Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Reduced Power Light and No Codes
      04-06-2014, 11:34 PM   #1
STIaintgotnothinonme
Drives: e92 Coupe N54 Black
Ive got an 07 335i coupe and its a blast but lately when i really get on the gas 4k if its cold and 5k if its warmed up the reduced power light comes on but no engine codes. I did some live scans but nothing looked out of the ordinary. Ive cleaned the vanos solenoids and done the spark plugs to no avail. Any ideas? The bmw dealer near me is a rip off. Im going to get it dynoed soon to see if anything comes up then. The car drives fine before during and after so im really at a loss.
      04-07-2014, 01:50 AM   #2
Art818
Sleeper (;
24
Drives: Glendale
maybe intake valves?
Follow Me On Instagram , Ill Follow you back!
IG = @isteeze
      04-07-2014, 11:30 AM   #3
SmAcKs
Drives: BMW 335i BLACK
I had the same problem. If you have a jb4 update the firmware and it will fix the problem it worked for me GL!
      04-07-2014, 02:54 PM   #4
Kid Red
Kid Red's Avatar
107
Drives: 2021 X5 40i
Coil packs? Charge pipe cracked?
Current: 2021 Carbon Black w/Cognac X5 M Sport
Sold: 2018 Dark Graphite 540i M Sport
Sold: 2013 Mineral Grey 335i M-Sport
Sold: 2010 Sapphire Black E90 335i
      04-07-2014, 04:32 PM   #5
I havent got a jb4. My other idea is that it might be running a tad bit lean and then when i really get on the gas it gets too lean because when i took the plugs out they had a bit of white on them which im led to believe is normal for a naturally aspirated car but for a turbo charged car it means lean because they tend to run more rich.
      04-07-2014, 04:34 PM   #6
I havent got a missfire because that'd lead to a code and maybe the charbe pipe because it seems to happen between gear changes or when i left off the gas. Maybe a fault bov
      04-07-2014, 04:57 PM   #7
Kid Red
Kid Red's Avatar
107
Drives: 2021 X5 40i
My charge pipe broke and popped off and when I would get above 3500 it would throw the dash light. The code was only thrown the first time I believe.
      04-07-2014, 07:09 PM   #8
e92_enthusiast_1
e92_enthusiast_1's Avatar
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
Yup, im driving on a CP hanging on by a thread almost right now(waiting for BMS to get their new ones in). I can't go above certain RPM's in certain gears or it can tell there's a "leak" and I get "Engine Malfunction, Reduced Power" checking the code on the instrument cluster is ccid-29? but it's just a generic error, I know it's cause my charge pipe is busted and is leaking under certain boost levels. I can get it to error usually at any time as long as I get on it good.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      04-07-2014, 10:02 PM   #9
alexukie
36
Drives: 335i coupe
check your intercooler pipes to see if they didnt pop off
      04-07-2014, 10:13 PM   #10
ctuna
Drives: 325xi 06 wagon MT
Are you scanning with a BMW compatible scanner.
(one that shows all the BMW shadow codes etc.etc..)
I can't believe you wouldn't get some kind of codes with
a half engine light.
      04-07-2014, 10:36 PM   #11
Im sure its missing something because that doesnt make sense that it wouldnt blow a code out. It seemed a little better today. The car has 100k so theres a bunch of things that could be wrong. All good input you guys.
      04-07-2014, 10:38 PM   #12
I did theyre all good. I think my exhaust vanos is leaking oil aswell
      04-08-2014, 01:59 AM   #13
Just did an oil change. Stupid used car dealership used ultra black silicon and Teflon tape on my oil drain plug causing it to leak. What happened to genuine people?!
      04-09-2014, 09:55 AM   #14
Kid Red
Kid Red's Avatar
107
Drives: 2021 X5 40i
haha, that was me. I didn't drive over 2500 RPMs for a week (would throw the code) before I could take the car in. That was a tough week for me
      04-09-2014, 01:21 PM   #15
e92_enthusiast_1
Im excited, BMS has em in stock again. Mine should arrive tomorrow! Gonna GET ON IT!!!!! Cant wait.
      04-27-2014, 03:58 AM   #16
Update! Just fixed the problem tonight. It was a cracked vacuum line leading to the canisters for the turbos. No half cel. Ridiculous amounts of power and a happy owner. All the lines were fragile and cracking go to your nearest automotive store and buy some 5/32s vacuum line and replace it asap. From what ive heard its a pretty big problem with an easy solution
      04-27-2014, 09:22 AM   #17
shiccobm
Neo
shiccobm's Avatar
10
Drives: 2007 335I
I have the same issue your having . Do you get limp mode when you go full throttle and let it hang around the 4000-5000 rpm ???
Road 1'er
335i, reduced power
