11-26-2011, 06:00 PM | #1 |
Rep 2
Best E90 intake upgrade
Hi,
I'm looking to get a little more horsepower and improve the sound of my E90 M3 without spending a lot. I've heard that OEM intake unit is optimal compared to aftermarket units and the best upgrade you can make is changing the filter. Is this true? I just bought mine yesterday and I'd appreciate any help. Thanks! Scott |
11-26-2011, 06:11 PM | #2 |
Rep 6,149
Don't waste your money, OEM is fine. Congrats on your purchase!
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
11-26-2011, 06:52 PM | #3 |
Rep 3,329
Dont bother changing the full intake you might end up losing power. Go for a drop in filter from a reputable company. I have the active autowerke filter and love it but there are a lot of others to choose from. Search and choose the one you like the best
F80 ///M3 6MT Avus Blue ZCP |
11-26-2011, 07:16 PM | #4 | |
Rep 5,496
Don't waste money on an intake. Drop-in filter is the way to go! |
11-26-2011, 08:16 PM | #5 |
drop a gear and...
79
Rep 967
The best intake upgrade is one with a compressor attached. Otherwise look into the macht schnell intake system for better sound.
11-26-2011, 08:41 PM | #6 |
Rep 1,105
I have posted about this recently. A filter (I got BMS but MS or any other high flow oiled filter will do) will give you a nice increase in intake roar over stock.
However the OEM filter size is so monstrous and big, and the intake box sucks in so much air, and there is an opening in the hood directly from the intake, that you get as much intake sound as you are going to get. For an experiment I took the top off my intake box and left it as a "open" intake setup to see if it was signifigantly louder and even with the top of the airbox off (just filter on) it was no different than the stock setup with the lid on like normal. I think the intake path out the hood allows for all the sound to be heard as that is a direct path to the filter. The other intake kits are not worth it and IMO likely lose some performance. The "elbow" in the aftermarket parts is generally larger than OEM and the larger the diameter, the slower velocity of air flow. Bmw designed their elbow the size they did for a reason IMO and I believe the OEM setup is better than anything out there. Filter is a good upgrade though-sounds great! |
11-26-2011, 09:22 PM | #7 |
Rep 746
To add to what Ateam said, the stock filter has a charcoal filter built in and the aftermarket filters do not, which is why they are a bit louder and add some horsepower.
Currently my car is stock, but I will be buying a BMC filter soon |
11-26-2011, 09:45 PM | #8 |
Rep 1,105
Actually after 2010 they no longer have charcoal built in and they are changed to the euro filter setup. So if you have a pre-2010 you even get more difference with aftermarket filter.
11-27-2011, 12:57 AM | #9 |
Rep 746
That's good to know, it disproves any rumors that the removing the charcoal filter will harm the car in any way. Thanks
12-01-2011, 11:47 AM | #12 | |
Enthusiast
194
Rep 1,283
Drives: 2015 F80 M3
Garage List 2011 BMW E93 M3 [0.00]
2004 BMW M3 [9.50] 2015 BMW F80 M3 [0.00] 1997 BMW 840CI [9.50] 2011 BMW X5 M [10.00] 2008 BMW 335i Conve ... [8.40] |
I'm going to do this mod however I want to make the right choice.
2017 Porsche 718 Boxster Carerra White / Garnet Red / Black
2013 Porsche 991.1 911 Carrera S Platinum Silver Metallic / Black and Yellow accents 2014 F31 328i xDrive Alpine White / Black |
12-01-2011, 12:02 PM | #13 |
Rep 423
Drives: E92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, 90631 La Habra, CA
Oiled has better performance, but the dry filter has better filtration capability. Personally I go with oiled just to get that extra performance, but either one you go with, I'm sure you'll be happy.
12-01-2011, 12:24 PM | #14 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
The oiled filter has 75% better air flow over stock and the dry filter has 50% better air flow over stock. Personally, I wouldn't want to deal with re-oiling the filter after cleaning it so I would go with a dry filter. I highly doubt I would notice a 25% difference in air flow, but who knows It all comes down to personal preference. Can't go wrong with either choice though.
12-01-2011, 10:37 PM | #15 | |
4th down; 4th quarter? Renegade.
87
Rep 3,850
The key factor on the intake side is pressure drop, not "air velocity". |
12-01-2011, 11:43 PM | #16 | |
Rep 1,105
While pressure changes is related to velocity due to burnoille's principe it is definetly a factor. Some of the RPI exhaust designs are kind of cool that they progressively get smaller toward the end of the exhaust to keep the gases flowing more quickly. Not on the m3 obviously. |
12-03-2011, 12:00 AM | #17 | |
87
Rep 3,850
We won't know exactly what is optimal until someone like Evolve does a thorough analysis, like they did recently on the exhaust. Making gross generalizations without any data to back them up doesn't help anyone. |
03-11-2013, 03:00 PM | #19 | |
Rep 1,406
I was wondering too, does an Intake do much as in sound and performance of the car??? |
03-12-2013, 06:50 AM | #21 | |
Grease Monkey
293
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
An air filter can't let in more air without letting in more dirt when unless the filter media area is larger! |
mharris200751.00 |
03-12-2013, 03:29 PM | #22 |
Rep 426
Well you are disregarding the entire concept of an oil filter. The whole point is that it can have bigger "holes" in the filter but the oil itself acts as a filter to "stick" to particals. So instead of a mechanical filter if you will, its a oil film filter that lets air through but sticks the dirt and particals.
So yes you can have bigger flow with not much more dirt go through due to the oil. That is why putting an oiled filter back in under oiled is devestating I have 5 new BMC fitlers i replace every 10k miles as I don't like to clean and reoil mine. The non-oiled filters obviously flow less as stated |
intake, upgrade |
