Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Square setup on E92
      07-13-2010, 05:17 PM   #1
dgbuilder
Drives: 2009 335i xDrive E92
Square setup on E92
Tried searching for this but not seeing a concentrated volume of this specific topic.
I am hoping to find the widest tire/wheel combo(s) that people have actually fit on an e92. Post sizes of your wheels (diameter x width +offset) and tires. Include if you rolled fenders or not. Pictures are appreciated.
Much obliged. DG.
      07-14-2010, 03:18 PM   #2
marcel b
marcel b's Avatar
132
Drives: F31 340i
265 square on 9x18 ET23 front and 35 back with -2.8 degrees camber in de front lowered pn KW clubsport. search for "265 square fit" and you find my post with pictures.
      07-14-2010, 03:21 PM   #3
dgbuilder
Thanks, marcel_b, for the info. May I ask what weels they are (on my way to check your thread at the moment - excuse me if the answer is there...) DG.
EDIT: Got it, thanks!
      07-14-2010, 07:11 PM   #4
Stanky19
Friends don't let friends early apex!
Stanky19's Avatar
Drives: "The Turbo Schnitzel"
2007 E92 335I  [0.00]
i am on a stock zsp suspension (and alignment), with 19 x 9.5 +33 square VMR V701 on 255's all the way around, and the only rub i get is a slight cosmetic one on the right front inner fender at parking lot speed (less than 10 mph) with full lock to the left. It's so light you almost don't hear it.
The balance of the car however...... she's dialed. E92's need a square set up, the car is close to 50/50 weight balance, so logically it makes sense you'd want similar sized tire front and rear. Turner and Dinan do it for a reason!
07 Space Gray E92 335i "Turbo Schnitzel"
Wavetrack LSD, KW V3, M3 Aluminum Arms, E93 M3 Front Sway Bar, Dinan Toe Link, Catless DP's, AE Quad Exhaust, DCI, Vishnu PWM Meth, Vishnu V2.5 440whp/460wtq (stock cats)
      07-15-2010, 01:41 AM   #5
marcel b
marcel b's Avatar
132
Drives: F31 340i
I have some rubbing with 265 square, but just with full lock when parking, not a big issue. The rubbing is in front of the fender (so not because of compression).
With 255x35x18 square, which I use in summer, I have no rubbing what so ever.
I totally agree that the E92 needs a square set-up. The car behaves so nice, so neutral to slightly oversteer which is great for turning. Understeer is gone!
      07-15-2010, 12:06 PM   #6
dgbuilder
Love the look of the V701s Post some pics of your setup.
What tires are you running? Thx. DG.
e92, square
