06-27-2014, 05:31 PM | #46 | |
70
Rep 116
So with a 6 speed, ceramics, leather, and 19s care to throw out a possible weight?? |
06-27-2014, 05:31 PM | #47 |
10775
Rep 27,587
Awesome!!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
06-27-2014, 05:37 PM | #49 | |
Moderator
617
Rep 10,855
Wheel Horse Power is what you get measured from a dyno that is actually powered by the driving wheels of the car. Horse Power (and BHP) are measures of power taken directly from the engine (flywheel). WHP is expected to be about 10-12% less than HP because of inherent losses in the drivetrain. So... 425 WHP translates to about 470 HP.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
06-27-2014, 05:37 PM | #50 | |
Rep 4,981
So if BMW says crank HP is 425 and we are seeing 425 WHP, you can do the math. edit: and @stressdoc beat me to the punch PS: Correct me if I'm wrong but is crank HP and BHP interchangeable? I'm fairly certain the mean the same thing. |
06-27-2014, 05:45 PM | #52 | |
Moderator
617
Rep 10,855
06-27-2014, 05:46 PM | #53 |
471
Rep 2,991
Looks like there will be a use case for water wetter or an upgraded exchanger... that said, the exchanger will get more airflow on the street, assuming EAS doesn't have a full on wind tunnel.
06-27-2014, 05:51 PM | #54 |
120
Rep 374
Not to beat a dead horse and I know it's the stock exhaust, but I'm still not feelin' the sound.
It's quiet, then gets louder, then starts to taper off again...all in the same gear. Otherwise, the weight plus underrated motor make this a definite performance improvement over E9x models. My E92 with a full tank of gas came in at 3,524 pounds. |
06-27-2014, 05:53 PM | #55 | |
Rep 826
I mean, comparing a stripper e9x m3 tha tis light to a f8x M3 with Carbon ceramics is whatever.... I wanna see a f8x stripper weight
Check out my YouTube Fitness Channel if your into that https://www.youtube.com/channel/UCoz...XQVuG0se8cTpUQ |
06-27-2014, 06:04 PM | #56 |
Rep 1,192
Drives: 2011 335i MT
I just got the latest Motor Trend mag in the mail and the M3/M4 are on the cover. Very positive review, "the M3 and M4 are ... extremely focused and astonishingly fun to drive."
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
06-27-2014, 06:08 PM | #57 | |
Rep 10,407
In short, a loaded car with DCT significantly outperforms a stripper with MT (regardless of and small savings from CSiC brakes). Let's say the difference is 217 lb even (not counting brakes) putting the lighter car with 90% fuel at 3400 lb even. Here are the results. The weight of M3 #2 on the right with M-DCT is exactly as posted here from the earlier post showing the scale weight, but adding fuel weight to get to 90% filled and including a 165 lb driver. The other, car #1 on the left is 217 lb lighter with MT. I am using 50 ms shift times for M-DCT and 300 ms shift time for the MT. It is a significant besting, 0.7 seconds to 100, 0.2 and 2 mph for the 1/4 and 0.6 from 60-130. I realize this won't convince you to purchase the M-DCT, but she WILL be faster, period. Note: Ignore the "M-DCT" and conflicting "MT" titles on car #1. It is 3400 lb with 90% fuel, without driver and has the correct shift times and transmission ratios for the MT car.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 06-27-2014 at 06:14 PM.. |
06-27-2014, 06:09 PM | #58 | |
471
Rep 2,991
My E90 M3 6MT with Akrapovic exhaust and half tank: 3600lbs The DCT is heavier. |
06-27-2014, 06:14 PM | #59 |
Rep 4,981
06-27-2014, 06:14 PM | #60 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
EAS is doing a great job of gathering data for the new car.
Can't wait to see a secondary cat delete in terms of sound and dyno. And by the way, the exhaust sounds ALMOST like an NA 6 in a row. The sound isn't much off of an n52 with a PE.
06-27-2014, 06:31 PM | #64 | ||
Rep 611
I'm fairly well optioned (all the standard box checks minus premium sound) with a 6MT on my 2012 E92 M3, and I've weighed myself with topped off fluids (full tank of gas...hell I even topped off the windshield wiper fluid to be sure) at 3590 on a CAT scale. If you check out other threads on this forum these same figures have been reproduced by multiple other forum members. |
06-27-2014, 06:49 PM | #65 |
120
Rep 374
Correct, I guess it could technically be a stripper. Only options were comfort access and carbon leather trim.
This was before my Challenge Street X-Pipe and Eisenmann Race but after my 19" Volks. So I suspect I'd be under 3,500 now. |
06-27-2014, 06:50 PM | #66 |
yodog
197
Rep 5,026
Looking awesome. Thanks for the weigh in Tom
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
dyno, eas, macht schnell, spacers, weights |
