BMW M3 Forum (E90 E92)
BPM
      09-19-2014, 03:32 AM   #23
SenorFunkyPants
SenorFunkyPants's Avatar
2511
Drives: 2019 M5
Yeah I know it seems counter intuitive.
On dry tarmac during braking the maximum friction between the tyre and road surface develops when the tyre is rotating at around 80% of road speed - ie slightly skidding.
If you hit the M3s brakes at 62mph and pressed as hard as you could, the ABS system would activate and hold the tyres at the preset slip rate (~80%) for maximum deceleration and you stop in 34.1m.
Repeat the test with a passenger (adds 200lbs), hit the brakes, the ABS activates , the tyres are held at 80% slip and your stopping distance will be the same at 34.1M.
The only way that adding weight to the M3 would make the braking distance longer would be when the ABS could no longer make the tyres brake at the optimum slip rate (all else being equal).
Note that a little VW Polo brakes from 62mph in the same distance as the M3 and the Porsche GT3 at 34.1m...braking is not really about weight and brake disc size (within reason) - but mostly about the tyre compound and the force pushing it into the tarmac. You can strip out weight, throw whatever brakes you like at a car but if its on road tyres the best you can hope for is a little over 1g in deceleration.
The other part of braking is the disc hardware. Braking a car is the conversion of kinetic energy into heat. A moving vehicle has energy calculated as KE=1/2mv^2 (a half of the mass times its velocity squared). When you brake, the pads press against the disc and the friction produces heat which is removed by the air flowing past the disc. The discs themselves have a "thermal capacity" which basically means the amount of heat that it can hold. Imagine them as being a bucket with holes in the bottom - as you brake the discs fill with heat which drains out of the bottom, if however you keep adding more and more heat (repeated hard braking at a track, driving down a mountain on the brakes) the bucket fills up with heat faster than it can drain out of the bottom and the whole system starts to overheat and you get brake fade. Which is why bigger brake kits are fitted by people who track their cars - its to handle the extra heat, by having brakes with a bigger thermal capacity and better cooling (bigger bucket with bigger holes). The alternative would be to improve the cooling to the standard brakes - the effect would be the same.
      09-19-2014, 01:46 PM   #24
White 13
42
Drives: A 2013 Alpine White E92
I can believe most everything you say above makes sense. Except I still can't see why more weight won't add to stopping distance. Perhaps adding 200 pounds wasn't enough to measure. What would happen if 1000 pounds were added?
Do you have a reference for your information, I would be interested to read it? I looked for the above article but can't find it.
      09-19-2014, 01:57 PM   #25
Hujan
Hujan's Avatar
Drives: M3
If weight were not relevant to braking distance, then all cars would have roughly the same size brakes except for applications where heat build up is an issue. And yet, SUVs and heavy vehicles tend to be fitted with very large brakes.
Brakes have to overcome inertia. Inertia is a function of speed and mass. The coefficient of friction of the two surfaces (tire and road) is a factor, but so, too, is weight. This is basic physics:
http://www.physicsclassroom.com/clas...ertia-and-Mass
All objects resist changes in their state of motion. All objects have this tendency - they have inertia. But do some objects have more of a tendency to resist changes than others? Absolutely yes! The tendency of an object to resist changes in its state of motion varies with mass. Mass is that quantity that is solely dependent upon the inertia of an object. The more inertia that an object has, the more mass that it has. A more massive object has a greater tendency to resist changes in its state of motion.
      09-19-2014, 04:18 PM   #26
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
The weight change isn't going to make a difference. If an M3 stops from 60mph to zero mph in 34m, with all else being equal if you removed 100lbs of weight, the M3 would still take 34m to stop.
Fitting Brembos will not change the braking distance (single stop).
A small change in the tyre size will not change the contact patch by any significant amount.
A small change in front suspension settings will not affect the braking distance - in fact a more track oriented set up would probably make it worse.
A "stickier" tyre compound would shorten the braking distance.
An increase in load on the tyre (reduced lift/increased downforce) will shorten the braking distance.
Optimising the ABS for shortest braking distance will unsurprisingly shorten the braking distance.
