Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Jb4 Install Help!!
      08-13-2014, 07:20 PM   #1
canen
canen's Avatar
Drives: 2010 E90 335i
Exclamation Jb4 Install Help!!
I am installing a jb4 and am stuck on getting the ecu connectors to seat properly. I have tried for over an hour and can't get the slider all the way in. Can anyone help me out?
Any help is greatly appreciated
      08-13-2014, 08:19 PM   #2
atinybug
Drives: 07 e92 335i 6mt
It should go in easily, I'm betting you have a bent pin in there somewhere.
      08-13-2014, 10:30 PM   #3
beetle6986
20
Drives: E90 335xi, E70 X5 50, 04 Cobra
Push down firmly on the plug as your are trying to push in the slider. I just did another install this weekend. I had to push down on the plug pretty hard.
      08-13-2014, 10:55 PM   #4
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
I can never get the sliders back in because the white ecu box blocks them, the small one I can sort of get in but the large one I got no chance. Any tricks to getting them in? I know you can't just install the connectors with the sliders already in (at least I think)
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      08-13-2014, 11:24 PM   #5
Timothyelkins
Be Kind --- Newb BMW Owner
Drives: 2011 335is convertible
You have the right ones in the right seats? I had a similar issue and had one of the small connectors swapped around on accident.
If it's all in the right seats then it all slides in nice and smooth.
      08-14-2014, 12:38 AM   #6
e90'D10
Drives: SG 2010 e90 335i
Make sure the connectors are matching, that was the same issue I ran into and once I realized they weren't matching I swamped them which caused them to go in EASILY
NOT Sponsored By Mommy Or Daddy
Build Thread 335i 1M http://www.e90post.com/forums/showthread.php?t=1090920 (SOLD)
FBOs | MHD tune V5.1 stage 2| Alpina B3 Flash
      08-14-2014, 01:38 AM   #7
este
N54 to N55
este's Avatar
65
Drives: e92 335i (sold) / M235i 6mt
with the large connecter its easier if you pull the ecu out a couple inches so you can have the slider all the way out as you seat it.
      08-14-2014, 04:49 PM   #8
beetle6986
20
+1. You have to have the ECU pulled up out of the box a bit to get it started or else the slider will be blocked.
      08-14-2014, 05:32 PM   #9
Fillyo75
Fillyo75's Avatar
Drives: 2009 e90 335i
Make sure you are matching up connector colors, not wires.
//|Phil
Current: 2011 Audi S4
Gone: 2009 e90 335 |6MT
jb4
