bottom around 6mm, would that be the thump? and btw my car has 27,000 miles on it.
I will upload a video of that lik lik lik lik noise when half clutch and the car tires to move.
How about PRELOADING the center bearing of the shaft? or alignment of rear shaft into diff?
      10-21-2014, 10:56 AM   #14
Joey911
Joey911's Avatar
http://www.e46fanatics.com/forum/sho...d.php?t=855233
useful thread, same thump as me
      11-05-2014, 11:23 AM   #15
Joey911
Joey911's Avatar
UPDATE:
So I bring my car in to a shop, wasted 800 dollars, cars still drive weird feels weird comparing to when the first time I get the car.
They said Diffsonline even swap the new Wavetrac unit, but I thump the same.
Emailed Wavetrac, they say it has to be something else wrong cause the unit won't do this noise? But the BMW specialist shop I went to can't find anything else is wrong? Wtf?
This sucks really bad
      11-05-2014, 03:51 PM   #16
Subaru335i
Drives: 2011 335i 6MT
2007 Subaru WRX  [0.00]
2011 335i  [0.00]
Damn dude that is a nightmare! I hope someone can help you get this resolved!
Daily: 2012 CTS-V Sedan 6MT
Fun: 2014 Porsche 911 PDK
More Fun: 2001 AP1 Honda S2000 White on red
Family/Offroad: 2020 Lexus LX 570 w/ 34" tires
Sold: 2011 335i 6MT, 2007 WRX Limited - STI swap, TD06-20GXT, E85
      11-05-2014, 11:07 PM   #17
Joey911
Joey911's Avatar
The more I drive it the more I think something is so wrong.... It jerk so badly when engaging the clutch that I can't drive smooth anymore even if I try so hard
      11-18-2014, 05:14 PM   #18
Techevo
Evo Junkie
35
Drives: E91 325D M-Sport, Evo 6
If the bearing pre-loads are not tight enough (pinion bearings and diff bearings), the backlash will increase when the diff is under load, but will measure up in tolerance when measured static with the diff on the bench, unless a lot of torque is applied to the crownwheel (with the pinion held tight to stop it rotating) when checking the backlash.
Ohlins DFV with 400/800 Swifts // M3 arms and bushes // H&R anti-roll bars // Modified top mounts allowing -1.5 deg front camber // 19" MORR VS8.2 // 235/265 Pilot Super Sports // Wavetrac // Evolve remap.
      11-19-2014, 02:18 PM   #19
Subaru335i
2011 335i  [0.00]
^ That makes sense. It does sound like something is wrong with the diff.
      11-28-2014, 09:52 PM   #20
Techevo
Evo Junkie
35
What was the backlash measurement?
If it's thumping and jerking I bet it's way too big and out of limits.
      01-02-2015, 09:17 PM   #21
danas
16
Drives: E92 335i M N54
any updates? by any chance you found the fix?
I just installed MFactory diff and have the same issue as you describe.. So far only 200 miles, but I doubt it will go away
      01-12-2015, 11:37 AM   #22
Joey911
Joey911's Avatar
Wavetrac told me they found nothing wrong in the diff, and will do further more test... And hasn't reply me since then, I'm still trying to email Dana, but no reply
I'm here in New England, I notice the thump will be super soft when it's so cold etc under 32F, or after I drift on dry road for like 10 minutes (things heat up)...
then the thump is basically gone, not annoying or noticeable for a while
But once starting driving for a while (in cold, things warm up), or drive normal for a while after drifting (things cool down), thump will come back again!!!!!! So annoying
So I'm thinking could the viscosity of the diff fluid soften the problem a little..?
335i, lsd, thump, wavetrac
