Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > VMR Wheel size/offset HELP on a 335i
      02-28-2014, 09:35 AM   #23
ndq
ndq's Avatar
Drives: 335i
Originally Posted by mambamvp View Post
everyone is telling me the same exact thing except 265 in the back...why do u say 275?
Because I chose 275s
265 is very close and gives a little more room, usually, which translates to less chance of rubbing. Personally, I just wanted the maximum width possible and I am running a 10" wheel and not a 9.5" (typical) which a 265 could be borderline stretched on (depending on the tire).
      02-28-2014, 11:28 AM   #24
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
265s are not really considered a stretch for a 19x9.5. You can safely run as narrow as a 235/35/19 tire on a 19x9.5 without an issue.
Obviously though, most people want to run the widest tire possible.
      09-05-2014, 11:11 PM   #25
zhp pilot
20
Drives: 2017 X5M
I figured I would just post here instead of starting a new thread since I have a similar question with these wheels. I'm likely going to pick up a set of v703 19x8.5 et40 and 19x9.5 et45 for my LCI e90. My current wheels are the same size but et35 (235/35) and et33 (265/30). When the v703's arrive I will use my current tires as they still have about 50% of the tread left.
My question is, when it comes time to buy new tires, would I be able to get away with bumping up the size to 245/35 (possibly 225/40) in the front and 265/35 for the rear? Currently on stock sport suspension, may lower later depending on what I can get away with.
I know I can do 275/30 on the rear with no issue on an LCI with the 45 offset but I would prefer more sidewall. All the e90 LCI threads where people venture away from "normal" sizes end without the OP ever updating.
So for cliff notes:
e90 LCI
f: 19x8.5 et40 with 245/35 ?
r: 19x9.5 et45 with 265/35 ?
2017 f85 X5M | Donington Grey | Aragon Brown
2009 e90 335i | Black Sapphire Metallic | Saddle Brown
2004 e46 330ci ZHP | Silver Gray | Black (RIP)
      09-06-2014, 12:06 AM   #26
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
So for cliff notes:
e90 LCI
Front would be fine, since it has correct aspect ratio, but the rear i wouldn't recommend using 35 aspect ratio. Since it makes the front and rear difference to 2%. Stick with 265 or 275/30/19.
You know you can fit your current wheels also to your LCI. http://www.e90post.com/forums/showpo...08&postcount=2
      09-06-2014, 12:24 AM   #27
zhp pilot
20
Drives: 2017 X5M
I was going by the m3 tire size. But knowing the difference I threw in the possible 225/40 front. That would make the difference around 0.8%.
My current wheels are on the car now but one of the fronts is bent.
      09-06-2014, 02:58 AM   #28
MonacoBlueE90
Finland
163
I don't think there is many guys who have upsized tyres. I know one with 225/45/18 and 255/40/18 combo, but he has stock style 162. So front is 18x8 et34 and rear is 18x8.5 et37.
I think you just would have to test it. 225/40/19 would probably work at front without issues, but rear could possibly cause rubbing issues, especially after lowering, but fender work fixes that.
      01-17-2015, 12:41 PM   #29
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
So for cliff notes:
e90 LCI
Does that really matter since he's not an x drive?
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      01-20-2015, 12:16 AM   #30
MonacoBlueE90
Finland
163
I would say it does, because the difference is so big between front and rear. 245/35/19 and 275/35/19 will have 3.1% difference.
      03-05-2018, 07:08 PM   #31
xxMike61
xxMike61's Avatar
78
Drives: 2011 335i Coupe
Will a set of 19" 8.5 +40 and 10 +38 fit on a 2011 e92 with stock m sport suspension? I don't really care about flushness but more so rubbing and clearance
Thanks
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703
335i, bmw, e92, vmr, wheels
