Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > FBO + E50 Dyno
      10-15-2013, 07:51 AM   #1
RoyalFlush
Professional Coin Flipper
RoyalFlush's Avatar
Drives: E92 335i
Talking FBO + E50 Dyno
I had my car proTUNED via dyno by Jake@PTF recently; the dyno sheet is below. This is with my turbos not hitting boost until low-mid 3K RPM(I think?) and with a minor boost leak (I think?). I'll be replacing the turbos, strapping on the Aquamist HFS-4 kit, and then hitting the dyno again. It was 90+ degrees that day, so it'll definitely be a lot cooler when I re-dyno.
(I'll post logs when I get them. Jake's been in the process of moving, and I'm not in a rush to get them.)
Modifications:
BMS OCC
BMS LTT
BMS DCI
HPF FMIC
ER CP w/HKS SSQV 4 BOV
AR DPs (Catless)
Vanguard v2 Exhaust (Catless)
Walbro 255LPH LPFP
Alpina B3 TCU Flash
      10-15-2013, 08:10 AM   #2
JStang
JStang's Avatar
562
Drives: FDB M3 CS
Looking good! I dyno'd the E45 map on Saturday and had similar numbers.
      10-15-2013, 08:32 AM   #3
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
Thanks sir! I saw your dyno; impressive as well. I'm gonna' try to iron out the kinks with my turbos and boost leak; hopefully push just a tad bit more.
      10-15-2013, 09:07 AM   #4
bmwm3redblack
bmwm3redblack's Avatar
59
Drives: BMW ///M3 E46, BMW E92 335Xi
I'm gonna go this way myself, but honestly i expect higher numbers on e50,but it's probably your turbos,leaks, good numbers anyway!!!
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
      10-15-2013, 09:11 AM   #5
JStang
JStang's Avatar
562
Drives: FDB M3 CS
The fact that it was 90+ degrees probably didn't help either.
      10-15-2013, 09:12 AM   #6
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
Yeah, I wasn't hitting boost until mid-3K for the most part. I think I'm supposed to hit it around mid-2K? That's a substantial amount of room to build more power.
I know it shouldn't affect it too much, but I was on stock 189s with all-seasons. I'll be putting on some new wheels (19 lbs) and tires (Extreme Summer Performance) before I re-dyno, so that should also help out a little bit.
This is true.
      10-15-2013, 09:16 AM   #7
JStang
JStang's Avatar
562
Drives: FDB M3 CS
This is true.
Were you hitting approximately 18.5 around 4k RPM's?
      10-15-2013, 09:19 AM   #8
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
To be honest, I'm not quite sure. I think I was around 17.9 PSI peak? I'll have to wait for the logs to double-check.
      10-15-2013, 09:28 AM   #9
JStang
JStang's Avatar
562
Drives: FDB M3 CS
That's close. I usually hit around 18.2-18.5 on my E45 map.
      10-15-2013, 11:32 AM   #10
Stucks
Stucks's Avatar
Drives: 2017 F30 340i Xdrive
lookin good aaron. with cooler temps and meth, your car will feel even better. come up for a run sometime with rich or me
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      10-15-2013, 11:52 AM   #11
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
Moore's dyno day in November should be a lot cooler. It was actually pretty cool in the morning while we were setting up the dyno, but by 10-11AM it was already 90+ degrees (WTFBBQ?). I'm hopeful that I'll have the Aquamist HFS-4 kit installed by then.
I'll need new wheels and tires before I run with you two; 189s with all-seasons.
(I'm really looking forward to new turbos though; it'll basically be a new car with the prior 50K maintenance I had done.)
      10-15-2013, 01:11 PM   #12
Stucks
Stucks's Avatar
lol, I run all seasons too
      10-15-2013, 02:02 PM   #13
CPWINCH
CPWINCH's Avatar
Drives: Toyota Prius
This is true.
new wheels wont really affect dyno too much. If you get larger diameter you will actually lose power (on the dyno)
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      10-15-2013, 02:36 PM   #14
Dmacc
200
Drives: 2011 BMW 1M
Any ideas as to where your boost leak might be coming from? I was having a similar issue and not hitting boost till around 3k just like yourself, but it turned out to be my leaky stock dv's. Maybe vacuum lines?
thanks to MGallop
      10-15-2013, 08:13 PM   #15
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
Yeah, but your wheels are far from 189s.
Well, that sucks. I'm definitely getting 19s; have to have some show with the go. (I might get 18" TE37s if I'm able to find a car that has them in person to chheck them out)
I have no idea. I had my vacuum lines replaced today, so I'll double-check. I'm also putting a new CP (long version), so hopefully that'll fix a problem if it was relating to that connection.
Someone will correct me if I'm wrong, but isn't not hitting boost until low-mid 3K more of a problem with the turbos than it is a boost leak? (Excuse the level of newbness if it's shown)
      10-18-2013, 09:15 PM   #16
RoyalFlush
RoyalFlush's Avatar
Drives: E92 335i
Here are some logs:
Datazap - RoyalFlush + FBO + E50
Datazap - RoyalFlush - FBO + E50 (1)
      03-04-2014, 10:53 AM   #17
bmwm3redblack
59
Modifications:
BMS OCC
BMS LTT
BMS DCI
HPF FMIC
AR DPs (Catless)
Walbro 255LPH LPFP
Alpina B3 TCU Flash
Great numbers man!!!!
How do you like your 255 walbro? Any DIY, pics? I want to protune on e60 and still hesitating which way to go???
cobb, e50, fbo, ptf, tuning
