Upgraded n54 Twins
06-21-2012, 02:57 AM | #45 |
Rep 422
These twins will replace the factory turbos, with custom made manifolds as well, so both of each turbo will be connected to 3-3 cylinders. There is a good reason, as a good idea stands behind it, why we use different size of turbine housing and different size of wastgate on each turbo. The larger turbine house will have smaller wastgate compared to the smaller turbine house, which will have larger wastgate. We named it "twin-scroll" effect. At this moment i can't tell you, how they will work againts factory turbos or RB turbos, only time will tell. These turbos will spool up a little bit later than factory ones, but we try to built many-many small tricks and ideas to decrease the gap as small as possible.
Upgrade n54 with twin-scroll (or at least divided) turbine housing turbo is also a good idea, and maybe simplier than my project. We have tried to purchase EFR 7670, but BW could not sell it (the twin-scroll turbine housee) EFR 7670, so we choose another way. Regarding the different turbo upgrades (RB, ASR, Shiv single,...): There are always different PATHS to walk through. All of them have advantages and disadvantages compared to each other. |
06-21-2012, 03:39 AM | #46 | |
Rep 1,432
06-21-2012, 11:29 AM | #47 |
Rep 1,201
I think you misunderstand how much it costs to make a CAST IRON manifold. It requires a mold, which is more expensive to make than even a few tubular manifolds.
If you're talking about two log manifolds; then yes, those are generally cheaper than a tubular; even though they don't flow as well and will limit the torque output. You also have to count that you're buying another turbo, and a single that flows equivalently doesn't cost anywhere near 2x as much. Twin IC piping, twin intakes, etc, etc. It's cheaper to do a single
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
06-21-2012, 03:11 PM | #48 | |
Rep 422
ft_th1 = size of factory turbo turbine housing nr.1 ft_th2 = size of factory turbo turbine housing nr.2 (=ft_th1) ft_wg1 = size of factory turbo wastgate nr.1 ft_wg2 = size of factory turbo wastgate nr.2 (=ft_wg1) nt_th1 = size of new turbo turbine house nr.1 nt_th2 = size of new turbo turbine house nr.1 nt_wg1 = size of new turbo wastgate nr.1 nt_wg2 = size of new turbo wastgate nr.2 ft_th1 = ft_th2 < nt_th1 < nt_th2 nt_wg1 > nt_wg2 >= ft_wg1=ft_wg2 The smaller turbine housed (nt_th1) turbo will spool up sooner than the larger one (nt_th2). The larger turbine house (nt_2) can delivery more air and exhaust gas on high RPM/Load than smaller turbine house (nt_th2). To compensate the difference, the smaller turbine house has larger wastgate (nt_wg1 > nt_wg2) and the larger turbine house has smaller wastgate. In the smaller turbine house on high load some exhaust gas, which cannot flow through the turbine wheel can flow through via the larger wastgate (as the exhaust pressure opens a little bit the larger wastgate). The problem with the factory turbos is the bottleneck of the exhaust manifold and the relative small turbine house. Depend on application, you can have great results with factory or factory upgraded turbos with the small turbine house and restrictive manifolds, but instead of upgrading them I choose a new PATH based on these ideas and give them a try. Laszlo |
06-21-2012, 11:35 PM | #49 | |
Rep 36
Funny, it cost me nothing but time...
06-22-2012, 07:41 AM | #50 | |
Rep 1,029
06-22-2012, 08:12 AM | #51 | |
130
Rep 2,290
06-22-2012, 08:33 AM | #52 |
Rep 1,571
CSL335i,
Why you would want the 3 back cylinder "bank" to have a heavier pre-turbine exhaust restriction than the 3 front cylinder "bank" is beyond me? Or am I reading that right? I would want the turbine housings to have the exact same flow capability and also have the wastegate to have the exact same flow capability. Looks like an awesome project but you really aren't thinking that part through too well IMO. Rob |
06-24-2012, 11:42 AM | #53 | |
Rep 422
Laszlo |
06-25-2012, 03:38 AM | #55 |
Rep 422
We would like to stay with OEM ECU with calibrated Cobb maps and JB4 on the top of it. (Currently i have JB4 installed and Cobb, which is not installedd so far).
