TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > E90 325i DSC, DCC, Start Off Assistant, Run Flat Error
      07-06-2009, 03:34 PM   #1
Willy325i
Willy325i's Avatar
Drives: E93 LCI 335i M Sport
2013 BMW 335i E93  [0.00]
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
Exclamation E90 325i DSC, DCC, Start Off Assistant, Run Flat Error
my E90 325i 2007, Steering Column Failure????
When I start the car, its ok, NO FAULT, but whenever I start TURNING the steering wheel, the error is triggered, Replacing this at the stealership, is very expensive, And my warranty is over, is there any way to fix this without replacing the whole steering column and reprogram the car from scratch?
I'm thinkng that since its already working, there might be something that I can do, to FIX it. Any Ideas are more than welcomed
Youtube Link here:
Really Appreciate ANY help, as I'm Disprate right now...
Power is Nothing Without Control!
      07-07-2009, 04:25 PM   #2
Willy325i
Willy325i's Avatar
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
whats up guys? no news, comments or any help till now? Any Suggestions?
regards;
Will
      07-07-2009, 10:29 PM   #3
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
issue with szl most likely...column itself likely doesnt need replaced just the module although programming is neccesary..most likely the fault has something to do with steering angle plausability or internal module issue..
      07-08-2009, 01:15 PM   #4
Willy325i
Willy325i's Avatar
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
volkswackin:
I can't thank you enough, but let me get this straight..., as per what you suggested, it seems that I don't need to replace the (Steering wheel column) is that correct?
if it is, what is the Name in English (lol) for the might-be faulty part?
I really appreciate your cooperation friend.
Will
      07-09-2009, 09:38 PM   #5
GMWNashville
nah not the column..this goes at the end of the column behind the steering wheel. its called a steering angle sensor... or szl
      07-10-2009, 03:57 AM   #6
Willy325i
Willy325i's Avatar
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
Thanks alot, I will give it a go, and see what may come up, but my last question for you is this:
Do I need to reprogram the whole car, as its the case when changing the Column? or no need to do that?
I'm asking because I want to know if I will ever need to go to the dealer to reprogram my car.
Regards
      07-10-2009, 04:01 AM   #7
Willy325i
Willy325i's Avatar
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
Sorry, I just forget to ask about Part Number? if available
      07-10-2009, 10:03 PM   #8
GMWNashville
not sure on part number..but entire vehicle will need to be coded to new part..
      07-16-2009, 09:18 PM   #9
headsock
Drives: black
hi i think we have the same problem.
dealer said its a common problem, anyways, they went in and cleaned the "steering angle sensor".. they said sometimes it can be cleaned sometimes it has to be replaced.. cost around $70 (PHP3500) to have it cleaned. error hasn't reaappeared
      07-22-2009, 03:25 PM   #10
Willy325i
Willy325i's Avatar
2012 BMW M3  [10.00]
2007 325i  [10.00]
2005 318i  [10.00]
Exclamation
I really hope that its a matter of sensor cleaning only, cuz it costs a hell, plus leaving the car at the dealer, and no loaner, since warranty is over.
Do you think I can clean it myself?
And:
Will the car need Software programming using the GT1 Tool?, or since its the same sensor (no replace) then I don't need SW?
really appreciate it man
      09-08-2009, 05:33 PM   #11
hachicho
hachicho's Avatar
Drives: 2018 Bmw M5
do you have any pictures on where is the sensor goes.... i have the same problem help please and thanks in advance....
      09-08-2009, 07:37 PM   #12
Viper3812
Drives: M Coupe
It's behind the steering wheel inside the stalk area.
      09-09-2009, 01:46 AM   #13
E90 ANdy
Drives: SG E90 325i sport + idrive
I'm having the same problem with my E90 it just happend tonight when i was playing with the car (swapping headlights) i had my wheel turned all the way so i could access the rear signal covers. When i went to turn on the car to test my lights the steering wheel automatically straightened itself out and the error came on. The wheels were still turned... I was able to get everything working, car drives like normal but now i have that error..
FTM error
DSC error
Amber BRAKE light on
I am also out of warranty
      09-09-2009, 04:47 PM   #14
hachicho
hachicho's Avatar
Drives: 2018 Bmw M5
need some pics please.....
      09-15-2009, 08:40 AM   #15
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
DSC, FTM and amber BRAKE errors
I am on a 4300 miles road trip, during a 10hr driving day approx half way into the day trip while the car was on cruise control, I've got the DSC, FTM and amber BRAKE errors. Cruise control would not engage with these msg. It wouldn't clear so I stopped at the first oppertunity. Turned of the car, got gas, started the engine - error cleared after pulling onto the highway, back on cruise control. Second time the errors came back after approx 30 minutes or so on cruise control. Wouldn't clear untill I turned of the car. Started it back up again, errors cleared after a mile (or so) driving. Then the third time the error came back briefly and cleared itself. All highway driving, no wierd steering angles, smooth pavement, 75 - 85 mph speeds, somewhat mountainous terrain (Colorado - Wyoming - I-80). Has not come back (yet). Any ideas?
I just checked my service msg on my I-drive, nothing seems to be stored relating to these errors. Did it clear itself?
2007 BMW ///M Coupe
      09-15-2009, 04:09 PM   #16
hachicho
hachicho's Avatar
Drives: 2018 Bmw M5
i was wondering where is that steering angle sensor goes? thats all if anyone know please upload pics.thanks
      09-15-2009, 06:44 PM   #17
Rekla
Rekla's Avatar
I don't want to take over this post, so I started another one... This time I have a Transmission error as well...
http://www.e90post.com/forums/showthread.php?t=302383
2007 BMW ///M Coupe
      09-15-2009, 10:08 PM   #18
Viper3812
Drives: M Coupe
The steering angle sensor is behind the steering wheel in the middle of the stalk area.
      09-24-2009, 10:13 AM   #19
KoPe
Drives: e90
e90 dsc problems
I have had similar probles due to alternator and voltage regulator.
You can try few things before new steering angle sensor:
1) start the car and turn the wheel couple of times from at most position from left to right and back (meaning from end to end). This should recalibrate the sensor, some say.
2) Go and check somewhere the alternator and voltage regulator. If there are low voltage or voltage is going up and down DSC is first to react.
      08-21-2010, 04:49 AM   #20
pmenadue
Drives: 320i Exec
Known problem!
Check this service bulletin - http://www.bmwtis.com/tsb/bulletins/...p/B340406g.htm
dcc, dsc, run flat, start off assistant
Search this Thread:
