Really!! Another E85 Thread...
07-10-2012, 10:15 PM | #1 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
The objective: E85 how to use it correctly?
I have read various post that support and don't support E85 for the N54. Some say yes, mix a little E85 (20%) and this will help with timing corrections. Some say, no don't mix any E85 unless you have a proper tune I have received feedback from others that say "are you worried about your fuel pump and injectors?" And have read from the EVO Thread, "i have never seen such a clean fuel pump. E85 Rocks!..." (yeah i know, different car, but its relative to E85.) Anyway, So what are the proper precautions to run E85 for miles to come?? Yes, I have a mix of 80/20. So far very nice results and it fixed all my timing corrections with my tune. I am not worried and I will continue to run this mix until convinced otherwise. Research? yes I have been doing a lot of research, but have not found anything really wrong with using it. besides the bad press about lower fuel economy. and that's the least of my worries. Please, this thread is meant to be constructive, try not to troll. Please post your experience and if you are running E85, what is your mix, tune, and any specific mods to support E85.... thanks, Vince
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI Last edited by VNeBLOB42; 07-10-2012 at 10:31 PM.. |
07-10-2012, 10:35 PM | #2 |
Your Master.
37
Rep 268
JB4 - MAP 5, 50/50 Mix E85/91, 3K Miles on E85
Runs great, no issues better then regular 91. But now that I'm back in cali and the closes E85 station is 25ish minutes away I am switching back to 91
07-10-2012, 10:53 PM | #3 |
Rep 150
Jb4 map 5.
Car runs great anywhere from a 50% to 20% e85 mix. Thousands of miles and couple of 1/4 mile passes.
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
07-10-2012, 11:35 PM | #5 |
Rep 2,396
Drives: '08 E90 335i
COBB -- Mixing 3 gallons (~20%) into one full tank of 93, especially when I flash for the Stg 2+FMIC Aggressive Map. Here's my Pros vs Cons Listing
Pros:
07-10-2012, 11:44 PM | #6 |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
I did a lot of testing with E85 last month. I use 20-35% of E85. Whenever I used from 35-50% my car threw codes at high loads.
My ECU doesn't like to much of it but it sure gives it much more power. |
07-11-2012, 01:00 AM | #7 |
Rep 538
07-11-2012, 07:01 AM | #9 |
Rainbow Racer
1008
Rep 2,539
I would at least run enough to get near a 0 value in timing retard (JB4) or very little to no timing corrections (Procede and Cobb) for the map you plan to run; it will take some experimenting but rewarding because of the results. For me, that means mixing 5 gallons or E70 (31%) to a full tank of 93 octane on map 3 set at 17.5psi.
FWIW, our Brazil counterparts have the same fueling system as we do and they have mandatory E25 content.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
07-11-2012, 07:35 AM | #10 |
Rep 6,986
Drives: 15 F80 M3, 22 G01 X3 30i
According to the owner's manual, E85 is specifically not recommended for the engines in current BMWs - the fuel systems are not equipped for it, and damage could occur with long-term use. If you run E85 and develop fuel system problems or other types of issues or damage to the engine, your warranty won't be honored. That said, almost all gasoline these days contains a certain percentage of ethanol, but not 85% like E85 - more like "may contain up to 10% ethanol", as it says on the pumps. So if you stick with no more than 10 to 15 percent, it will probably be diluted enough not to cause damage. The other factor is that ethanol is "hygroscopic" and will retain water/moisture unlike gasoline, so there is a possibility of injector damage. It's like it says on over-the-counter drugs - "please read the label carefully and use only as directed".
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-11-2012, 08:39 AM | #11 |
324
Rep 2,663
07-11-2012, 09:14 AM | #12 | |
Rep 1,244
I was talking with someone locally who was testing the ethanol content in various gas stations and he said some were testing as high as 17% even though they reported 10%. My point in bringing this up is that it's probably difficult to know exactly what we're getting. With all that being said, I've been running a 50/50 mix with PROcede for about 2 weeks. I noticed that the car seems to be adapting to it rather nicely as the timing looks better than it did when I first ran it. (Probably took some time to get the mixture right in my tank and for the car to adapt.) |
07-11-2012, 09:36 AM | #13 |
Rep 868
Jb4 / e85
JB4 tuned FBO+meth
I went to the track on Friday night 50/50 e85/93 1st run 12.0@116 2nd run 12.3 codes 29e2/29f2 3rd run 12.5 same codes Codes popped just before 100mph at WOT Hooked up to laptop and fuel loop was @ 98 each time it coded Terry advised me to me to turn off loop auto learn and set loop to 80 to stop codes I was wondering if maybe codes were due to e85 Still running out the e85 tank I'll fill up with93 tomorrow and do some logs to see if I get the same codes without e85 before turning off the fuel loop auto loop
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
07-11-2012, 09:54 AM | #14 |
Rep 2,197
As alluded to earlier, almost all gasoline currently sold in the US is atleast 10%-15% ethanol(higher concentrations elsewhere in the world.) It has been this way for a while now and i'm sure BMW/Continental was aware of this when designing the fuel system.
IMO the thing that e85 is most useful for, when not autotooning, is to keep timing corrections at bay on aggressive maps. If making an e85 map in ATR then a set ratio has to be determined and strictly adhered to, which isn't a problem if e85 and 9x are sold together in the same station are conveniently located to you. |
07-11-2012, 10:05 AM | #15 |
Rep 4,632
Running E85 for about 4K miles now.
Throw 5 gallons of it to every tank which is around 30% mix. Cleans up timing very nicely! Able to run more boost.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
07-11-2012, 10:05 AM | #16 | ||||
Rep 1,677
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
07-11-2012, 11:01 AM | #17 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
I have been mixing E85 with CA 91 for about 20,000 miles now. I only used about 20-30% E85 up until JB4 started to be tuned for it at the beginning of this year. Since then I have been on about 40-50% on map 6 then map 5 and have had no fuel or air issues. I have good timing and am boosting over 16 psi consistently.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
07-11-2012, 02:37 PM | #18 | |
Rep 108
I ask this, because I'm contemplating on either getting e85 mix or meth injection for my car |
07-11-2012, 02:47 PM | #19 |
Rep 7,378
No... Meth is injected in the chargepipe
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-11-2012, 02:54 PM | #20 |
DIYER
614
Rep 5,521
Running E85 for the past 8,000 miles, mods in signature....running it at 45-50%
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-11-2012, 04:01 PM | #21 | |
Rep 584
u have good tires?? should be 11s i would say |
07-11-2012, 04:53 PM | #22 |
Rep 1,054
jb4 and map 5 wih 50/50 with e85/93. 17psi with no meth, no dips in timing....Nuff Said
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
e85, ethanol, n54 |
