      04-21-2013, 11:43 AM   #1
Ihave1
Drives: 2008 135i
Diff install parts
My diff makes a humming sound so I am swapping it out for a fresh one. I will have to remove the muffler, unbolt the driveshaft (have the tool), and L/R output shafts (ordered E10 socket). Are any of the diff bolts or exhaust seals in there one time use? Its an fully assembled differential so I dont need to worry about any of the internal seals. I did put in fresh SAF-XJ.
      11-28-2013, 01:02 PM   #2
bwawuz02
Long Member
14
Drives: 2016 BSM F80
As you can see from the lack of replies to this post, most 1er owners aren't big DIYers. lol. Did you ever find out what all was needed?
      11-28-2013, 03:58 PM   #3
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
All aluminum bolts of side shafts should be replaced with new ones according to bmw. Though i think they can be reused.
      11-28-2013, 04:17 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
You will need a "thin walled" 52mm wrench to get off #6 in that first diagram. Someone posted this link along time ago... here is the wrench you need for only $27 off of Amazon.com
http://www.amazon.com/dp/B003NSC7R0/...=I4A85WAHB3SOA
I would also change your diff fluid after 1K miles. Also don't do any hard launches or top speed runs until your new diff is broken in. BMW says not to exceed 170 kph for the first 2K kms.
You might also want to replace the (rubber) "flex disc" up front between the trans output shaft and the drive shaft. Its also called a "quibo" disc.
Dackel
diff, differential, install
