      04-27-2015, 12:30 AM   #67
rod.bearings
rod.bearings's Avatar
123
Drives: E92 M3
2009 BMW 135i  [0.00]
Just got my Apex arc 8s 😁
235/265 hankook Rs-3
On kw v1s, m3 front control arms and pins removed
2011 E92 M3 AW DCT
IG - rod.bearings
      05-27-2015, 12:45 AM   #68
Newguy123
Drives: 2008 Nissan Titan
Subscribed
2012 DCT 135i
PURE S2
JB4/mhd
Fuel-It! direct port meth injection
check out my youtube channel here
      05-27-2015, 06:51 AM   #69
Fidiman
Fidiman's Avatar
France
113
Drives: BMW 120d e82 M Sportpaket
2010 120d E82  [10.00]
Any rub front ? Which tires did you order ? What's the ET and the width of the wheels ?
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ...
French community of 1 and 2 Series: One-Two-Bimmers
      11-13-2015, 08:40 AM   #70
GoodMoodley
225
Drives: 12' 135i Pure Stg 2, 15' 228i
So did anyone get their ARC-8s delivered yet from the recent Group Buy? Looking forward to seeing some new pics.
I should have mine some time next week.
      11-26-2015, 08:36 PM   #71
skyscraper_g80
skyscraper_g80's Avatar
Australia
371
Drives: 2022 G80 M3 Competition xDrive
My new ARC-8's from the group buy: 18x8.5ET45 Square in Hyper Silver
      11-30-2015, 07:30 AM   #72
GoodMoodley
225
Got my new set mounted
18" in Anthracite. Running 265 / 235 BFG Comp 2 A/S. Sitting on stock springs.
Had to get them mounted so I could play with them a little before the snow flies.
Getting some minor occasional rubbing. I think it is only the front but I'm not sure. Will have to examine a little closer this week when I take them off to put on my winters.
These tires have really wide shoulder/rim protectors.
      12-01-2015, 06:39 AM   #73
BMW 130i Greg
BMW 130i Greg's Avatar
Drives: BMW 130i 2010
WOW mate, that looks stunning!
What tyre's do you run (specs) and do you have spacers mounted up front?
Any other modifications up front or just the M3 LCA's?
BTW: keep making lovely vids on youtube, I like!
@evolution42
      12-01-2015, 07:59 PM   #74
skyscraper_g80
Australia
371
@evolution42
Thanks man, I'll always upload footage of any motorsport event I participate in
For the ARC-8's, I am running Nitto NT-01 235/40R18 square with a 3mm spacer up front. Full mod list can be found here http://www.1addicts.com/forums/bpgar...o=view&id=7620
      12-02-2015, 04:49 PM   #75
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
I wish APEX would come out with a high offset 17" rear wheel for these cars. 18" isn't necessary at all, but it's near impossible to find 17x9.5 fitments for these cars.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      12-02-2015, 09:32 PM   #76
rac
rac's Avatar
27
Drives: 2008 135i 6MT
In my googling I found braid to be a possible alternative to forgestar for custom track wheels with a reasonable price tag. They are not ultralight, but fairly light. Durability probably a strong point.
      12-03-2015, 08:32 AM   #77
e36addict
Drives: 2013 X1 35iX
Love this colour. Absolutely stunning.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
      12-03-2015, 09:46 AM   #78
GoodMoodley
225
Thanks, I was on the fence when I saw the ad for this car online but I was sold once I saw it in person.
      01-08-2016, 01:02 PM   #79
GoodMoodley
225
This is where my setup was rubbing. Ignore the dirt. A lot of new home construction around me and can't avoid it when it rains.
The first two pics show the front. You can see where the tire rubbed the strut tube. I also identified paint wear from rubbing on the inner fender lip. It rubbed at about the last 3/4 inch of lip right where it meets with the bumper.
The third pic shows where the inner rear tire was rubbing the felt liner a little bit.
Might just not worry about the rub on the strut tube. Should just wear off a smidgen of rubber. Will try to roll the little bit of fender with hand tools noting that it is such a small area. For the rear I am considering a 3mm spacer. Should flush it out a little more. I think I have enough room for that.
This is all with stock suspension. Planning on installing Eibachs in the spring and hoping that it doesn't get worse. No issues right now as I am rolling on my winters.
These tires definitely run wide. I chose them because of their ability to handle cooler temps so I can minimize my time on winter wheels but I am now kinda wishing I just went with Michelin PSS.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid
      01-08-2016, 01:11 PM   #80
Ginger_Extract
California-bound
Drives: BMW 135i
Yup, same as me, I used a 5mm spacer in the rear. I would remedy the issue ASAP as the the rear wheels will burn through the fuel filler and then you're hosed.
      01-08-2016, 01:38 PM   #81
GoodMoodley
225
What tire are you running? Was considering only a 3mm spacer as I was concerned about rubbing on fender. Also curious if there was enough hub lip left with spacer to properly connect with bore in wheel.
      01-08-2016, 07:24 PM   #82
Ginger_Extract
California-bound
Drives: BMW 135i
255/35 RS3.
      02-01-2016, 12:23 PM   #83
drewster99
43
Drives: 1 SERIES
I'm about to mount my ARC-8 wheels (18x8.5 ET45 & 18x9.5 ET62) with a 225/255 setup and ST XTA coilovers. From what I read, it seems like the people that have issue with rubbing are the ones that went with a 235/265 setup. My question is, with the setup I plan to run, will I need spacers or will I not have rubbing issues when the car is lowered ~1.5"?
      02-01-2016, 01:35 PM   #84
rod.bearings
123
Drives: E92 M3
I'm on 235/265 Hankook RS3 which run a little bigger and lowered on KW V1. No rubbing at all but I do have m3 control arms. Planning to go with 245/265 PSS this season with Dinan Camber plates
      02-13-2016, 04:07 AM   #85
GoodMoodley
225
So Apex just switched up the rear offset for the 18x9.5 ARC-8 to 58mm from 62mm. Makes sense to me as I just ordered a set of 5mm spacers to solve my inner fender liner rub.
      03-12-2016, 04:07 PM   #86
drewster99
43
Drives: 1 SERIES
      03-14-2016, 10:42 AM   #87
GoodMoodley
225
Here are a couple of newer pics with the car sitting on Eibachs.
I added a set of 5mm spacers in the rear due to inner shroud/ felt liner rub but now I get a minor rub on the actual fender. May get all of the fenders rolled.
      08-30-2016, 07:58 PM   #88
Smac355
Drives:
So I am running arc 8s 8.5/9.5 with 235/265 front/rear. 95k miles and stock suspension is just about shot so time for full upgrade, m3 bits all around and likely coilover (tckline hopefully) swift springs etc. anyone running such setup, everything right now seems to be real tight so not sure if I am setting myself up for a disaster or not...
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
18x8.5, 18x9.5, apex, arc-8, wheels
Search this Thread:
