Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Looking at some new 18" wheels
      06-24-2014, 04:17 PM   #1
trav00
Drives: 2011 Space Gray 335xi sedan
Hey all I am brand new to this. Just picked up a 2011 335i xDrive. The car came with 17" wheels. I am looking at these 7 spoke 18's that come in 8" and 8.5" wide. I am totally sold on the oem sport suspension. It drives like a dream and I have no desire to change it. My goal is to decide to either get a square set up or go staggered with these 18" wheels. Another primary objective is to fill in the wheel gap with a meatier tire. I would also benefit form a meatier tire due to the condition of most roads here in NY.
Another factor- I purchased the wheel and tire protection plan for 5 years. Its to my understanding that as long as the wheels are OEM and under 21" and have the "original" tires on- I am warrantied. So I am unsure of tire options that are covered, as well as sizes. I am assuming run flats are my only choice for warranty coverage
Any advice would be great.
http://www.finishlinewheels.com/BMW/...11/A-59587U20/
Above is a link of the specific wheel I was referencing. Thank you
      06-30-2014, 05:01 PM   #2
trav00
can anyone offer some info?
      06-30-2014, 05:17 PM   #3
bmw325i
Drives: 2006 BMW 325i
Stock sizes are 225/40/18 and 255/35/18.
      06-30-2014, 05:20 PM   #4
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
no real insight to the insurance thing, but I love those wheels. Decided to leave them on my car, so I added 10mm front and 15mm rear spacers to get rid of some of the offset gap.
      07-01-2014, 12:10 AM   #5
dbjb
I sweat pheromones
dbjb's Avatar
202
Drives: e92 335i, retired SLK55
When one gets a larger wheel, typically the tire gets a lower profile so that the total diameter is the same as the original tire.
For example, 225/40/18 becomes 235/35/19. So the tire isn't any meatier. It's actually thinner. The only way to reduce the appearance of gap is with spacers, pushing the wheel out further which gives some illusion that the gap is lessened or truly reduce gap through lowering springs.
Make sense?
      07-01-2014, 12:11 AM   #6
dbjb
I sweat pheromones
dbjb's Avatar
202
If your sold on the OEM suspension, install spacers and see how you like it.
      07-01-2014, 03:28 AM   #7
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
What you could do is use 225/45/18 and 255/40/18 with those 18x8 et34 and 18x8.5 et37. It's fine for xdrive the diameter difference is only 0.22% and since you aren't planning to lower the car i doubt there is going to be any rubbing issues. Here is a nice comparison with style 162 and stock vs. upsized tyres http://www.e90post.com/forums/showth...2#post14323772
Just remember those tyre sizes affect your speedo making it showing slower speed than you really are going, but in reality BMW's Speedo shows more than true speed from factory anyway. So it would be good idea to check with gps what's the true speed really is.
Last edited by MonacoBlueE90; 07-01-2014 at 10:32 AM.. Reason: Little bit of misunderstood info
      07-01-2014, 07:32 AM   #8
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
Drives: 2011 335d M sport
I have an M sport suspension for sale...fits your car...
BMW Advanced Diesel, 2011 335d M sport...
      07-01-2014, 07:52 AM   #9
IBOOSTU
Drives: 19 M5 COMP/21 M5 COMP FROZEN
Just remember those tyre sizes affect your speedo making it showing faster speed than you really are going, but in reality BMW's Speedo shows less than true speed from factory anyway. So it would be good idea to check with gps what's the true speed.
18x8.5" ET35 APEX PS-7 ///////
18x9.5" ET33 APEX PS-7 Wheel
can i fit these on that setup ?
      07-01-2014, 08:54 AM   #10
MonacoBlueE90
Finland
163
Is your car e90 or e92 and is it Lci or pre-lci? Anyways rear is most likely going to rub, since your rear wheel is more aggressive than the one in the link. Especially if you are lowered.
      07-01-2014, 09:47 AM   #11
dbjb
I sweat pheromones
dbjb's Avatar
202
With an e92, you MAY need a slight fender roll in rear... maybe not. The fronts are fine.
      07-01-2014, 09:49 AM   #12
dbjb
I sweat pheromones
dbjb's Avatar
202
Opposite. Speedo shows 60, you may be actually driving 65.
      07-01-2014, 10:43 AM   #13
MonacoBlueE90
Finland
163
True i wrote/understood it wrong. My bad. I will edit the original post. By the way according to the calculator, it's 62mph true speed and speedo shows 60. This should be correct
      07-01-2014, 12:05 PM   #14
bmw325i
Actually he was right. It reads 3mph high with stock sizes so if it says 63 you're actually going 60. Taller tires will make it more accurate.
      07-01-2014, 12:31 PM   #15
MonacoBlueE90
Finland
163
Was i? To be honest i'm not sure anymore I though i was understanding it correctly at first but then started to think. Basically i understand it like this 225/40/18 compared to 225/45/18 says that
Speedo at 60mph will read 62mph. Doesn't it mean that Speedo will show 60mph, but you are going 62mph.
One thing is for sure BMW factory speedo is adjusted to show faster speed than you are really going.
      07-01-2014, 12:57 PM   #16
IBOOSTU
I HAVE AN e92 pre lci 07 sorry for not saying that in first post, i just want to take care of the rims and wheels what setup should i go with guys ? im getting the apex ps7s
and do you guys recommend any tires i want traction in the rain/dry climate as well
      07-01-2014, 01:09 PM   #17
zipstic
Drives: 2008 e92 335xi
2008 335xi Coupe  [10.00]
False.
      07-01-2014, 01:23 PM   #18
MonacoBlueE90
Finland
163
I would assume you would have serious rubbing issues at rear with that upsized 255/40/18, because your rear wheel is more out than stock setup.
You could try 245/40/18 and 275/35/18 which might need fender roll to rear tho. http://www.e90post.com/forums/showthread.php?t=392383
As far as tyre brands look for premium brands Michelins, Continental, Bridgestone etc.
      07-01-2014, 01:24 PM   #19
DieselRacer
Originally Posted by zipstic View Post
False.
do you have a 2011 sedan 3 series if so it will fit like a glove... according to his avatar specs 2011 sedan, sounds like a fit to me explain why it wont work for a 2011 3 series, unless you have a 5 series which could also be a 2011 sedan or their of...thanks...
X drive????
      07-01-2014, 10:30 PM   #20
dbjb
I sweat pheromones
dbjb's Avatar
202
If we throw out the whole BMW speedometer is off... This video does a good job explaining the impact of increasing tire size.
      07-02-2014, 11:04 AM   #21
zipstic
X drive????
Not everything from a 3 series i to a 3 series xi/x-drive is compatible. The springs from an i will work, shocks will not.
      07-02-2014, 07:18 PM   #22
bmw325i
Yes going up to the 45 profile from 40 would mean you are going 2mph faster than you think. But the stock speedometer reads 3mph higher than your actual speed.
So if it says 63 you are really going 60 with stock tires and 62 with the taller tires.
335, 335i, 3series, bmw