Weight carries major relevance to braking distances. It's physics (1st and 2nd law). Having a 255 wide tire in comparison to a 245 tire, There is approximately a 5% difference in the width of the contact patch as well as a change in tire friction coefficient. Better calibrated dampers combined with wider tires will equal to better stopping distances, as reduced weight transfer will reduce load on the front tires. Lower vehicle weight will also affect weight transfer characteristics.
It's true if the car has zero toe or toe out, it could worsen braking performance due to suspension geometry and added deflection and in turn reduce the tire contact patch while going straight, but both the regular M3 and GTS are toe-in at the front suspension.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      09-19-2014, 04:35 PM   #27
SenorFunkyPants
2511
Drives: 2019 M5
Yes a heavier car will have more Kinetic energy (or momentum if you prefer) so the brakes will have to do more work to stop it at the same deceleration rate as a lighter car but as long as its within the ability of the ABS to work as designed then the stopping distance will be the same...otherwise little lightweight cars would stop in a much shorter distance than heavy ones yet the stopping distance from 62mph for a typical 850kg small car is little different to that of a 1700kg M3.
Look at the braking distance for any modern car (with decent brakes) and the very first thing you will see is that the typical 60-0mph braking distance is consistently the same (within a small margin) regardless of vehicle weight.
      09-19-2014, 10:20 PM   #28
White 13
42
Senor,
I think you are focusing on the ability of the brakes where I am talking the ability of the tires to bring the car to a stop. I am assuming most cars have the ability to lock the tires or activate the ABS for at least one "panic" stop.
Lets forget about various ABS setups and different cars for a minute just to make a apples to apples comparison. If my M3 did one stop, full ABS, at minimum weight then with the same conditions tried it again with max weight shouldn't it take a longer distance to come to a stop?
I hope I am not coming off a antagonistic. One of the reasons I am interested in the topic is I think you have Ross Bentley (Speed Secrets) on your side and I could not figure his point either. At any rate for me it is a fun discussion.
      09-20-2014, 07:12 AM   #29
SenorFunkyPants
2511
Drives: 2019 M5
As I understand it the distance should essentially be the same up to a point. Extra weight will have an effect on the shape of the contact patch and how it interacts with the road surface - there is a weight on a tyre's contact patch which gives the optimum pressure (per unit of area) pressing the tyre against the road surface which then produces the maximum grip (the complex interaction between a braking tyre and the road surface is a book in itself). In principle extra weight on a tyre produces greater grip if the tyre is designed for it - think F1 where a car can brake at up to 6g at 220mph due to the tonnes of downforce produced by the cars aerodynamics. How extra weight would affect the tyres on an M3 is unknown but I suspect the tyres have quite a wide operating window. There will be also a crossover speed at which the min weight M3 can still fully activate the ABS down to 0mph while the max weight M3 will not be able to - pick a speed 150mph? I don't know...whatever that speed is, its the moment that a big brake kit would make a difference.
Absolutely...I think I am right but I if I'm wrong I would rather find out so I'll know better for next time. Discussing and learning stuff is the best part of M3post.
      09-20-2014, 05:59 PM   #30
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
I think it is waste of money putting a BBK if you do just one club track event a year. Visually it would be great and will give you bragging rights but much lighter in your wallet. I think for street driving the standard breaks are just perfect. Keep the money because you will need to spend if you happen to keep this car for a long time.
F86 X6///
      09-21-2014, 10:03 AM   #31
Hujan
Hujan's Avatar
Drives: M3
Stopping distances for light cars would be shorter than those of heavy cars assuming everything else stayed the same. But they don't; little cars have puny brakes while big heavy ones have bigger brakes. Do you really think a Chevy Suburban would stop in the same distance as a Toyoyta Prius if using it was using brakes from a Toyota Prius?
      09-21-2014, 10:30 PM   #32
White 13
42
Looks like we have too many variables to ever get to apples and apples. I guess I am going to have to find that book on tire grip and read it.
Thanks
      09-22-2014, 04:33 AM   #33
SenorFunkyPants
2511
Drives: 2019 M5
I very much doubt it would...but thats because the Prius brakes would be too small to stop a much heavier car, not because heavier cars take longer to stop.