Wastgates on turbos will be boost actuated (not vacuum) by Garett actuators, or at least we try to fit these things into the OEM architecture. We have some ideas, how we can connect boost actuated Actuators via solenoid control, but we have not tested yet these ideas. If we cannot fit boost actuated Actuators via factory or other solenoids, then we will use vacuum type Forge actuators as a backup plan. |
06-25-2012, 06:23 AM | #56 |
Rep 1,201
Really? If that's the case, why don't you just roll your own kit then?
FYI: A ghetto-fied manifold running weld-els isn't a cast manifold.
06-25-2012, 07:31 AM | #57 | |
291
Rep 2,898
Is this correct? Neil |
06-25-2012, 08:44 AM | #58 | |
Rep 36
The cool thing is ductual iron has a 0% shrink factor so you could just use the model you made in mock-up as the pattern, just go back and add machine stock later when you add you core prints. But aluminum is 5/16 per foot and stainless is 1/4 per foot, so those would just have to be left as models. Oh ya, then you have to make down pipes, then figure out how to get cool air to the turbos, and tuning. I'll make you a deal, pay pal me $15,000 as a gift, so I don't pay any fees, and my pattern shop will get right on it. Pony up big boy |
06-25-2012, 09:02 AM | #59 |
Rep 422
06-25-2012, 09:12 AM | #60 |
291
Rep 2,898
06-25-2012, 09:14 AM | #61 |
Rep 1,029
06-25-2012, 09:37 AM | #63 |
Rep 3,177
personally, i think the whole "upgraded twins with different turbo manifolds" is not worth it.
*it will be more costly than a big single turbo *more points of failure or points where issues can arise, from twice the turbo's, twice the downpipes, twice the oil/coolant lines, twice the wastegates, etc. *single turbo will be more efficient. log manifolds suck and are not as efficient as a properly designed tubular manifold. the upgraded twins will have higher exhaust back-pressure, resulting in higher IAT's, less power, etc. *you're going to have just as much lag and boost response as the single turbo kit *a properly sized, single turbo on the n54 won't lag much worse than stock turbo's, as illustrated by FBIS and vishnu's recent threads. look a the dyno's, especially the ones with the stock dyno over-layed onto the single turbo dyno *twin turbo's will produce much higher torque, which will kill transmissions, axles, etc faster. a single turbo will have more hp than tq, as shown by vishnu's work. twin turbo upgrade will run more torque than vishnu's kit. personally, i wouldn't want more than 500 ft-lbs to the wheels, like the single turbo kit runs *i'm not just basing this just off vishnu's kit. they're the first with real, quantifiable results. others will fall in over time. a single turbo is better for the n54, all things considered. |
06-25-2012, 05:30 PM | #64 |
Rep 4,764
+1 Bryce. I think that for a hybrid twin upgrade there is a nice market, and for a single a nice market, but not much room between them. All we need is the vishnu final kit pricing so people can make a real decision with all the info on what upgrade market they fall in.
06-25-2012, 09:14 PM | #65 |
Rep 444
Remember HPFs kit is somewhere in the works haha...Tired of their stupid updates...Full Race I believe is making a kit due next year....Excellent Rep...and there are a couple people working on a twin upgrade project...
Vishnu kit looks good, but will definitely wait till people log thousands of miles as well as what the latter companies have to offer
2017 Mineral White M3
Mods to COME |
06-26-2012, 02:47 AM | #66 | |
Rep 422
During desing, our preferences were: 1, twin-scroll turbine house turbo (like BW EFR) or two new single-scroll turbo (each for 3 cylinder). I have choosed the second way. 2, One single-scroll turbo is not an option for me, i would not use one big single-scroll on an I6 n54, which does not mean, that somebody cannot fit it and use it. There are different PATH walk, every PATH has advantages and disadvantages compared to each other. Laszlo |
gt28rs, single, turbo, twins, upgrade |
