Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Which tires to go with?
      11-28-2010, 06:33 AM   #1
jahmed78
jahmed78's Avatar
Drives: 2007 BMW e90 335i
I am planning on putting on some 19x8.5 +35 and 19x9.5 +33 m6 reps on my e90 with sport suspension. i will probably add a drop with KWs later on. for the tires i planning to go with 235/35/19 front and 265/30/19 rear. i would rather not roll my fenders.
should i go with Yokohama S-drives or Falken FK-42s? I am not tracking, etc. just city and hwy driving. Is the tire size OK?
2007 335i e90 - black on black w/wood trim and iDrive
19" BMW M-Performance wheels, ST coilovers, m3 rep front bumper and skirts, CF Hamann rep diffuser, Remus Race quad exhaust, aFe DCI, LED angel eyes & DRL kit,
      11-28-2010, 09:35 AM   #2
I335
I335's Avatar
123
Drives: '08 335i Coupe
Tire & wheel size are both great but on an e90 they might not be as flush as they'd be on an e92, but not bad either. I've decided that I'm going for "softer" riding tires when I'm ready for the next set, but I haven't done the research yet as that's a long way off. The only thing I'd recommend against is going with cheap, low quality tires. Tire Rack is a great resource for tire research.
      11-28-2010, 12:52 PM   #3
jahmed78
jahmed78's Avatar
thanks! yea it seems like quality wise these are both decent
      11-28-2010, 08:20 PM   #4
sjb335
Drives: 09 E90 335i
Lost my front run flat the evening before Thanksgiving over 200 miles from my destination. The only tire I could find without being towed for miles to a BMW dealer was a Falken 512. I had both fronts replaced and I have to admit I would have not gone with these tires if I had another choice. However, after a 500 mile return trip today, I am impressed with the tire and will leave them on. Both tires installed at DT was approximately $260.
      11-29-2010, 12:22 AM   #5
jahmed78
jahmed78's Avatar
anyone running on m6 reps on an e90? what size tires and what kind of suspension? did u have to roll fenders?
      11-29-2010, 11:16 AM   #6
Tallest
Tallest's Avatar
1301
Drives: 911
2011 911  [10.00]
why not take something from top tier range for better emergency performance, just in case? probably overall difference will be couple hundred bucks... You may not track the car but you won't detune the 306hp either.
F30.F11.E86.E90.E90.E36
      11-29-2010, 12:16 PM   #7
jahmed78
jahmed78's Avatar
any recommendations?
      11-29-2010, 12:32 PM   #8
Tallest
Tallest's Avatar
1301
Drives: 911
2011 911  [10.00]
Michelin PS2 is what i've been using but you can try GY Eagle F1 is good if you get more rain (michelins start floating in water a bit sooner). Bascially anything from Bridgestone, Michelin, GoodYear and Continental will be good. Top tier tyres perform well not just when new, but also when used a lot. Cheaper tyres have inferior layers underneath it seems and give up performance quicker over time. I dont know what in your area, but if you dont mind slightly higher wear than normal, Michelin PS2 or PS3 is a very good tyre - BMW puts it on M cars too. I mean you don't track, i get that so some may say its' an overkill, but Falken 452 is a kinda pretend performance tyre but really isnt, so why look into something that's trying to be fast but isn't anyway. They are noisy too and much worse than Michelins because my previous 3 series had them on and I wanted to get rid of them asap.
PS. michelin makes some other models here in Europe which will be nice if you dont want the cost of PS2 but still a high quality tyre. They are very good at making the ones with low rolling resistance which gives some 2-3% fuel savings as well.
      11-29-2010, 01:26 PM   #9
Sherwood
Sherwood's Avatar
Drives: SMG 335i
I had s.drives on my G35 coupe and loved them(20inch wheels too). Much better than the stock potenzas the car came with. I'm waiting on my wheels to arrive so I'm searching as well. I have it narrowed to the hankook ventus and yoko s. Drives. Both are similar in price, treadware, and reviews I've read.
      11-29-2010, 03:30 PM   #10
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Both the S.Drives and FK452's are great tires for the money. If you do any kind of spirited driving here and there, S.Drives will offer you slightly more grip.
-Charles@VMRWheels
      11-30-2010, 08:56 AM   #11
OEMconcept
OEMconcept's Avatar
251
Drives: BMW
With the setup you're going with, you will be fine with a 235/35 front and 265/30 rear. As far as tires, go with the Yoko's hands down! The Falkens are crap. If you have to go with the Falkens, go for the Hankook Ventus V12's.
      11-30-2010, 09:27 AM   #12
Tallest
Tallest's Avatar
1301
Drives: 911
2011 911  [10.00]
I'd go with Hankook ventus prime - they are close to Michelin Primacy HP, but may be ride a bit harsher, but overall a good budget tyre.
      11-30-2010, 12:08 PM   #13
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
I'd strongly consider the Conti Extreme Contact DW for a top Tier performance tire with some emphasis placed on ride quality. The price is reasonable as well.
Tires
http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
falken, tires, yokohama
