Rusty Wheels!!
02-25-2009, 04:25 PM | #243 | |
Lons
10
Rep 383
I'll def try that approach at the weekend. Called at the dealer today and got hold of the service manager. Very helpful but tried to tell me that it was the salt on our roads! Backed off when I said it was b*llocks and eventually admitted that they were well aware of the problems and personally he had attended rescue callouts and been embarrassed "on more than one occassion" when they couldn't remove a wheel at the roadside. Confirmed BMW aren't interested despite pleas from the dealerships to at least factory grease the hubs to stop sticking and wouldn't accept warranty issues. He offered to clean the hubs as goodwill if I booked the car in which I declined (60 mile round trip) as that wouldn't solve the problem - so will do it properly myself. I checked the forecourt and loads of similar rust evident. Ah - well............................... SO-Yank Can get dead blow hammers in uk - I'll try to remember where I've seen them but probably just need a builders 2 or 4lb club hammer and a block of wood.
02-25-2009, 04:40 PM | #244 | |
Lons
10
Rep 383
http://www.toolshopdirect.co.uk/item...oogle/sn/69773 http://www.axminster.co.uk/product-A...mers-22790.htm http://www.toolfastdirect.co.uk/acat...w_Hammers.html Loads more if you google it
02-26-2009, 04:07 PM | #245 |
Rep 7,519
Drives: 2009 E90 335i MT
I already have a Draper DB hammer. I was stating that is a useful tool to have for removing the wheels. I'll bring it to UK7 next weekend.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-26-2009, 05:58 PM | #246 | |
Lons
10
Rep 383
I can't be at the meet but I might buy one as they aren't expensive. Just posted the links in case anyone else was interested
05-11-2009, 03:35 AM | #247 |
Rep 81
Hi. I've been checking this thread out for a bit now. I finally took the plunge and did the hubs on my X5 which were in a pretty poor state. (Not as bad as the 335 which is 2 years younger.) I used the Hammerite Silver Smooth after wire brushing and sanding off. Took the opportunity to clean out the inside of the wheels with Wonder Wheels as well. Result is pretty good and much better than before. I'll post some pics later. Now I just need to get round to doing the 335, which is more difficult since it doesn't have a jack! Luckily the X5 one has the same top, but is hard to use as the 335 is so low that the jack is still spread right out.
One thing tho, I didn't need a dead blow hammer, the back of a long handled axe worked a treat for beating the wheels off!
Cheers,
Oscar |
05-11-2009, 09:06 AM | #248 |
Rep 81
Hi, thought I'd post some pics of the X5 wheels that I have had a go at before I fix the 335d.
Picture of the rusty culprit (This is 335d not the X - forgot to do a before and after!) and then two that I have done. On reflection my preparation could have been better but that is why I tried it out on the X first! Still much better that before. Thanks for the advice on here.
Cheers,
Oscar |
05-17-2009, 03:22 PM | #249 |
Zummerzet Zyder Drinker!
111
Rep 5,541
Drives: '06 330D Le Mans Blue
This wheel/hub corrosion isn't just affecting BMW vehicles - it is an industry-wide problem.
Any decent service-workshop will clean and lubricate the hub mounting flanges at service time - but the trouble is, with large open alloy wheels, the brake linings etc can easily be seen without removing the wheels - adding to the problems. I think I'll do the hub painting exercise next weekend, looks really smart.
05-17-2009, 03:30 PM | #250 |
111
Rep 5,541
That's exactly what I use, never fails and isn't too harsh.
05-24-2009, 09:29 AM | #251 |
111
Rep 5,541
Just done my disc bells - which were quite rusty seeing as though they are newish BME brake discs!
Before and after..... Would have loved to have done the calipers in a light gold like MattinOz did, but it was simply too hot out there today (Well that's my excuse!) Going to get some new wheel centre trims - these are a bit corroded.
05-24-2009, 09:51 AM | #252 |
Rep 7,519
That looks great, Doc. How long did it take? What paint did you use?
05-24-2009, 10:37 AM | #253 |
111
Rep 5,541
Took about an hour....tools needed were a 17mm socket & breaker bar, jack, wire brush and screwdriver.
Hammerite smooth was what I used; the smallest pot would have done the job - the middle sized pot I got would do about 20 cars!!!
05-25-2009, 06:26 PM | #254 |
Rep 9
Did my hubs and calipers for a second time today on my e93.
Cleaned rust off with wire brush attachment to drill, and similar attachment on a dremel for the fiddly bits. 2 coats of primer and 2 coats of high temp satin silver. Great end result. Same problem with sticking hubs as a few of you folks.I jack the car up, leave 3 bolts in, undo 2 turns and drop the jack very gently, that frees them a treat. |
05-26-2009, 12:28 AM | #255 |
111
Rep 5,541
I would liked to have done my calipers at the same time but 'er indoors wanting to go to the garden centre/mothers/friends house* curtailed my "car time"
* delete as you see fit!
06-21-2009, 12:56 PM | #256 |
Rep 7,519
Did my rear hubs yesterday and the fronts today; front left still needs the second coat shortly. I used Hammerite Smooth spray and it was a b***h. Did you know the distance from the brake pad to the rotor is less than the thickness of masking tape? I ended up making a carboard mask so the rotors could be rotated to get all around the hub.
Also took the opportunity to clean the insides of all the wheels. I might take a hack at painting the calipers next weekend, weather permitting. I'm thinking about black. Anyone have any advice on that other than not to paint the pads?
06-21-2009, 01:10 PM | #257 | |
Moderator
322
Rep 5,493
Yes, the spray is a bitch as the masking is a bit tedious. But the finish is excellent! Don't paint the calipers yet - do it later on when you're down this way, if you know what I mean...!! And again, leave the fronts...?!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
06-21-2009, 01:41 PM | #258 |
111
Rep 5,541
Spraying the hubs must be a right bitch! Painting with a decent brush with smoothrite silver gave an more than acceptable finish in about 10 mins tops.
Calipers? I'd mix a little silver & gold together to give that plated "new" look. Someone here did that and it looked the dogs. Black calipers? No way! Silver or silver/gold every time.
06-21-2009, 03:53 PM | #259 | |
Rep 7,519
hubs, rust, wheels |
