Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Would you put wider spacers on front wheels and thinner in back?
      03-21-2013, 10:16 PM   #1
Jeffman
Jeffman's Avatar
28
Drives: 2008 335xi E90
Here's my current setup:
Pre-lci E90 335xi
Lowered on KW-V1 coilovers, adjusted to 1/2 inch vertical wheel-fender gap in front and 1.5 inch vertical wheel-to-fender gap in rear.
Front wheels: 18" x 8.5" Apex ARC-8 with 235 Michelin PSS
Rear wheels: 18" x 9.5" Apex ARC-8 with 265 Michelin PSS
The horizontal tire-to-fender gap in the front is about 15 mm.
The horizontal tire-to-fender gap in the rear is only about 7 mm.
Question: Does it make sense to put wider spacers on the front wheels, maybe 12 mm, and thinner spacers in the rear, maybe 5mm?
      03-23-2013, 08:19 AM   #2
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
Pre-lci E90 335xi
I would to square up the stance. In think it looks awesome when you can get the front and back tires as close to the outer fender lip with out rubbing or making a fender mod.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
335xi 335i xdrive, apex arc-8, gap, kwv1, spacers
