proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      05-22-2013, 12:35 PM   #23
ATX78703
Drives: 2014 335i
Originally Posted by Remonster View Post
If they're making 420 horsepower at 8,000RPM then torque will be at 275lb/ft at redline. 420 horsepower at 7,500RPM translates to about 295lb/ft at that same RPM. If the horsepower and torque figures we've been hearing turn out to be correct, then this motor will be losing power quickly as you approach redline (like the current N54/N55 but I expect an M motor to have a better power curve). If you compare that to the power curves for the current S63tü, it makes almost 80% of its peak torque at redline while these rumored power figures would mean the S55 in the new M3 will barely make 70% of peak torque at redline so I still believe the real horsepower figure will be higher than 420, despite the rumors. We'll see.
The amount of torque you make after 5252 rpm is irrelevant. there's nothing gained by making a higher percentage of peak torque at redline.
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
      05-22-2013, 12:37 PM   #24
AlpWhite11
Drives: 335i
Originally Posted by s62
I reverse-engineered the numbers to match the 415hp and the ~395lb-ft claimed figures. Assuming a redline of 7500 to 8000 and a power curve that looks similar to the one of the S63tu, I came up with the following output.
To me at least, it appears that all surmised numbers could very well be the nearly whole truth
Of course, max torque would be converted from NM so here are other possible torque values:
540NM = 398.28lb-ft
535NM = 394.59lb-ft
530NM = 390.90lb-ft
520NM = 383.53lb-ft
But with playing the above and the RPM one can easily hit the desired hp output
Thx for sharing your analysis. I believe these numbers.
The admins and mods here report solid info.
      05-22-2013, 12:37 PM   #25
Karazy
Go Fast And Take Chances
Karazy's Avatar
Drives: 2020 M2C
I hope your right on the horsepower. Common M, lets see 450 HP / 400 lb-ft AND nearly an 8K rpm's!!
I'm still drooling on the new C7 Stingray...
2014 Corvette Z51 Stingray 3LT, 7 M/T
2015 KTM 1290 SA
Retired- 11 BMW 335, 07 BMW R1200GSA, 04 BMW Z4, 01 BMW K1200RS, 00 BMW R1150GS
      05-22-2013, 12:39 PM   #26
NAV8TT
NAV8TT's Avatar
Drives: 2013 ///M3 E92 DCT ZCP
This car needs a lower suspension
      05-22-2013, 12:51 PM   #27
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
I really don't like the hood on the 3 series 4 series form the front 1/4 view. It looks really high.
Car on the whole looks mean
      05-22-2013, 12:54 PM   #28
Longboarder
Longboarder's Avatar
3430
Drives: 2016 BMW i8
lol. 100% incorrect.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      05-22-2013, 12:56 PM   #29
jayzi
Drives: Ex E30 318is
Are these real LED headlights?
      05-22-2013, 12:57 PM   #30
solstice
Drives: 2015 M3 6MT
My first thought exactly.
The bad: the big wheel gaps and ground clearance can signal EDC with a soft comfort mode that requires long springs and the sporty setting is all electric dampers stiffening which I personally don't think feel as natural and dynamic as stiff springs.
The good ( very good ). The gaps are large even on the outer side, away from the curb when cornering. That is one stiff suspension, whoa.
I hope we get the choice of a passive sports only suspension.
      05-22-2013, 12:59 PM   #31
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Yes.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      05-22-2013, 01:02 PM   #32
Boss330
Boss330's Avatar
1712
Drives: BMW
Considering that it seems like BMW is typically stating HP lower than it's in reality, don't be surprised that the next gen M3/M4 has 450HP...
I recently read an interview with someone from BMW that explained that their HP claims was given for a "worst case scenario" situation (like bad fuel, hot weather, high altitude, humidity etc).
BTW. Next years F1 engines will be 1.6l turbocharged engines with a lot higher rev limit than 8000rpm...
      05-22-2013, 01:04 PM   #33
ATX78703
Drives: 2014 335i
not really, but say what you want. engines can achieve the same goal in different ways. only thing that matters is moving the axle.
