BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
BPM
      07-31-2012, 05:56 AM   #23
TurboBimmer
TurboBimmer's Avatar
Luxembourg
79
Drives: F82 M4
Originally Posted by radiantm3 View Post
I can attest to that. I guess I just worded my previous comment wrong. I meant braking performance in general and that means at the track as that's the only place where aftermarket brakes will become useful. My stock brakes stopped just as well as my brembo 380 kit. The difference is I can run 25 minute sessions throughout the day in 100+ degree weather without a hint of brake fade.
My biggest fear at the track is having the brakes not working properly when slowing from 125mph to 30 around a hairpin turn with a wall straight ahead. Going from the 365 to 380 kit is just a tiny fraction of the cost of the whole kit so why not get the one that will most likely stand up to heat the best. At least that's my thinking.
Bigger discs will limit the choice of wheels. Not many 18" clear the 380mm kits.
Stopping power will indeed be virtually the same and heat dissipation a bit better with bigger discs. But even the "small" 355 or 365 BBKs will outperfrom any stock setup by a large margin.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
      07-31-2012, 06:47 AM   #24
Malakas
Drives: 2020 M2c
Originally Posted by Porschefile View Post
Does 355/355 feel balanced still? I was worried that if I did 355/355 it would be more rearward biased than it should be.
Even though the kit is 355/355 the piston sizes are different so the standard brake bias is preserved. I spoke with Stop Tech at length about this prior to purchasing. I went with front/rear kit simply to have a good all around solution to combat fade on these relatively heavy track cars. In terms of stopping "power" there is little difference. In terms of brake feel - the ST kit reminds me of my 996 4S which may be mostly due to the stainless lines and fluid...
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before:
2013 - 3.8L GTR, first DCT
2012 - 5.2L R8 v10, 6MT
2011 - 4.0L E92 M3, 6MT
      07-31-2012, 07:34 AM   #25
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Cool, good to know. I hope to get a bbk this fall, almost certainly stoptech.
      07-31-2012, 10:14 AM   #26
aus
Drives: Odysse
Many people who got the ST 380mm front kit got the APEX wheels. Their new wheel will even accept the Brembo 380mm BBK up front now.
      07-31-2012, 10:23 AM   #27
radiantm3
Apex Everything!
radiantm3's Avatar
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
Yea I planned all that out before going with the 380 kit. 18" TE37sl's.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      07-31-2012, 10:45 AM   #28
CSanto
Drives: 2015 BSM/SO M3
I'm pretty much trying to copy everything about your car. I just bought yellow brembos. =)
There isn't a nicer AW on the forum.
      02-21-2013, 04:11 PM   #29
MTROIS
MTROIS's Avatar
France
188
Drives: on the wrong side of the Ocean
I am currently debating on the same items, and after my discussion with Dave Zeckhausen, the following additional advantages of the front ST-40 vs. ST-60 would include:
- ST-40 is lighter (almost 3 pounds for calipers + rotor per corner)
- and you can rotate your pads front to rear if you also install the rear BBK
I am almost set on the ST-40 in the front as I think that the ST-60 is an overkill (given my current driving skills... for sure! One has to be humble....)
2019 M2C MT (ED + PCD) | 2008 M3 Coupé MT | 1995 M3 LTW MT | BMW CCA HPDE Instructor
      02-21-2013, 04:24 PM   #30
uplusd
uplusd's Avatar
Drives: 2013 E92 M3
Go 380
4-piston, 6-piston, alcon, bbk, brakes
m3post
