ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      07-31-2013, 11:22 AM   #111
bradleyland
TIM YOYO
Drives: 2013 M3
Originally Posted by Levi View Post
You did a sound analysis quite easily, could do it to figure out if the engine is I6 or V6 (90°)?
That's easier to do by ear than it is through frequency analysis because of the difference in character between a cross-plane V8 and an I6. A cross-plan V8 has a "double" combustion event on each side as it works through the firing order. Scroll down to the "Chevy V8 Firing Order" graphic on this page to see what I mean:
http://craig.backfire.ca/pages/autos/v8-engines#firing
For a given RPM, a V8 will have a higher sound frequency, because it has more combustion events per revolution, so if you know the RPM, it's trivially easy to determine the number of cylinders through frequency analysis.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      07-31-2013, 11:27 AM   #112
NISFAN
NISFAN's Avatar
3487
Drives: BMW M2
Originally Posted by bradleyland View Post
It's possible, but you need a good clean upshift where the driver is WOT (or close) before and after the shift. Basically, a hard acceleration run at an easily estimated speed.
Watch this video and post any timestamps of regions where you find that:
If you do the footwork, I'm happy to do the analysis.
Thanks, 0:55 and 1:30 are two possible samples. It doesn't sound like max RPM upshifts to me, but that might be some audible illusion (???)
      07-31-2013, 12:53 PM   #113
bradleyland
TIM YOYO
Drives: 2013 M3
Let me ask you a question. What insight do you want to gain? I assumed you were interested in the gear spacing, but I'm not sure that's correct. I can tell you the highest amplitude frequency before and after the shift, but that will only tell you the relative difference in RPM between gears; it won't provide any insight in to maximum RPM.
      07-31-2013, 01:03 PM   #114
bradleyland
TIM YOYO
Drives: 2013 M3
The "illusion" you refer to is called doppler shift. It can be corrected if you know the correct inputs, but we have to guess because we don't know the velocity of the car, nor the exact angle-of-travel relative to the recording source. If you're making a relative comparison, and the inputs are close enough, you needn't correct for it.
I used the 1:30 region for analysis.
Samples:
  • Pre-shift: 01:28.2, 00:00.3 duration
  • Post-shift: 01:29.2, 00:00.3 duration
Highest amplitude peaks (not corrected for doppler, Hanning window):
  • Frequency pre-shift: 289 Hz
  • Frequency post-shift: 232 Hz
Plots:
      07-31-2013, 01:53 PM   #115
BMW269
435
Drives: BMW
I meant V6, not V8.
      07-31-2013, 03:13 PM   #116
NISFAN
NISFAN's Avatar
3487
Drives: BMW M2
No you are correct, I wanted to understand the rev drop from one gear to the next. The problems relating that into anything tangible, is we don't know the speeds, or even the gear numbers (guesses aside).
Thanks for the frequency plot. If anyone can shed some light on speed approximation for the piece of track involved. We can at least guess a gear number.
      07-31-2013, 03:33 PM   #117
NISFAN
NISFAN's Avatar
3487
Drives: BMW M2
Samples:
Assuming negligible change in speed (cancelling doppler) between shifts, there is a 20% drop in engine revs, does that conclusion sound right?
I'm not going to guess on what the doppler effect is, as speed unknown. Assuming a gear change at say 7,000rpm, next gear is 5,600rpm. That is quite a long gear spacing if from 3-4th on a 7 speed box.
Little movie I took in the M6, very similar. Forward to 27 seconds.
      07-31-2013, 06:18 PM   #118
bradleyland
TIM YOYO
Drives: 2013 M3
Yep, that sounds about right.
      07-31-2013, 06:23 PM   #119
bradleyland
TIM YOYO
Drives: 2013 M3
I meant V6, not V8.
Ah, in that case, I don't think waveform analysis is sufficient to identify the difference without some very specific circumstances. E.g., a V6 with dual exhaust, and a stereo mic placed on the centerline.
