Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Journal: N54 Total Engine Rebuild & Upgraded Internals
      12-12-2010, 07:57 AM   #45
atomic69
atomic69's Avatar
Drives: Alpina D3 Bi-Turbo
Originally Posted by 335i E92 View Post
Tony
Informative & indepth as ever!!
As one or two have commented on here the amount of damage and wear for 50k is shocking. This thread as interesting as it is will now doubt be causing concern / panic for many on here that are running mods on the n54.
Just to try to ease everyones minds a little i think it only fair to push the point that your car whilst regularly serviced has been pushed to the limit & tracked many many times. Whilst the carbon build up is a definate worry (even with a CC) I wouldn't expect anywhere near that kind of wear on engines for the majority of n54 owners out there who are enjoying the performance of thier mods on the road and only exposing the car to medium level temps.
There are probably many on here like myself who drop thier oil every 5k and whilst modded at 370bhp + don't push their car to extreems. Don't get me wrong Ill have times when I drive the car hard but not for extended periods of time and I personally back off everytime my temp gets to 120c.
As you've mentioned alot of the damage is heat related, what sort of temps have you seen on track days?
Best of luck with the rebuild, You really are a pioneer of the n54. Hope you get her back on her feet n fitter than ever ready for some Nurburg action
If you are seeing oil temps 120degC of a fairly regular basis then you need to look into additional oil cooling. If you wanted something nice and discreet then a Laminova type oil cooler would be ideal.
      12-12-2010, 08:17 AM   #46
zltm089
zltm089's Avatar
243
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
Absolutely amazing thread!!!....Thanks for posting!....
Did Birds do the port and polish work?
My engine is on 50k Miles aswell.....(but standard).....hope the damage isn't too bad!!!...(its still running fine, so touch wood!!!)
You are a the n54 god!!!.....
      12-12-2010, 08:23 AM   #47
zltm089
zltm089's Avatar
243
Can I ask how much bhp you getting from the engine?
      12-12-2010, 08:43 AM   #48
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Fantastic stuff. Will enjoy this. It is frightening to see such engine wear, but safe to say Tony's engine has had a tough life around the ring. Not your average usage around there.
Most will go maybe twice a year, and do what 10 -15 laps per visit.
Tony will go 7-8 times per year and does approx 50 properly hard laps per visit maybe even more. Thats some hammering.
Now its being re-built ''Properly'' It will be insane!!!
997.2 GT3
      12-12-2010, 10:07 AM   #49
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
Im amazed you did all this work so far but didn't dry sump already..
BTW a degree of det will see of the crown and ring lands like that - or a failing fuel delivery from a shot injector.
I have done it on a big bike engine, and went the big-bore Wiseco route to fix the liner gouges.
      12-12-2010, 10:19 AM   #50
magic77
magic77's Avatar
258
Drives: ex- 335i
wow some serious work maybe next time we go to the ring at least it want break down and I can finally get a lap out with the ring maister.
F30 335i M Sport - now departed
      12-12-2010, 11:16 AM   #51
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Originally Posted by atomic69 View Post
Looking a the pics there look to be some heat issues with the big end's. There could be many reasons for this and without some data logs it would be difficult to say conclusively.
You have chosen your components and manufactures wisely and I would rate CP-Carrillo as being one of the top three manufactures in the world along side Arrow, Omega and Cosworth. Aftermarket pistons tend to be made from low expansion alloy forgings like 2618 or 4032 as they are far more resistant to high loads and temps than oe pistons. As you are not doing things by half if I were you I would also contact Vandervell and see if they could produce you some Mahle Motorsport bearings to suit. Mahle's Motorsport cast bearing are without doubt the best available and offer far better load characteristics than other manufactures "Race" bearings which tend to be just standard bearings that are hand picked and checked for dimensional tolerances.
As for oiling issues, unless you go to the trouble of installing a dry sump your only real choice would be to install baffles and install an Accusump. The Accusump's work very well for what they are and have a race proven record, being used in the likes of the BTTC etc. Modifying the oe oil pump to increase flow and possibly pressure is also something to consider.
Great information and thank you for your input. I agree entirely with your thoughts on CP-Carillo and hence why I used them to manufacture the engine parts for me. I have already thought of the Mahle bearings (CP actually advised me on this!) and things are 'in process'!
I've also been looking at dry-sumping and have figured out a way of doing it successfully, but the problem is that there isn't enough clearance above the engine. The engine would need to be lowered in the bay, with ramifications for the ancillaries and the steering rack. It's a real ball-ache!
I already have an Accusump (3qt high pressure) and I think with the pan baffles this will be a suitable combination of devices to maintain oil pressure under heavy load.
See above on the dry sump issue
And yes, you are right a degree of detonation can cause much of the damage.
Tony
You are quite right - the damage shown in this engine is not representative of the state of N54 engines around the world. There are other underlying issues here which won't occur with other owners.
