335i misfire? jb4 g5
03-17-2013, 09:29 PM | #1 |
Rep 24
Need help.. Car is a 07 e90 335i sedan w/ sport package.
I have JB4 G5 and DCI on my car that i installed a couple weeks ago. Did a wot run on the highway tonight and "service engine soon" light came on. Car felt like it was misfiring (shaking at idle like it's going to stall) and was jerking every time i gave it gas (while driving it).. Hear some rattle from the engine bay, exhaust popping at idle.. Restarted the car twice, one time it struggled to start.. All that did was make the "service engine soon" light go away. Car has CPO so just might remove tune and intake and take to BMW.. Any thoughts what it could be??? |
03-22-2013, 09:27 PM | #2 |
Rep 4
disconnected/cracked charge pipe or intercooler tube would be my educated guess. I'd start with the charge pipe since it seems to be a "common problem". The misfire symptom would be a result of a false reading from the afm because of a air leak from the crack or disconnection. If you are raising boost levels above factory spec you should invest in an aftermarket charge pipe anyways. If this isn't the problem now it will be eventually. Take it for what its worth as this is my first post.
04-02-2013, 02:48 PM | #4 |
Rep 3
im having this same problem but all i have is AFE intakes. No other mods Mt, 07,69k havent done the plugs yet planning on doing them soon. no idel problem though... any thoughts?
04-02-2013, 03:02 PM | #5 |
3441
Rep 79,212
Drives: C6 Z06, 09 335i, 10 335xi
04-04-2013, 10:47 AM | #6 |
14
Rep 239
misfire
i was running jb4 g5 map2 and started getting misfires. plugs fixed the problem for me.
2009 n54 e90 / Sport Pkg (ZSP) / Premium Pkg (ZPP) / black sapphire metallic / Logic7 / AMS FMIC / BMS 3" DP / BMS OCC / Alpina TCU Flash / ER CP + ForgeDV / Cobb
335i, e90, jb4, misfire, n54 |
