10-15-2012, 12:57 PM | #1 |
Administrator
40811
Rep 21,240
FAQ: BMW iPhone 5 and iOS 6 Functionality, Bluetooth and Y-Cable Overview
BIMMERPOST NEWS FAQ: BMW iPhone 5 and iOS 6 Functionality, Bluetooth and Y-Cable Overview Apple recently introduced the new iPhone 5. There are three key differences between it and earlier iPhone models that affect its integration in BMW vehicles. First, the physical dimensions of the body of the new phone are thinner and longer compared to the iPhone 4/4S. Second, the iPhone uses a new 8-pin connector in place of the traditional 30-pin connector used on all other iPhone variants as well as iPod touch and iPod nano. The third is the elimination of the analog video signal. Taken together, the result is: 1. iPhone 5 is not compatible with any of the current snap-in adapters available through BMW. 2. The PlugIn feature as a means of accessing one’s music library is not available on the iPhone 5. (Owners are still able to access their music library using a USB cable, see details under “Will I need an adapter to use my iPhone5?”.) 3. Also, watching videos stored on the device, on the car’s screen while parked is no longer possible. FAQ Below is an FAQ regarding the use of iPhone 5 and iOS6, as answered by BMW: Can I connect my phone via Bluetooth to make phones calls, see my contacts and play music? • Yes.Can I still play music from my iPhone 5 in my BMW? • Yes, via the External Devices menu in iDrive.Will I need an adapter to use my iPhone 5? • This depends on the options in the vehicle:Can I use PlugIn and/or play videos from my iPhone 5?◦ No, if you currently use an Apple "white cable" to connect your iPhone to your vehicle. In this case, all you need is the new Apple Lightning cable, included with your iPhone 5. (See our member's DIY guide for creating a cradle and integrating the lightning cable)◦ Yes, if you currently use a Y-Cable to connect your phone. In this case, you will need a "Lightning adapter" to connect your iPhone 5 to the Y-cable. (See "USB vs. Y-cable" on below to determine when a Y-cable is needed for MY 13 vehicles.)◦ The "Lightning adapter" is an adapter available via Apple to convert the old 30-pin plug to the new 8-pin connector or "Lightning cable". It is already on sale by Apple and retails for $29.99 (for the adapter) or $39.99 for the adapter cable. • No, the iPhone 5 Lightning connector does not support analog video, therefore making the PlugIn feature and video playback incompatible. • PlugIn and video playback are still supported when using an iPhone 4/4S with iOS 6.When will the iPhone 5 Snap-In Adapter be available? • BMW's official word on this is that there is currently no timeline set for the release of the iPhone 5 Snap-In Adapter, but as we recently reported, our sources indicate that its currently in developemtn and to expect it sometime around June 2013.Is "BMW apps" compatible with iPhone 5 / iOS 6? • Yes, owners with iOS 6 (incl. iPhone 3GS/4/4S/5) and a "BMW apps" equipped vehicle can continue enjoying the same great app integrations, just as they did with iOS 5.1. This includes Pandora, MOG, Aupeo, Stitcher and BMW Connected. • Pandora is still not compatible with the New Navigation Professional System (SA609) vehicles, but an update is expected from Pandora by November 30, 2012.)Can I use Mobile Office with iPhone 5 / iOS 6? • With the release of iOS 6 (incl. iPhone 3GS/4/4S/5), Mobile Office is now supported for Text Messages and iMessages. This is available in cars with option code 639 / 6NL "BMW Assist with Enhanced Bluetooth". Owners will be able to see their text messages / iMessages on the screen, • Not all of the Text Messages / iMessages on the phone will be displayed in the vehicle. Only new messages received while the phone is connected to the vehicle will be available in the vehicle. • Owners will have to configure their phone as follows to activate this feature: 1. Pair the phone to the vehicle as normal. 2. Under "Settings" and "Bluetooth", press the blue arrow to the right of the paired vehicle: 3. Then turn on "Show Notifications": 4. Also,notifications must be turned on for "Messages" as well: 5. Owners then have to reconnect their phone to the vehicle. This is done by scrolling over the paired phone in the vehicle’s “Bluetooth” menu and pushing the iDrive controller. 6. Returning a phone call via the displayed text message / iMessage is not possible. Owners should either dial the number directly or select a contact from their address book using iDrive. Y-CABLE / BLUETOOTH USB vs. Y-cable: USB is offered standard on all 2013 BMW models, but the available functions differ based on vehicle equipment. Audio playback through the USB port is always included, but may require the Y-cable accessory in combination with an iPhone / iPod. The BMW Apps features are only available in combination with option 6NR "BMW apps". Some of the app features are accessible using the Apple cable, but video playback is only possible with Smartphone Integration (6NF) in combination with the appropriate snap-in adapter. * Plug-In is not currently compatible with the new Navigation Professional system (SA609); a fix is expected later this year. The Y-cable is needed unless the vehicle is equipped with 639 or 6NL "BMW Assist with Enhanced Bluetooth and USB", which is standard equipment on all MY 13 5 Series, 5 Series GT, 6 Series, 7 Series, X5 and X6 models. On most other MY 13 models, 639/6NL is offered in combination with 609 "Navigation system" and/or in the Technology Package and/or as an option. See the chart below for more details about each model’s Y-cable dependency. Bluetooth: Bluetooth comes standard on all 2013 BMW models, but again, the available functions are dependent on vehicle equipment. Please refer to each vehicle’s ordering guide to determine which options are available. |
10-15-2012, 02:10 PM | #3 |
Bavarian Wolverine
96
Rep 525
It took me a few years, but I finally understand which cables allow you to do what in each model/model year. This is very helpful for the newbies, though!
