Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > OBDII Readout Question
      03-14-2011, 07:51 PM   #1
Lotus7
Drives: xxxx
Has anyone had any experience trying to read engine or vehicle data from a N55 engine BMW OBDII port?
I want to add a constant readout of the turbo boost pressure and thought the “ScanGaugeII” <http://www.scangauge.com/> would possibly be an ideal way to do that. The issue is, does the X3 report the MAP level on the OBDII port. According to Linear Logic (the ScanGaugeII manufacturer), only about 50% of vehicles using MAP sensors will respond to a request for a MAP readout. The ScanGaugeII is programmable for scaling and offset, so it will have no problem converting a MAP reading to a true “boost” reading, IF it’s available.
Linear Logic has had no experience with N55 engines, so doesn’t know if their gauge will provide this function on a new (2011) vehicle.
The question is: Has anyone tried a scan tool on a N55 equipped BMW, and if so, does the port respond to a request for a MAP reading?
The vehicle in question is actually a (F25) X3 35i. I posted this on the X3 forum, but I think the typical X3 forum member is less technically savvy and probably doesn’t know a OBDII port from Obi Wan Kenobi.
boost gauge, digital readout, obdii