      05-22-2013, 01:04 PM   #34
Tĺst
Tĺst's Avatar
Drives: BMW, I think.
Nearly 8000rpm means, that engine is heavy modified N55, not badge tuning.
....Mclaren Mp4 3.8L tc V8 revs 8500rpm.
      05-22-2013, 01:09 PM   #35
Dan Parker
Drives: 2012 Golf R
It's no Cadillac...
Dan Parker
      05-22-2013, 01:15 PM   #36
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Added more shots:
Latest M4 Coupe Prototype on Nurburgring - in Silverstone II
      05-22-2013, 01:17 PM   #37
Jblack4083
Drives: E46 ///M3 JB/CB
I'm still not convinced by this 420hp figure. I know the horsepower wars are ending but 420 would seem to almost put the M3/M4 downmarket unless there is a combination of weight loss on the order of 150-300lbs and extensive chassis tuning (differential, custom tires maybe?)
      05-22-2013, 01:20 PM   #38
CanAutM3
General
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
This is incorrect. Usually, the higher the percentage of peak torque is produced at redline, the higher the power output of an engine.
And power best indicates the capabilites of an engine .
      05-22-2013, 01:20 PM   #39
CanAutM3
General
CanAutM3's Avatar
21115
540NM = 398.28lb-ft
535NM = 394.59lb-ft
530NM = 390.90lb-ft
520NM = 383.53lb-ft
Nicely done
      05-22-2013, 01:22 PM   #40
solstice
Drives: 2015 M3 6MT
This car will be a looker for sure. Dang, those two pix of corner entry from the front are HOT.
      05-22-2013, 01:29 PM   #41
Boss330
Boss330's Avatar
1712
Drives: BMW
Interesting article on the McLaren MP4-12C on the dyno and with power curves.
http://www.edmunds.com/car-reviews/t...no-tested.html
As can be seen on that engine, it's possible to combine high end power, high rev limit and turbocharging.
Interesting overlay of power curves for the McLaren, Porsche 911 GT2 RS and Lexus LFA:
      05-22-2013, 01:31 PM   #42
ESC OFF
ESC OFF's Avatar
40
Drives: 1M, CaymanS, 914, 500 Abarth
Originally Posted by Dan Parker View Post
It's no Cadillac...
....and no matter how hard it tries, it never will be....
The faster you go, the better it feels
      05-22-2013, 01:38 PM   #43
GOLFFRR
GOLFFRR's Avatar
10802
Drives: GOLFFRR cart
I was under the impression the coupe and the sedan would be released at the same time?
are those dates confirmed or just estimates?
either way pretty exciting. I am really looking forward to seeing how they can improve over the e9x. The e9x is such an awesome car. I can't wait to see this unfold!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      05-22-2013, 01:42 PM   #44
burrito007
93
Drives: e46 M3
Originally Posted by Gjm127 View Post
Nothing is new here except for the doubtful 8k rpm red-line which to me sounds impossible with that many turbos attached to an I6 that boasts around 415HP and 400 lb.ft torque..
If that's true, I'm all for it, I guess they're trying to make up for loss in the capability of a high-reving V8..
edit: E46 M3 had an 8k RPM redline too, my comment is flawed lol
But you are correct about the HP/TQ comment. That tq curve is going to have to be ^ instead of a nice flat curve. remember the e46 m3 only had 262 tq right up to around redline and it made 333 hp. for power to be 415 at redline, the tq will only be in the 300s.
if this is all TRUE - the car will be a real monster when tuned to hold boost to redline - we are talking 600hp.
2014 bmw m3, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m3 weight, 2014 m4 engine, 2014 m4 weight, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m3 engine, 2015 m4 engine, 2015 m4 weight, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 s55, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 s55, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 s55, bmw m3 s55 engine, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, bmw s55, bmw s55 engine, bmw s55 motor, bmw spy, bmw spy photo, bmw spy photos, bmw spy pic, bmw spy pics, bmw spy video, bmw spy videos, f80, f80 forum, f80 forums, f80 m3, f80 m3 engine, f80 m3 forum, f80 m3 forums, f80 m3 motor, f80 m3 s55, f80 m3 sedan
f80post
