04-09-2013, 05:45 PM | #1 |
16
Rep 114
Automatic High Beams - Dead?
Hi guys,
I drive my car at night a lot because of work so the Automatic High Beams option, which i payed extra for in my MY 2013, was very useful; however, it stopped working a couple of days ago out of nowhere! Have you guys experienced this issue if you have the Automatic High Beam option or am i the first unlucky one?
Omar Liendo
Atlanta,GA |
04-09-2013, 08:50 PM | #2 |
Rep 4,323
Were there street lamps in your highway or side street that were part of your commute?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-09-2013, 09:36 PM | #3 |
Rep 604
hold your hand over the sensor and see if that turns them on (the sensor under your rear view mirror)
07 E83 X3 BSM Sport-->10 E90 335i xDrive BSM M-Sport-->13 F30 335i xDrive EB M-Sport-->16 MKVII LB Golf R --> 19 F22 M240i xDrive MG
04-10-2013, 11:19 AM | #4 | ||
16
Rep 114
It's my fault i should have been more specific: A lot of times just putting my hand in front of the sensor would do the trick; however, what is different now is that the little green light on the dashboard which indicates that i have the AHB on, does not turn on anymore! So it's like it does not get activated anymore
Omar Liendo
Atlanta,GA |
04-10-2013, 01:49 PM | #5 | |
Rep 729
04-10-2013, 03:10 PM | #6 | |
107
Rep 1,997
Then you have to turn the auto high beams on (I dont think it has a 'remember the last setting' for the auto high beams) Last edited by tdizzle; 04-11-2013 at 09:13 AM.. |
04-18-2013, 02:23 PM | #7 |
16
Rep 114
You guys are awesome!! I have no idea when i changed that but apparently i did! It works now!
THANK YOU!!
Omar Liendo
Atlanta,GA |
04-19-2013, 01:01 AM | #8 |
Rep 99
HBAssist is potentially availbale when both headlight switch is in "A" position AND lights are turned ON (due to low environmental light condition). Only then you can activate HBAssist manually (Switch ON with steering wheel switch). In case sufficient environmental light (driving through tunnel or so) the Auto lights turn off which consequentially RESETS the HBAssist. You have to turn it on manually again when lights turn ON. Also daylight changes in this period of year, so there are less conditions where HBAssist is needed; this can be erronuously regarded as a failure.
Now one year driving and still impressed !! |
atlanta, automatic high beams, high beam assist, omar liendo |