It is true that lighter cars are *easier* to stop, you can use smaller brakes and tyres, the brakes need to do less work, they produce less heat and the tyre contact patch will tend to deform less under hard braking than a heavy car. Yes top of the braking list will always be cars like the 500kg Ariel Atom track car on road legal track tyres - but only a few meters behind will be near 2 ton performance Mercedes and even a 2.3 ton Bentley Continental can stop in a staggering 33 metres from 60mph.
The principles always remains the same, its the friction produced between the tyre and the road surface that determines the stopping distance all else being equal. If the brakes can hold the tyre at the optimum slip rate and the tyre friction coefficient is unchanged then adding a few hundred lbs of weight will not make a difference to stopping distance.
Take an otherwise standard M3 and put on a set of carbon ceramic brakes from a Mclaren P1. Make a stop from 60mph. Add 300lbs and make another stop from 60mph.
The brakes are surely easily up to the job of stopping the car, the weight difference is not sufficient to put the tyres outside of their operating range so what mechanism could be occurring that would cause the stopping distance to change?
      09-22-2014, 11:31 AM   #34
Hujan
Hujan's Avatar
Drives: M3
Let's try it this way: Assume an infinite length straightaway. Two identical trucks take off at the same time, reach 80 mph in the same distance, shift into neutral, and then coast to a stop without hitting the brakes. The only difference is that one of the trucks is loaded with four tons of cargo. Which one will come to rest sooner than the other?
      09-22-2014, 03:19 PM   #35
SenorFunkyPants
2511
Drives: 2019 M5
See
http://hyperphysics.phy-astr.gsu.edu/hbase/crstp.html
Its not that heavier cars stop in the same distance just that the brakes need to do more work to make them stop in the same distance.
Also
http://en.wikipedia.org/wiki/Braking_distance
      09-22-2014, 10:49 PM   #36
Hujan
Hujan's Avatar
Drives: M3
See
Also
That the brakes might be able to overcome the effect of additional weight in order to stop the car in the same distance as it would without the weight, does not mean that weight has no effect on stopping distance.
I sense that you and I actually agree: For the most part, the chief limiting factor on stopping distance is friction, as a factor of the tire (or "tyre") grip and the road surface. Most cars are built with brakes that have ample extra braking force, so that if you load the car with passengers or cargo, the braking distance will not suffer much if at all (assuming similar surfaces and tire conditions).
But as you pointed out, the brakes have to do more work to stop a car that weighs more. This work will translate to additional heat, which will cause the brakes to heat up faster than those same brakes on the same car but with less weight in that car. (The same would be true of the cars, tires, and weights were the same, but one car was traveling 80 miles an hour faster than the other car when the brakes were applied.) The extra heat starts to build up on the track and braking distances will start to grow.
It's probably true that additional weight will not increase stopping distance significantly if at all in a single-stop scenario, assuming dry tarmac and good tires. But this is because cars are built with ample braking capacity, not because weight has no impact on braking distance.
As the Wikipedia page you linked to said, the vehicle's mass is a critical component of the stopping-distance formula:
The theoretical braking distance can be found by determining the work required to dissipate the vehicle's kinetic energy.
The kinetic energy E is given by the formula:
E=\frac{1}{2}mv^{2},
where m is the vehicle's mass and v is the speed at the start of braking.
      09-23-2014, 02:39 AM   #37
SenorFunkyPants
2511
Drives: 2019 M5
Ah OK so we are not that far apart at all.
Interestingly an M3 can stop from 100mph in a little over 4 secs. Turn that round and consider how many BHP you would need to accelerate a 1700kg M3 from 0-100mph in 4 seconds...I'm guessing easily over 1000bhp. That indicates how just much work the brake system has the potential to perform. Braking from 60mph is hardly stretching them at all...the brakes are only handling a quarter of the kinetic energy a car has when at 120mph.
      09-23-2014, 08:15 AM   #38
Richbot
Drives: Jerez Black E90
The answer to this question is excellent ABS calibration and Michelin PS2's, which when the M3 came out were the best all-around street tire available, and still were right up until the PSS came out. Top performers as street brakes yes absolutely. Most people here want more.
brakes, brembo, stock
m3post
