BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > BMW E92 335i Coilover Install DIY with Pictures
      07-13-2014, 10:00 PM   #1
Andrew
Moderator
Andrew's Avatar
429
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
We spent the weekend installing a coilover kit on my cousin's 2008 BMW E92 335i and did a DIY guide with some photos from the install. Check out the link below for the full write up.
http://thebuildjournal.com/diy/bmw-e...r-install-diy/
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      07-14-2014, 12:23 AM   #2
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
No need to loosen control arm bolt on coilover install and suspension should be at ride height and torque to 74ftlbs.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      05-03-2016, 05:22 PM   #3
ksspacegray07
Drives: 335is coupe
when installing the rear shock
after ive got the spring set to the correct height, how do i install the shock at the correct height?
      05-24-2016, 04:45 PM   #4
bmuum3
Drives: 1998 M3/4 ---> 2010 E92 335i
Where are the jack stands?????
      05-25-2016, 01:41 PM   #5
techlogik
Drives: 2020 M340i Dravit Grey
Also, which way do you have the rear springs installed with the "perch" adjustment piece?
I've seen most photos where the spring is sitting on the arm on the bottom, and the adjuster/perch piece is at the top to set the height?
Nobody seems to have photos of this...M3 is that way, 1 series that way, but haven't seen photos of the spring installed on a E92 335i couple.
Thanks
2020 M340i: Dravit Grey Mettalic. Loaded.
335i, bc racing, coilover, diy