However it is worrying that so many people in the States in particular are chasing ever increasing amounts of horsepower, and yet pay less than zero attention to the ancillaries or supporting products that are needed to maintain that reliability. The pictures of my engine should serve as a wake up call to all those running 18psi boost pressures on race maps etc etc...
Originally Posted by Yahoo View Post
OK. So, could the problem be that the oil is thicker at higher operating temps?
Please bear in mind that I have little knowledge of fluid dynamics and continually bow to your knowledge of all things N54 Tony - however, I would like to explore whether this hypothesis holds water.
If the problem is due to pistons getting too hot, expanding and scoring the cylinder walls, this surely points towards a lubrication issue. The purpose of engine oil being to lubricate all moving parts, preventing metal:metal contact, generating too much friction/heat and damaging components.
So, could this be due to the following conditions / characteristics of your engine:
1) Blueprinted engine = tighter tolerances between moving parts than a stock N54.
2) 5w-40 oil = thicker engine oil at high temps = less flow to moving parts at high temps then with recommended 5w-30 oil.
3) Sustained track use = sustained higher temps then would be experienced then 99.9% of N54s on the road.
Could these circumstances lead to expanded pistons, even tighter tolerances, less flow of thicker engine oil to components, more friction, increased heat and so on?
If so, this would become a vicious circle of friction, heat, lack of lubrication leading to this type of engine wear.
After the initial premature engine wear, once cooled, the tolerances between pistons and cylinder wall would become larger increasing blow by and carbonisation.
Out of interest - which catch can are you running?
The 5W-40 is definitely NOT the cause of any of this wear. The oil is nowhere near too viscous at operating temperatures and having been speaking to so many engine builders and experts, they have actually advised the opposite. With the temperatures that I run the engine at, typically 125-130 degrees oil temperature at the 'Ring, they have suggested that I should run a 5W-50 oil to ensure high-temperature oil structure and pressure is maintained. The thinner the oil, the lower the oil pressure and at high temperatures a 5W-30 oil or 0W-30 is thinner than a 5W-40. It's certainly not an issue of lubrication in itself (as can be seen by the oil seepage past the rings) but more likely of oil pressure.
Originally Posted by ///ajd View Post
Very interesting Tony,
There is also an interesting thread on PH in relation to the latest DI 997 engines. Ian_UK1 is looking to get his internals boroscoped soon at an indie garage.
What do you think the bigger issue is - oil seeping past the valve stems, or oil from recirc'd air? Catch cans obviously only help with the latter.
http://www.pistonheads.com/gassing/t...997?&mid=78451
I think a lot of the issues being seen are a result of oil vapour recirculating into the intake system, and not having petrol washing over the valves to effectively 'clean' the system. Direct injection has many benefits, but it may be that we are seeing one of the downsides to the new technology. I'm no expert on DI techniques and solutions so this is only my own hypothesis.
BMW have designed this N54 engine to run an average oil operating temperature of 115 degrees. For whatever reason, they want it running hot. The Motorsport engines run at 130-135 degrees. I already use a double oil cooler system using Setrab cores. I might change over to a Laminova cooler - still thinking about this.
A lot
      12-12-2010, 12:18 PM   #52
Yahoo
Drives: 335i e91 LCI msport
Good info, thanks Tony.
      12-12-2010, 12:52 PM   #53
m1bjr
m1bjr's Avatar
72
I suspect the high operating temperature is to assist fuel vaporisation in the combustion chamber with D.I.
Without the inlet tract of a conventional setup, I suspect they want high cylinder temps instead.
A-La Diesel.
      12-12-2010, 01:21 PM   #54
subieworx
Drives: 07 335
Originally Posted by E92Fan View Post
The honest truth is that we have no idea why there is such abnormal wear. Yes the car lives a lot of its life on the Nurburgring, but equally it is exceptionally well maintained and regularly inspected. The Nurburgring doesn't actually pose that many challenges to an engine - if anything, a circuit like Laguna Seca is more demanding on an engine in terms of oil lubrication and starvation because it's a much smaller track with greater frequency of corners within the same time frame.
The engine is now being loaded up with data logging equipment so I can directly measure things like oil pressure and exhaust gas temperatures.
What are the ring end gaps on the pistons you just pulled? We often see in newer factory engine builds cylinder wear of this kind on engine used for performance reasons. We find that oems are gapping the rings very tight for emissions reasons which can lead to the ring ends butting against each other then pushing outward to the cylinder walls and creating massive scoring. Seems to be what could be going on here.
      12-12-2010, 02:04 PM   #55
stealth-twntrbo
stealth-twntrbo's Avatar
Drives: 2020 740xi
This makes me want to do a carbon cleaning, and also get a catch can, oil cooler, and aluminum radiator.