If you had a very detailed recording, you could examine the waveform from various examples of V6 engines versus I6 engines, but you'd need a high quality recording with many samples. Ultimately, I think there are too many confounding factors, like exhaust design and turbocharger configuration.
      08-01-2013, 06:29 AM   #120
NISFAN
NISFAN's Avatar
3487
Drives: BMW M2
Agree. For example listen to this video. The cars are all Subaru's with a flat 4 (horizontally opposed) engine. All the cars except the Blue Hatchback (around 0:25, and the video front image) are the common Subaru exhaust headers Turbo one side of engine fed with unequal lenght headers from each bank), which give an uneven 'subaru burble'. The car at 0:25 is fitted with the 'Twin Scroll' equal length headers, which changes it's sound completely, it sounds like an inline 4 (which it should as firing timing is exactly the same as an inline 4). Ignore the first 'anti lag' rev pops for this one.
On a parallel twin turbo straight six, although not as dramatic as the Subaru, the front 3 cylinders typically have a longer exhaust path, which phases the sound out of sync with the rear 3. This could give the impression it is a V shaped engine sound. Certainly the M3/M4 doesn't sound like a conventional inline 6.
      08-04-2013, 03:40 AM   #121
Boss330
Boss330's Avatar
1714
Drives: BMW
Swamp, Bradleyland etc:
Does this clip contain any valuable sound info? Listen to the car passing at around 2:19 on the long straight at the 'Ring:
      08-05-2013, 12:28 AM   #122
swamp2
swamp2's Avatar
Drives: E92 M3
Nope, you need the sound right before a shift and a likely redline shift as well. As a side note I believe it is unlikely that the car will require redline shifts in the upper gears to extract maximum acceleration (unlike current car).
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      08-05-2013, 01:53 AM   #123
Boss330
Boss330's Avatar
1714
Drives: BMW
My bad, I thought there was a shift on that straight, but re-listening I see that I was mistaken...
      08-08-2013, 04:33 AM   #124
Boss330
Boss330's Avatar
1714
Drives: BMW
Is this whistling noise on the MB CLA there just to disguise engine RPM's?
      08-08-2013, 08:10 AM   #125
bradleyland
TIM YOYO
Drives: 2013 M3
I don't know what the heck that whistling noise is, but it won't prevent a Fast Fourier Transform analysis of the engine RPM. To do that, you'd need to produce a tone similar in frequency to the primary combustion impulse. That whistle is way too high-pitched. Maybe it's a harmonic, but each multiple you move from the fundamental, the benefit of confusing the base frequency would be diminished. That whistle would have to be a shriek.
      08-08-2013, 01:39 PM   #126
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
It's got those whistle tips. woo WOO!
      08-08-2013, 02:05 PM   #127
swamp2
swamp2's Avatar
Drives: E92 M3
I strongly suspect it is just pressurized air, air/fuel or even exhaust leaking in the turbo system somewhere due to a poorly fitting part or an improperly torqued bolt(s). This is a known issue. As noted above this would not disguise the fundamental combustion frequency in a fourier transform.
      08-08-2013, 05:33 PM   #128
Dr. Sound
Drives: M3 e46
Location: Germany near Cologne, 100 miles to Nuerburgring :-)
Please have a look: http://f80.bimmerpost.com/forums/sho...7&postcount=24
2014 bmw m3, 2014 m3, 2014 m3 forum, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m4, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, f80, f80 forum, f80 forums, f80 m3, f80 m3 forum, f80 m3 forums, f80 m3 sedan, f82, f82 coupe, f82 forum, f82 forums, f82 m3, f82 m3 coupe, f82 m3 forum, f82 m4, f82 m4 coupe, f82 m4 forum, f82 m4 forums, f83 m3, f83 m4, m forum, m forums, m3 f80, m3 f80 forum, m3 f80 forums, m4 forum, m4 forums
f80post