I ended up keeping my iPhone 4 to use as a music hard drive in my 2009 M3, and with iTunes Match turned on, it automatically syncs my music and playlists with all my other devices/iTunes when I park at my apartment and the iPhone 4 sees my router. Alternately you can use your 5 as a Wifi hotspot to update the music/playlists on your 4 if you continue to use it as a hard drive.
Euro Delivered: 15 428i xDrive Gran Coupe M-Sport EBII
Past: 12 VW GTI, 09 E93 M3, 07 E92 335i, 06 WRX STI |
FlorinQCK-2.50 |
10-15-2012, 02:28 PM | #4 |
35
Rep 183
Drives: 2011 Alpine White 535i M-Sport
Anyone experience both phone call and audio at the SAME time when I pair my iPhone via bluetooth instead of using the apple cable? I mean I was listening to audio via bluetooth and when I receive phone call...I will hear both sources at the SAME time in the car...caller seems to get my voice only from the other end...anyone?
FlorinQCK-2.50 |
10-15-2012, 03:16 PM | #5 |
15
Rep 108
Great summary!
Unfortunately the procedure for showing text messages doesnt work for a iPhone 3GS with iOS 6 in a F30 equipped with 6NL and 609. The phone does not show the option " Show notifications" under the paired device". It does show "Synchronize contacts" and that works fine. Anybody with different results? (Car bt software updated using upd1005.bin) |
FlorinQCK-2.50 |
10-15-2012, 03:49 PM | #6 |
Sold: E46 330CI, E90 320dA with 270000km
9
Rep 187
Drives: 1M
Im getting my BMW 1M (production date - 04.2011) next week!
It has Navigation Profesional.....but i have no clue how much I will be able to do with my iPhone...?! |
FlorinQCK-2.50 |
10-15-2012, 04:21 PM | #7 |
Came to the N55 Darkside
1112
Rep 12,740
Can't shuffle via the USB cable, which sucks.
Bluetooth is flaky too. I have had to forget my BMW Bluetooth and repair to get Bluetooth audio more times than I can count (this is most likely an iOS 6 issue) and occasionally the audio crackles too via Bluetooth. Ah the price we pay for new tech... |
FlorinQCK-2.50 |
10-15-2012, 07:13 PM | #11 | |
Give '///M' Hell!
125
Rep 1,325
Even Siri works fine over BT (You can turn this on/off on the phone itself). Also, congrats on your 1M. Don't forget to come say hi on the 1M board.
The 1 series M is the most badass, coolest, sickest BMW to debut since the 1988 M3. The E30 M3 finally has a successor. Please welcome the stupidly fast, wickedly tempered, awkwardly named, possibly perfect little son of a benchmark - Automobile Magazine, August 2011
FlorinQCK-2.50 |
10-16-2012, 01:00 AM | #14 |
I want to drive a Zamboni
1129
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Having trouble with white cable on my 09 E82 can only charging but can't connected to USB on idrive. With MY12 E93 had no problem at all.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
FlorinQCK-2.50 |
10-16-2012, 07:28 AM | #16 |
teh porcupine
96
Rep 1,726
Drives: 2020 Tesla 3 LR AWD
Any way to have txt messages display without navigating the iDrive to the office menu, then the phone menu, then the message menu? I would like the message to display over what ever iDrive screen I happen to be on at the time. Navigating all those menus to get the txt message sort of defeats the purpose.
I have a 2012 135i with iDrive and NAV, and an iPhone 4 with iOS 6 installed.
FlorinQCK-2.50 |
10-16-2012, 09:01 AM | #17 |
13
Rep 121
Sorry for the potentially stupid question, but what does PlugIn actually mean?
I have an iphone 6 with the y-cable. If I get the thunderbolt adaptor will I still be able to browse through the songs on my iDrive screen, or is that what PlugIn means? |
FlorinQCK-2.50 |
10-16-2012, 10:24 AM | #20 | ||||
Rep 4,488
If you use a Y-cable, that may be true (although I think those cars use analog audio through the snap-in too, but I'm not sure). But if your car can pull audio using just the normal white USB cable, then sound quality should be identical since it'd be digital audio in either case.
Can't imagine why not. Quote:
FlorinQCK-2.50 |
