BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > OBD2 K+DCAN
      02-25-2012, 04:12 PM   #1
ca2del
9
Drives: 2007 330D, 1978 1275GT
OBD2 K+DCAN
Car: 2007 E90, 330D
Problem: DPF warning
I think I've fixed the cause of the DPF failing to regenerate (faulty EGR thermostat causing the engine to run too cool), but now I'm struggling to get the car to regenerate itself.
I got a garage to clear the fault codes (2 for DPF, 1 for exhaust backpressure), but this cost £36. They said they could force a regeneration, but it would cost £250, plus a load of fuel.
Ideally, I'd like to get hold of a cable so I can force a regeneration myself, and it would be a bonus to be able to read the fault codes without a £36 charge each time.
Amazon do a K+DCAN cable, but does anyone in the Cambridge / South area have a cable I could borrow / rent ?
The Amazon unit won't ship for another week or so, and that's a long time to run the car - I imagine the DPF will just keep filling up?
Otherwise, can I buy this cable over the counter somewhere ? or could i modify a more readily available cable to work with this port?
Any help appreciated,
Dean
      02-25-2012, 04:19 PM   #2
Danny.B.
Danny.B.'s Avatar
94
Drives: E90 330d M Sport
Take a quick look at my lastest thread mate. Ive just bumped it to the top with an update.
      02-25-2012, 04:28 PM   #3
ca2del
9
I just noticed - I'd been hoping for an update like that! Thanks
So hopefully, if I was to buy some cleaner *and* clear the code, it might work.
Now... where can I buy a device / cable to clear the code?
      02-25-2012, 05:11 PM   #4
mistryn
mistryn's Avatar
147
Drives: BMW 335D
If you was near west mids and you could install, get the software to work on my laptop you could have borrowed the cable to do what you require
      02-26-2012, 02:28 AM   #5
Danny.B.
Danny.B.'s Avatar
94
How close to peterborough are you? Thats my nearest cambridgeshire location, could meet there and i could clear the code for you
      02-26-2012, 03:41 AM   #6
ca2del
9
I'm about 40mi from Peterborough, so close enough. It'd give the engine time to heat through too...
I'm going to order a cable from ebay, but it'll take a few weeks to get here
I'll need to get hold of a can of dpf-cleaner before the attempt, I think, but it would be awesome if you could clear the code for me!
Dean
      02-26-2012, 03:57 AM   #7
Danny.B.
Danny.B.'s Avatar
94
I did about 40miles with the additive before resetting the code, then did a fair few miles down the a1m aswell seemed to do the trick!
Ill be free this saturday for a short while if your free. I purchased the dpf cleaner off ebay. Took 2days to get here.
This has worked for me (so far! Monday will be a good test) so hopefully it will work for you.
      02-26-2012, 04:12 AM   #8
ca2del
9
In that case, I'll buy the additive today.
Saturday sounds good - I'll make free. PM me with a time / place, and I'll give you my number incase there's any problems.
Thanks again,
      02-26-2012, 07:23 AM   #9
TMP
TMP's Avatar
349
Drives: M6
Out of interest, does that cale also come with the software ?
M2 Arrived!
Family 5er
      02-26-2012, 08:57 AM   #10
ca2del
9
Yes.
It's on ebay, and the seller even suggests he sends the software first to check compatibility.
      02-26-2012, 10:46 AM   #11
buckethead
buckethead's Avatar
24
Drives: e90 320d msport
one of the 1st things to try is to go for a clear motorway drive
to make the 3.0d work hard enough its got be over 80+mph for 40 miles plus
the idrive will ping, if the dpf clears
      02-26-2012, 10:47 AM   #12
mistryn
mistryn's Avatar
147
Drives: BMW 335D
Originally Posted by ca2del View Post
Yes.
Thats the very same seller I have bought my cable from and having issues installing the software
      02-26-2012, 12:09 PM   #13
Danny.B.
Danny.B.'s Avatar
94
Dean try this first, i had originally done a 70mph cruise for near on 100miles. I only went to 80 in 6th once i had the dpf cleaner in the system, so its hard to say which of the two did indeed work.
      02-26-2012, 03:29 PM   #14
TMP
TMP's Avatar
349
Drives: M6
Yes.
Cool, and daft question No.2 - apart from clearing fault codes, what else can this do - look at live stats, or just set coding up?
M2 Arrived!
Family 5er
      02-26-2012, 04:07 PM   #15
makkan00
makkan00's Avatar
886
Drives: F83 and F36
It can read and delete the code.
It can also read live data.
If it is only inpa, it cannot set codings on your car. However you can search some softwares online, and use the same cable to do coding. However you should know what you are doing with coding, and its geek thing, not very user friendly.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      02-26-2012, 04:21 PM   #16
ca2del
9
I'm tempted to wait for the DPF cleaner to arrive before going for another run, especially if it's 40+ miles at 80+ mph... I really don't know how many of these runs I'll be able to do before the DPF is completely full.
Which cable / software combination do I need to be able to force a regeneration?
Is that BMW DIS? Would the cable I posted above work for this software?
Thanks for the comments,
Dean
      02-27-2012, 01:04 AM   #17
AlwynMike
337
Drives: F36 440i GC.
The software can be a real camel to get set up, and it's a long-winded process. A decent eBay seller should provide a good walk-through.
I did a clean XP install on a new hard drive for my laptop, so the risk of any conflicts was at a minimum.
INPA is easy to use, if clunky and basic looking.
DIS is the one, but running Virtual Machine (VM) makes my laptop perform like it came out of the Ark, and not at all user friendly. DIS itself is very comprehensive. I've not tried any coding - and don't intend to, but it was good at faultfinding on my 530d. INPA read codes and frightened me because there was so many, but after reading them, they were all relatively minor (glowplugs weak etc).
Mike
      02-27-2012, 02:21 AM   #18
ca2del
9
Is DIS free?
I'm installing a VM now, so I'll try running the INPA software I got from the seller.
Cheers Mike,
Dean
      03-04-2012, 10:59 AM   #19
ca2del
9
Yes.
Mistryn, did you manage to install the software yet?
His guide skips a couple of important steps - if I wasn't a systems administrator, I doubt it would be fun to install :-/
      03-04-2012, 11:06 AM   #20
mistryn
mistryn's Avatar
147
Drives: BMW 335D
I am trying attempt (enter rude word) however number of time (lost count). I have tried to install but when it gets up to where you have to change value in notepad I am lost. I have tried to carry on and plug it into my car and not much happens.
So I emailed the seller and he sent me out a 3 DVD software which takes about 35GB hard drive sapce. I have tried to install that but again I got halfway thorugh the instructions (55 page pdf file) and says to try it in the car which I did but nothing happens - I am at this stage of giving up and trying another day.
I may buy a cheapo laptop to run this from because at the moment I am installing this on my main laptop and need the disk space and cant afford for it to mess up
If anyone has installed this and fancy installing it on my laptop for some beer tokens please contact me
      03-04-2012, 12:17 PM   #21
makkan00
makkan00's Avatar
886
Drives: F83 and F36
I have installed inpa and DIS on i7 and DIS (due to virtual machine) messed up my laptop.
It made booting very slow. And one day, it lost the win 8.
So back to win 7 on i7.
Just bought old laptop with XP and installing all those on that.
It is a lot better to play with old laptop (though very slow).
I think you start with inpa first and once you get that working move on to next one.
      03-04-2012, 12:23 PM   #22
mistryn
mistryn's Avatar
147
Drives: BMW 335D
I am having trouble installing inpa, I will definatly get anothet laptop.what does it mean by virtual machine?
code, dpf, k+dcan, obd