      12-12-2010, 02:08 PM   #56
Oli
Campervan man
94
Drives: RS3 and VW Kombi
Bloody hell. That has some serious wear on it. However the carbon buildup s common on modern engines, when i had my RS4 there were people getting new engines, from Audi because of decreased power due to this!
Looking forward to seeing the rebuild and results - did you RR it before the dismantle, so you can compare?
www.bmvs-camperhire.co.uk
Genuine VW T5 California Rental
      12-12-2010, 02:17 PM   #57
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
I don't think comparing will count, the engine is having many different, higher spec componets fitted, let alone the porting and polishing of the head so will not be a fair comparison.
I think Tony's engine ran various different power outputs in its previous state, anywhere from 450-550HP depending on map etc.
997.2 GT3
      12-12-2010, 03:14 PM   #58
MB London
Come as you are
MB London's Avatar
136
Drives: M4 SSll
This is a really interesting read, doesn't really make much sense to me but enjoyable none the less. Tony, with such an incredible knowledge of this engine and with so much data, experince and history - are the men in white coats from BMW not knocking on your door offering you a job in their R&D Dept. If they're not they should be
      12-12-2010, 03:35 PM   #59
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
There are a couple of improvements being done, namely an all-aluminium radiator in place of the plastic end-tanked OEM version...
Definitely an improvement. You'll love the piece once it's finally in your car.
Master Batman (currently in London)
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      12-12-2010, 03:42 PM   #60
Alpina_B3_Lux
263
2009 335i  [8.90]
The standard compression ratio of the N54 engine is 10.2:1, whilst Alpina use a 9.3:1 piston in their B3S.
I know we discussed that yesterday and I don't want to be splitting hairs here (although, you know my profession so I'm usually paid to do that), but the compression ratio for the Alpina B3S Biturbo is 9.4:1. See here: Alpina Catalogue (pages 17 and 26).
EDIT: Wanted to add that Alpina also mentions they're running 1.3bar of boost pressure (18.85 psi) which seems incredibly high to me. I wonder what they do to counter the problems of the N54 engine we're seeing here (except the lower compression)?
Master Batman
      12-12-2010, 04:42 PM   #61
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
I'll measure next time I have the pistons on the bench
      12-12-2010, 04:43 PM   #62
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
Awesome thread
      12-12-2010, 04:47 PM   #63
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Master Batman
Lawyers
I stand corrected
And yes, Alpina run up to 1.3bar of boost pressure but I am 99% sure that the top end of that is an overboost facility. Nevertheless, the lower compression pistons will allow higher levels of boost to be run safely. The exact component changes of the Alpina aren't really known, although I can probably get hold of the Alpina-specific parts disc to see what part numbers differ...
      12-12-2010, 05:27 PM   #64
toxicnerve
97
Drives: E92 335d M-Sport
I get the impression Tony is in touch with the sheds at BMW...he's showing them how far their N54 unit can be pushed. Though to be honest, once all the mods are done, can the engine even be considered an N54 anymore?!?!?
Tony,
Thanks for sharing re the insurance issue. I appreciate the insight.
Finally, why so reluctant to share bhp figures? Are you under some kind of NDA? (serious question). Is someone (BMW?) afraid that you'll be giving ideas to the great unwashed as to what they can get away with in on a 35i engine?
Also, with all the upgrades (you might have mentioned this already but I can't see it) are you still running the standard 6-speed ZF gearbox that comes OE?
Have you had her on a rolling road lately?
Also, with all the mods you're running, how would your car fair against an E92 M3 or similar?
      12-12-2010, 06:17 PM   #65
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Tony,
The insurance thing is a bit of a minefield to be honest. It took a lot of explaining to the underwriters exactly what my car is about and the fact it's not a regular hopped-up car that is ragged around the local roads by a boy racer
The issue with the bhp figures is that there is too much willy-waving on the forum (US forum) and the figures are always open to interpretation depending on the rolling road used, the operator and so on. I don't want to put out a number for people then to go "oh I can get that with just a $500 JB3" etc etc. There is much more to an engine than just a bhp figure. Two cars can make the same crazy bhp, but one will be running 22psi boost and about to blow up, whereas mine will be running 15psi and be the epitome of reliability and drivability.
There isn't an NDA or anything formal like that in place, although there is an agreement between parties on certain matters
The gearbox has different software, but in essence is the same ZF gearbox as standard. It was last on a rolling road about 6 months ago
If you want a real-world indication of performance, I can give you this example... with the previous engine configuration and starting my car in second gear, I out-drag a 997 Porsche GT3RS
      12-13-2010, 01:38 AM   #66
toxicnerve
97
It's always worth asking (and sometimes pressing the issue) because (as in your case) there may often be a reasonable answer provided...
Interesting insight and re your last line....
carbon, cylinder head, engine, intake, n54, n54 engine, piston, rebuild, valve
