Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > spacers for staggered xdrive?
      10-11-2012, 09:59 AM   #1
tcheung13
9
Drives: Alpine White 2011 328i xdrive
Im currently running 18x8.5 up front and 18x9.5 in the rear. I've done a lot of searching around and have accumulated some questions. As a staggered set up I am not sure what size spacers to be running in the front or rear. I was thinking 10mm all around, but I'm not sure whether that will hurt the awd system. Also at what point will extended bolts be necessary?
Any suggestions and set ups will greatly appreciated!
      10-11-2012, 10:43 AM   #2
mattt555
Drives: e90 330d
wont hurt the AWD, just running spacers, its the overall tire height that affects it.
so if the tires are the same the wheeks are all turning the same, you'll need longer bolts for 10mm, although I heard 10mm dont fit standard E90s as the the hub is too long, better with 12mm
      10-11-2012, 04:17 PM   #3
tcheung13
9
thanks matt!
      10-12-2012, 10:42 AM   #4
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
keep the rolling circumference within 1% and you should be fine. same goes for diameter. im running a square setup with 10mm and 15mm spacers
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      10-12-2012, 02:43 PM   #5
VMRWheels
VMRWheels's Avatar
2037
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Spacers + AWD = no problem
8.5, 9.5, spacers, staggered, xdrive
Search this Thread:
