New 2009 2010 BMW Z4 - ZPOST
      08-09-2010, 08:16 AM   #1
benj5386
Drives: 35i
Navigation: Colours and Night Mode
Either i'm being really stupid and missing the obvious or the navigation screen isn't behaving as it should.
INFO: I am in the UK and have UK and euro maps loaded.
If i have the navigation screen up as a full screen display of the map, the map colour is generally a very grey colour. The only colour on the map seems to be the road numbering labels(M5, M4, A30, A303 etc). When i go in to the settings and tick the option for Night mode, nothing happens. The map remains the very washed out grey colour.
But.....
If i split the screen so the map is displayed on the right hand side (the smaller half if you like) the map is full colour (different classes of roads are different colours, rural areas are green etc). When i then select night mode, the map changes to a black background and roads are red which seems correct.
So my questions are....
1) Should my main map be more colourful along the lines of the split screen map?
2) Should I be able to select 'night mode' so it is mostly black in colour for the main navigation map?
3) If the answer to q1&2 is 'yes', any ideas on how to correct this?
If you need any more info to help, then let me know.
Thanks for any help and suggestions in advance.
      08-09-2010, 09:02 AM   #2
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
Turn off traffic
      08-09-2010, 02:51 PM   #3
eduq
Drives: z4
Turn gray cards off in the option menu of the nav.
      08-09-2010, 07:13 PM   #4
richard in NC
Drives: 2009 Z4 35i
What is the zoom of each view? Grey indicates cities. I don't recall if night mode still shows the grey or black for cities.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims
Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i
      08-09-2010, 10:39 PM   #5
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
52
Drives: Like a Demon!
2010 BMW Z4 35is  [10.00]
2013 BMW X5 30d  [0.00]
For me the easiert way to check if your night and day mode are working properly is to check the sky on the screen.
Mine has clouds in the daytime and stars at night.
Citties (nearby) also add a light glow on the horizon.
It looks so cool my son loves to turn it on all the time (now set as programmable button number 8)
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-10-2010, 02:01 AM   #6
benj5386
Drives: 35i
Originally Posted by Memphis1 View Post
Turn off traffic
This is the answer. Brilliant, i was pulling my (not much left) hair out over this.
I unticked the 'traffic view' in the same menu as the night mode and map display went back to normal. Full colour mapping and it also switches to night mode as expected.
Thanks for your help Memphis1 and of course to everyone else who replied to this question.
Cheers
      08-10-2010, 02:34 AM   #7
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
52
Cheers
Does yours switch to night mode automatically? I have to do mine manually...
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-10-2010, 03:18 AM   #8
benj5386
Drives: 35i
No, I have to go into OPTIONS and MAP SETTINGS (i think) to tick the night mode box.
It seems like a long winded way to change a regularly used setting. It's a shame you can't set it to one of the short-cut keys.
      08-10-2010, 03:50 AM   #9
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
52
Mmmm... but you can set it to the shortcut keys.
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-10-2010, 07:49 AM   #10
benj5386
Drives: 35i
Strange, i tried setting the shortcut this morning and it said i couldn't set night mode as a shortcut.
      08-10-2010, 04:08 PM   #11
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
52
All I know is, mine is set in programmable button number 8.
Are you pressing the programmable button when you see the option to change between night and day, or after you have pressed the option for night and day?
I did it before, while it was highlighted with the iDrive selector.
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-10-2010, 04:29 PM   #12
mikeinaustin
Drives: 2010 z4 3.0 crimson red
i have one button programmed for traffic on/off and one button programmed for night mode on/off.
      08-11-2010, 08:25 AM   #13
T89
T89's Avatar
Switzerland
39
Drives: Z4 35i & Mini Cooper S
+1
T
      08-12-2010, 02:40 AM   #14
benj5386
Drives: 35i
I'll give setting the shortcuts a go later on today. All I can say is the Idrive warned me that a shortcut couldn't be set for that option. I'll play around with the sequence and see what happens.
      12-17-2010, 02:27 AM   #15
Aleppo
Aleppo's Avatar
Drives: Z4 sDrive35i
i do wonder however, is there no way of making the shift between night mode and daytime more automate? any standard garmin gos device has this option, i would have thought the idrive gps would as well.
does anyone know anything about this?
      12-18-2010, 12:25 AM   #16
Z4-2023 Mike
Z4 Mike
73
Drives: 2023 Z4 M40i
2023 Z4/M40i  [0.00]
Shortcut key works for me. Changes to night and same key back to day setting.
      12-19-2010, 01:40 AM   #17
Aleppo
Aleppo's Avatar
i wonder if there's a way to make it change colors according to the light sensor which activates the automatic headlights... or maybe a timer, according to sunset, etc...
      12-19-2010, 09:15 AM   #18
cdeslandes
cdeslandes's Avatar
Drives: 2010 Z4 s35i
I may do just that... Thanks for the suggestion.
2010 BMW Z4 s35i
2014 Jeep Wrangler Rubicon
2013 Volvo XC90
      12-19-2010, 09:16 AM   #19
cdeslandes
cdeslandes's Avatar
You'd think so. A $100 Garmin does it, a $60,000 BMW doesn't...
2010 BMW Z4 s35i
2013 Volvo XC90
      12-20-2010, 05:21 AM   #20
Aleppo
Aleppo's Avatar
my thoughts exactly. i wonder if BMW will be nice enough to include something in a software update...
Santa? Help?
      12-20-2010, 10:29 AM   #21
Land_Shark
In The Flesh
Hong Kong
22
Drives: Z4 sDrive 35i
Santa? Help?
Santa ain't coming this year... He is test driving in Norway... LOL
idrive, navigation, night mode
Search this Thread:
zpost
