Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > 2011 BMW 328i - iPhone 4 USB Integration Issues
      11-28-2011, 04:53 PM   #1
hshah603
Drives: 2011 BMW 328i
Hi everyone. I just recently bought a 2011 328i. My first BMW after driving various Toyota / Lexus vehicles for the last 8-10 years.
I have been trying to connect my iPhone to the car via USB so that I can play Spotify through the car speakers. I have a iPhone 4. I first tried a random Belkin iPhone cord (USB only), then tried an official Apple cord and finally purchased and tried the official BMW cord (with both USB + Aux).
Each time I had the exact same issue. I plug it in, go to the "External Devices" section, see my iPhone Name connected with USB, click on it, have Spotify up and playing on the phone. First I get a message saying "this device is not optimized for this iPhone," press "dismiss" and then all seems OK. Press play in Spotify and I hear the sound OK for about 20 seconds and then it goes out and I no longer see my iPhone connected in "External Devices" (the option gets grayed out). This back and forth connecting and then dropping connection happens over and over, each time I unplug and re-plug it in.
The same occurs if I use Pandora instead of Spotify.
I have a iPhone 4. Just installed iOS5 this morning and have not tried this since. Maybe iOS5 will solve this issue, but I'm not sure since it was working for a few seconds even without upgrading to iOS5.
Any thoughts, suggestions, ideas are much appreciated.
Thanks!
      11-28-2011, 04:57 PM   #2
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Sounds like you have 6FL (underneath your armrest should be a USB port and a standard headphone jack).
If you don't, or even if you do, try using a standard AUX cable plugged into your phone, and when going to sources, select AUX and see if that works for you.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      11-28-2011, 05:08 PM   #3
matrix76
matrix76's Avatar
61
Drives: 2020 Z4 M40i Black/Red
BMW INTERFACE CABLE FOR IPOD IPHONE 3G 3GS 4 AUX/CHARGE
http://www.ebay.com/itm/BMW-INTERFAC...item336842644e
      11-28-2011, 05:09 PM   #4
hshah603
Thanks for the quick reply! I didn't know what "6FL" meant, but yes, these connections are in the center armrest console, so I believe I do have 6FL. I haven't tried AUX only and will definitely give that a try.
I guess even if that works, this constant connections drop via USB+AUX will still bother me and I will still want to get some closure there. It's annoying because it does seem to work fine for 20-30 seconds and then just drops and loses any recognition that a iPhone is plugged in.
      11-28-2011, 05:16 PM   #5
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
I can tell you that I have a 4S, running iOS5, and a '10 with 6FL, and streaming Pandora/Spotify, etc, works on my phone, so I know that 6FL is capable (and the version you have *should* be the same version I have. If you paid for 6FL, it should work, but there was a lot of discussion about the 6FL cables and them working properly/charging our phones. Can you see what the model # is on your cable, just for grins?
      11-28-2011, 05:30 PM   #6
hshah603
Here we go. Part # 61-12-0-440-812 and then it says 0 440 796 on the cord itself. Good to know that it works for you and with a newer iPhone too. I'm sure it will end up being a silly issue and will work out, but it's so far no luck. Thanks again!
      11-28-2011, 05:42 PM   #7
PINeely
PINeely's Avatar
Drives: 2013 535i, 2015 Tundra 1794
I actually had my 6FL cable work flawlessly for months before this same thing happened. I bought a replacement OEM cable and it did exactly as you described; 20-30 good seconds and then it cuts out.
Drives me nuts because if I want to play from my phone I have to plug in to the auxiliary jacks (can't select songs through drive this way) and if I want to use the idrive to song select I have to load a flash drive with music (can't alter contents without reconnecting to a computer).
Issue first pronounced itself on my 3G. Now I have an iPhone 4 with the new iOS and have the same issue.
      11-28-2011, 05:54 PM   #8
dryicerx
27
Drives: 335is
Odd behavior... sounds like a bug with the iDrive software as per PINeely's comment (did you have your idrive software upgraded when this happened).
Have you tried pairing it up with bluetooth to stream the audio, and simply having it plugged in to charge it?
      11-28-2011, 06:30 PM   #9
PINeely
PINeely's Avatar
iDrive software was not updated prior to the issue. It just happened one day about halfway to work.
Never tried Bluetooth streaming as I thought you could only do this with the 2011 models and the i4S.
      11-28-2011, 06:42 PM   #10
Braxo
Drives: 2005 LR3 / 2011 328xi
Unfortunately I cannot remember when I had my iPhone 4.
My iPhone 4s (with iOS5) can stream Spotify to my speakers using an iPod's USB cable.
Sometimes, I'll have Spotify playing, then I plug in the USB and select it through my non-iDrive system. At this time, the music sometimes stops as my phone's Music app opens and begins to play. I have to manually go back to Spotify and start the song again. After that, it continues to play Spotify. Perhaps it would also help to close the Music app.
2011 328i xDrive - Automatic
Twitter: @braxo
      11-29-2011, 04:38 AM   #11
brentb
Drives: 2011 328i
I believe the USB connection is used for playing music through the iPod app only. Why not just plug an audio cable from the headphone jack into the jack on the car. Then select aux instead of iPod from the stereo. Don't expect the radio or steering wheel controls to do anything but adjust the volume though.
      12-26-2011, 11:38 AM   #12
Brenzo
Brenzo's Avatar
Drives: 2015 M235i xDrive
When I try playing Spotify on my iPhone4 over the USB (2011 328xi), it will play for 20-30 seconds and then stop until I hit "play" again in the app. However, it'll stop playing just a few seconds later and I can't get it to consistently play. Not sure if having a jailbroken phone is causing the issue.
I have tried the Music Controls Pro jailbreak app, but that did not solve the problem. My only other thought is seeing if the new iDrive update that supposedly was pushed to dealerships last week can fix my problem.
      03-21-2012, 10:00 AM   #13
SpartanGA
SpartanGA's Avatar
Drives: 2018 BMW M4 Comp F83
I bet this is the best post. the ipod integration is most likely designed for browsing thru the music on your iphone, not playing music from apps.
the aux cable should work, you just wont be able to skip songs...I normally just listen to whatever shuffles up in the app I am playing anyway.
2011, 328i coupe, iphone 4
