Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Rematch: Cobb FBO 335i vs JB4 FBO 335i (Video Inside)
      09-08-2012, 12:17 PM   #1
Laid Black 335i
BMW
Laid Black 335i's Avatar
Drives: 2007 BMW 335i (6MT)
This is a follow up from our first run. Info from our first run can be found here:
http://www.e90post.com/forums/showthread.php?t=724453
To keep things short, I lost the first run because I shifted too slow and my protune wasn't finished. My car is 6MT and "Stucks" car is 6AT. Now that my protune is completed, we set out for a rematch.
Car Mods & Details for Run #2:
Laid Black 335i: 2007 BMW 335i (6MT): Cobb Protune (18 psi), FBO, No Meth, Stock OEM Exhaust, running a 60/40 mix of 93/E85.
VS.
Stucks (Camera Car): 2008 BMW 335i (6AT): JB4 (Map 5 - 16.5psi), FBO, No Meth, Stock OEM Exhaust, running a 75/25 mix of 93/E85.
Summary: We did a 40 roll again letting off around 135. I was able to pull a car length at the start and by the time we let off, I was half a car ahead.
Just for kicks.... here's a video of my 60-130 time. I estimate it is low to mid 9's.
      09-08-2012, 12:31 PM   #2
King mode
Drives: 335xi
Nice. I need a pro tune.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock
13.10@106.01 w/ 1.86 60' (5,800' altitude)
      09-08-2012, 01:17 PM   #3
bboy8282
Drives: BMW 335i
just curious...how much power are u making after the protune?
      09-08-2012, 01:39 PM   #4
Stucks
Stucks's Avatar
Drives: 2017 F30 340i Xdrive
These runs took place in Africa! Very close and good runs! laid black 335i took me for a ride in his car after the run, and his car is really fast! Jake @ protuningfreaks did a great job on the protune cause that thing rips! We also wanted to do a 60 roll, but other circumstances prevented that :/
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      09-08-2012, 04:50 PM   #5
Jake@MOTIV
Jake@MOTIV's Avatar
84
Drives: 135i, 335i
Nice runs. Its impressive considering Dean's car is a manual and the jb4 car is an auto. I want to see some logs if you get a chance. We probably have a little more to squeeze out of it.
      09-08-2012, 04:57 PM   #6
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
6AT > 6MT from a roll
Another point to mention is the Protune runs 18 psi down low; at 5000 RPM (in the powerband, the car runs 17.5 psi tapering to 14), the JB4 uses a 3 psi taper from peak, so if it is actually running 16.5 psi, it's tapering to 13.5 or so, so the boost disparity isn't much.
Either way, nice run.
E90 LCI N54 6AT
      09-08-2012, 05:18 PM   #7
cupertinosteve
Drives: BMW 335i
Just curious, did both cars have passengers?
Looks like you sorted out the difference from your first thread. What was the change?
All-in-all, fun to watch ... its what is expected, both cars being FBO for WOT, there really shouldn't be much of a difference between tunes.
Keep it safe and the right side up.
Vishnu/FFTEC Single Turbo (58mm) 6AT ... 60-130 in 6.881 seconds
Vishnu Procede Rev.3, Vishnu PWM Meth Kit, AE Exhaust, Helix IC, Forge DVs, Wavetrac LSD
#### IT'S FOR SALE ###
      09-08-2012, 05:26 PM   #8
Laid Black 335i
BMW
Not sure, we are going to set up a dyno day soon.
Will do. I was going to today but unfortunately the massive thunderstorm & tornado warning messed those plans up.
Thanks cupertino, the first run I was running just a base map and didn't shift that fast. The protune wasn't complete. Also, I shifted "super fast" this time to give me a chance to keep up with the 6AT. I didn't have a passenger but Stucks had his GF recording but she only weighs like 95lbs.
It's not a single turbo or anything, but I'm definitely enjoying the car now that the custom tune is 98% done.
      09-08-2012, 06:39 PM   #9
CPWINCH
CPWINCH's Avatar
Drives: Toyota Prius
in all honestly 100 lbs makes a little bit of a difference. I would like to see both no passenger. the pro tune would still win tho
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      09-08-2012, 06:58 PM   #10
brusk
brusk's Avatar
33
Drives: 2008 135i Coupe
I'm curious to what happen in the 60-130 vid at about 5200 RPM's it seems to have a stutter or something there.
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
      09-08-2012, 07:52 PM   #11
TLO03
16
Drives: E
umm am i missing something ? you can be fbo with oem exhaust?
