Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Transfer case problem
      06-22-2012, 12:01 AM   #1
idungknoe
Drives: 2007 328xi
Hi I have a 2007 328xi and my transfer case went bad. Do you guys think its my wheel setup that can make it go bad? I am running some m3 zcp wheels with 225/40/19 front and 255/35/19 rears (those tires are what came with the rims when I bought them and the tires are pretty much brand new)
I am getting the transfer case replaced soon and was wondering if the wheels are the cause of it. I don't want it to go bad again. Please let me know what you think. Thanks
      06-22-2012, 10:58 AM   #2
AWD Addict
Chief Executive
AWD Addict's Avatar
300
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
There has been some speculation that tire sizing could impact the transfer case.
Typically, people try and have a rolling diameter variance from front to rear of less than 1%, and you're somewhere near 1/4 of 1%. Most people with 19s seem to be running 265 35/235 40 (closer to 1/3 of 1%).
I had mine replaced, and while it could have been a wheel diameter issue, I tend to doubt it.
      06-22-2012, 11:27 AM   #3
idungknoe
Drives: 2007 328xi
I bought the rims thinking that oem tires are ok for this setup. I don't want to get into the hassle of buying new tires and selling the ones I have. Transfer case is getting replace next week. If this happens again I'm screwed.
      06-22-2012, 12:03 PM   #4
Carl Morris
Drives: 2008 335xi 6MT
If you're rolling diameters are that close, I don't think it has anything to do with your wheels and tires.
      06-22-2012, 09:50 PM   #5
idungknoe
Drives: 2007 328xi
My car has 68k. I know that might also be a factor. I need more feedbacks please. What do you guys think
      06-24-2012, 12:56 AM   #6
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
there are hundreds of ppl here running stagger setups on their XI for years and never had a problem...so the answer is "No"
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      06-28-2012, 08:13 AM   #7
BAMxi
BAMxi's Avatar
30
Drives: E90 328xi
2007 328xi  [10.00]
I'd say it probably just went bad. I had my transfer case servo motor replaced before I even put my 19s on. Seems fairly common for our cars. There are a few posts on transfer case issues going on right now, so you're not alone.
Eibach Pro Kit | 19" Avant Garde M341 | BMS PBX
      06-28-2012, 08:18 AM   #8
obert
obert's Avatar
Drives: 2013 328i
I believe the 335xi come stock with a staggered set up.
As long as you are not running a crazy size difference I would say it has nothing to do with the size your running.
      10-24-2012, 11:38 PM   #9
Fly1ngSqu1rr3l
Drives: 2007 E90 335xi
BMW dealership just tried to tell me that I can't run the brand new VMR V718s I bought w/ 225/40R18 and 255/35R18 tires.
225/45R17 = 24.97" / 634.23mm
225/40R18 = 25.08" / 637.03mm (+0.44%)
255/35R18 = 25.02" / 635.50mm (+0.20%)
I go in tomorrow to see if they can reset my computer or repair my transfer case (extended warranty) on my 2007 335xi . However, I don't know what to do about the wheels. I put the stock wheels back on to get the calibration done, but could the technician be right when he says there is NO fix for my computer throwing errors with the new wheels?
      10-25-2012, 09:15 PM   #10
Jeffman
Jeffman's Avatar
28
Drives: 2008 335xi E90
I don't believe the wheels and tires are causing the problem. Mike Miller of BMWCCA Roundel "Tech Talk" fame recommends transfer case fluid change at 30,000 miles as part of preventive maintenance, which I just did a few months ago on my 2008 335xi with 18 inch Apex wheels 235 40 front / 265 40 rear first mounted with Dunlop Direzza Star Spec (17k miles) and now with Michelin PSS. No problems yet.
      10-25-2012, 11:14 PM   #11
Mspeed_1
Mspeed_1's Avatar
20
Drives: Car
I had my transfercase just gone bad and replaced a few month ago, my tires were 225/40/18 all around, but i was lowered. however, i doubt that's what's caused the problem. Just comes with age of the car, I have an 07 e90.
      10-26-2012, 12:17 AM   #12
Fly1ngSqu1rr3l
Here's to hoping I'm not chasing codes this week. VTG motor replacement in the AM should clear all the codes, then time to test the wheels again.
Thank you all for the technical and emotional support. /sniff.
I love you guys.
      10-28-2012, 07:54 PM   #13
Fly1ngSqu1rr3l
I love you guys.
Fixed . VTG motor did the trick, computer has stopped complaining.
      11-04-2012, 10:09 PM   #14
bmw32atexi
Drives: E90 328xi Space Gray
Does anyone know of symptoms of a failing transfer case ? EG. makes some type of noise ?
      11-05-2012, 01:29 AM   #15
kamek
Drives: 2018 X3 M40i
2008 BMW 328xi  [8.20]
Huh...? 225/40 and 255/35 are just fine.
Creaking/grinding from a stop was my symptom.
abs, awd, dsc
