E93 Hard top gets stuck
05-04-2014, 06:41 PM | #1 |
Rep 3
Hi Guys,
This is my first post here at E90posts. I recently bought my 2007 335i convertible. I did not have any issues in the beginning but now the hard top gets stuck before it detaches from right above the windscreen. I have to punch it a little bit for it to get off and then rest everything goes smooth. Can you give me an idea what the problem could be? Nik
Nik
05-04-2014, 07:39 PM | #3 |
Came to the N55 Darkside
1110
Rep 12,740
It's not one of a myriad of sensors- perhaps the roof pistons or some other hardware needs to be adjusted.
In any case, like the brother above me mentioned, you should definitely go to the dealer if feasible- you don't want to tinker with that fickle hardtop yourself. |
05-04-2014, 08:15 PM | #4 |
Rep 107
I had a similar problem where the roof was struggling to disconnect from the windshield latches too. When it finally came loose it popped off way too fast.
I just sprayed the latch and hinges with a bit of WD40 and it's been fine for over a year now. Give that a shot before you go to the stealership
E93 328i | Eibach Pro Kit Lowering Springs | 19 inch BMW Performance 269 Rims | Aero Front Lip | Yellow Fog Light Tint | Black Front Grill | K&N Drop In Filter | Charcoal Filter Delete | Cyba Air Scoops | Rev Motoring Silicone Intake Hose | Magnaflow Full Catback Exhaust | Secondary Cat Delete | BMS Powerbox Tune | BMS Downshift Blocker
05-04-2014, 08:41 PM | #5 |
IG @F30_MPE
257
Rep 703
^Either that or a broken wire/poor connection which is not allowing the latch to detach properly.
I would bring it into the dealership, just to make sure nothing else gets fucked up. |
05-04-2014, 09:08 PM | #6 |
Rep 5,446
Definitely clean and lube the latches and the whole roof actually to keep it functioning smooth, there is a good how to over on bimmerfest about it. If that doesn't do it, it probably needs a bit of adjustment at the dealer.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
335i, hardtop, hardtop convertible |