      09-08-2012, 07:58 PM   #12
Stucks
Stucks's Avatar
Yes, the e92 coupes exhaust is not really a major restriction until you get to 450whp. youll get maybe 8-9whp max off an exhaust.
      09-08-2012, 08:15 PM   #13
TLO03
16
Drives: E
yeaaah no, bolt ons have never been measured in "only needed if im pushing xxx hp" exhaust used to be the first bolt on. again not trying to get off topic or start crap . but an exhaust is a bolt on available to n54 cars. my thought was when you install all available bolt on's your car is Fbo.
we can agree to disagree, maybe i'm mistaken, please proceed with thread..
great vid good runs.
      09-08-2012, 09:03 PM   #14
LuSt4Boost
Drives: CTS-V
lol... Lance FINALLY loses. Nice run.
And yeh, I consider an exhaust a bolt-on also that completes the FBO acronym.
http://www.e90post.com/forums/image.php?type=sigpic&userid=50760&dateline=132735  2876
Boost |Get a Grip
      09-08-2012, 10:59 PM   #15
AU335i
AU335i's Avatar
78
Drives: 2008 335i E92
mehh... nice runs but honestly from all the talking that was done in the other thread... mainly this:
Dean - send the 002 logs and I'll send you something back that will require the camera to be on his car so you stay in the frame Also shift at 6300ish rpms and shift fast. If you want to meet up tomorrow night we can just belt it out and re-run him.
not impressed.... to pay for a protune only to beat the same car by half a car-length that is running a lower mix of e85? lol but just my opinion... i'm sure your car is still alot more fun though!
      09-09-2012, 12:23 AM   #16
jayzF30
34
Drives: '07 335i, '09 M3
PTF charges like 299 for it 199 for an etune. I really think that's a huge bargain considering how much time they spend to perfect and squeeze the most out of your car. Look at people paying 1500-2000 for an exhaust or 6-900 for dowpipes or intakes and its just bolt up and go. On top of it all these guys won't leave you hanging ever at least in my case a definite both thumbs up and highly recommended. Without the pro tune this car loses but now it wins the race which is worth it to me
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock
      09-09-2012, 12:31 AM   #17
blisstik
blisstik's Avatar
151
Drives: E92
Was that the E50 map?
      09-09-2012, 12:47 AM   #18
Laid Black 335i
BMW
I'm 190lbs. Stucks and his GF are maybe 270lbs combined. My 19" wheels are also heavier than his 18" LTW5 Wheels.
It's nothing that I'm worried about. I've never noticed it until watching this video. The car has a very smooth powerband. Not many people take videos of their speedometer going full throttle to ever notice something like this.
If you want to spend $1200 + on an exhaust for an extra 5-10whp, then more power to you.
      09-09-2012, 12:53 AM   #19
Laid Black 335i
BMW
It sure is a lot of fun and has a lot of torque. But as themyst said, 6AT > 6MT from a roll. If it was a 6AT vs 6AT race, who knows how much bigger the gap would be.
I agree. I have the benefit of living 10 minutes away from Jake@PTF so it would be ludicrous not to get protuned.
It's a custom map for 40% E85.
      09-09-2012, 01:19 AM   #20
Catalina Wine Mixer
Catalina Wine Mixer's Avatar
169
Drives: 09 335i Coupe White/Coral Red
2009 335i  [7.26]
2008 328i  [5.50]
nice man! windows tho roll them up!
| 09 335i Coupe | Alpine White/Coral Red | M Sport | 6mt | Premium | Logic7 | 19" Beyern Mesh | 20% Tint | LUX Angel Eyes | 5000k Fogs | Black Kidney Grill | BMS DCI | Cobb Stage 1 | M-Pedal Set | Painted Side Reflectors | Rear Lip Spoiler | Euro Front Plate | Passport 9500ix | BIM Coded |
Who is John Galt??
      09-09-2012, 01:28 AM   #21
Fully_Bolted
Drives: E92 335i
OP, are you still on stock clutch? I'm assuming that hiccup at 5200rpm is your clutch slipping before 5200, and then catching.
Time to upgrade man
      09-09-2012, 01:47 AM   #22
Beemw335
62
Drives: 335i
Goes to show you how beneficial 6at is.
The at car is runing 16.5 psi and kept up with the mt car running 18 psi.
Nice runs
60-130, cobb 335i, e85, jb4 335i, race
