      08-02-2014, 01:05 AM   #1
Orangee94
Orangee94's Avatar
40
Drives: 135i n55 DCT 2013
help: advan rs-df/ rz-df
hi guys im just after some help here since im pretty noob with offsets and stuff
would the advans rs-d/rz-df fit with for the 135i with or without guard rolling?
fronts: 18" x 8.5" et35 with 225/35,40
rears: 18" x 9.5" et35 with 255/35
i've seen people have et38's in rear with CCW classic rims or something but yea thought 3mm's cant be THAT harmful
thanks in advance
      08-02-2014, 09:12 AM   #2
A_Squared
Drives: n54
Are you lowered? If you are, the rears will most likely rub due to the offset. You want et45 or et50 with a 9.5" wheel back there. The fronts might be ok if you dial in some camber.
      08-02-2014, 11:51 AM   #3
Orangee94
Orangee94's Avatar
40
nah stock ride height atm cant get too low in aus otherwise the POL POL will get me and also the area around me is already scraping on my driveway and friends
      08-02-2014, 06:56 PM   #4
Marc08EX
Marc08EX's Avatar
139
Drives: 2011 E82 135i
I don't think it matters whether you're lowered or not. +35 offset on those widths will rub IMO.
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
      08-02-2014, 07:56 PM   #5
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
I will be able to tell you in about a week when I put my advan rsII on...
Running 18x8.5 +35 225/40 up front
More conservative 18x9.5 +50 255/35 in rear
      08-04-2014, 06:28 AM   #6
Orangee94
Orangee94's Avatar
40
WELP that sucks then D;
      08-04-2014, 06:29 AM   #7
Orangee94
Orangee94's Avatar
40
thats really conservative at the rear haha. The rs2's are still pretty nice but i'm those guys seeking a bit of DISH (Y)
      08-04-2014, 07:14 AM   #8
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
Beggers can't be choosers with the jap brands...
Really conservative would be +58 or +62
I will be able to tell you if you can find another 15mm at least
      08-09-2014, 11:26 AM   #9
Orangee94
Orangee94's Avatar
40
yes that is true D;
      08-14-2014, 01:26 AM   #10
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
FYI
Installed the 9.5 +50 on the rear and at 10mm lower than stock ride height with -1.5 deg of camber it is close to flush with the gaurd....
if you want to find another 15mm you will need more camber and pulling the gaurds for sure...
      08-14-2014, 08:03 AM   #11
rsr552
rsr552's Avatar
Drives: e90 m3
Have this exact fitment....Front works just fine if you are on stock height...but once i made it lower with about 1 finger gap or less it rubbed like crazy...Rear is perfect in my opinion
      08-14-2014, 10:22 AM   #12
Orangee94
Orangee94's Avatar
40
FYI
oh shieeeee do you have a picture ?
      08-14-2014, 09:36 PM   #13
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
http://www.1addicts.com/forums/showthread.php?t=1021127
      08-14-2014, 10:09 PM   #14
c0ris07
c0ris07's Avatar
Australia
25
Drives: BMW 135i
rear has settled since then. Ill try and get a better rear shot.
RSR552 how much lower were you when it started rubbing bad? I have no rub now and am 330 from center to eyebrow
      08-15-2014, 01:22 AM   #15
flinchy
Drives: E82 135i
you don't want anything to do with 9.5+35 then haha
you'll be poking by 10-15mm at a guess, unless you have some crazy stretched tires and camber or something.
8.5+40 is perfect front fitment with about 1.5deg camber on 235's.. could probably go 245 even.. +35 i'd guesstimate 235 would be the limit.
with my offsets effectively +55 i get plenty of scrub when 120mm off the ground but it's still legal enough, in the guard.. making it +35 would be hell.
135i, advans, australia
