08-21-2014, 03:32 PM | #1 |
8115
Rep 18,809
Drives: BMW
▀▄ eas | DIY: Valentine One Radar Detector Hardwire
My V1 radar detector has never let me down. Its like a trusty co-pilot I've had for years, and usually one of the first things to do to a new daily.
I've never been a fan of the telephone cord visible on the windshield. While V1 has recently released the Savvy, it's just additional clutter in the cabin area and I'd probably end up taking it out with a wild kick by accident one day. Instead, we'll be hardwiring the V1 to turn on/off with the ignition. Items Needed - Valentine One Radar Detector - Valentine One Hardwire Kit - RJ11 Interface Cable - (2) ScotchLock wire clips (not pictured, Red 18-22AWG) - (2) Male Spade connectors (18-22AWG) 1. Start by crimping the spade connectors onto the hardwire kit. 2. Pull off trim plate on sunroof panel/light cluster. 3. With a small pocket screwdriver, press the retaining tab while slightly pulling on sunroof module and work out of place. There are (2) retaining tabs on opposite sides. 4. Remove plastic mirror housing by pulling apart. Crimp ScotchLocks onto wires as follows: Green/Brown Stripe & Brown/Black Stripe. 5. Route Power/Ground leads through headliner to exit by driver's side of rearview mirror. 6. Pull some slack on connecting leads by driver's side of rearview mirror. 7. Connect spade connectors to ScotchLocks as follows: Green/Brown = +12V Switched/KL30 & Brown/Black = Ground. 8. Connect RJ11 cable to [MAIN] port on V1 Hardwire Kit. 9. Reinstall mirror housing, route RJ11 cable through headliner to driver's side of mirror. 10. Reinstall remaining trim pieces and plug into RJ11 port on V1. Press START button and test. Install is complete. Verify V1 position is clear of headliner and does not interfere with sun visor. This and much more covered in our journal thread here: http://f80.bimmerpost.com/forums/sho....php?t=1020487. Enjoy and safe driving out there!
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 03-21-2016 at 11:45 AM.. |
08-21-2014, 06:29 PM | #3 |
M3AT LOVER
322
Rep 1,853
Excellent tutorial!
Your link at the end is broken with the '...' in the middle. This is the correct link: http://f80.bimmerpost.com/forums/sho....php?t=1020487
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
08-21-2014, 06:34 PM | #4 | |
8115
Rep 18,809
Drives: BMW
08-22-2014, 09:02 AM | #5 |
Rep 12
I've been waiting for someone to post this....much thanks. Question though. Did you access the wires under the light dome or did you also remove the housing around the mirror? When I jumped into this last night, I could only find those wires in the small harness leading to the mirror. Unfortunately I'm still not getting power...???
08-22-2014, 11:17 AM | #6 | |
8115
Rep 18,809
Drives: BMW
Double-check your connections with a digital multimeter, also make sure the spade connector blade inserts into the slot (and doesn't push) aside when inserting into the scotchlock, not making contact.
08-23-2014, 10:40 PM | #7 |
Rep 806
this is what Ill be doing once I can find the crimp piece of the set up. that goes on the wire I had to leave those on my e92. Anyone know where to buy these? Any pep boys ? Thanks
96 E31 JB 07 E92 AW F82 BSM |
08-25-2014, 07:25 AM | #8 |
14
Rep 80
Thank you for the detailed instructions. I see that you did not opt for the concealed display. Has anyone run the wiring for that? Any preferred place? I'm trying to find a spot on the instrument cluster where I won't block information. I suppose I could use the Android app for the display for that although I do not know if using the Android app turns off the display on the V1 the way the concealed display does. Plus, the Android phone is busy running Waze which is a wonderful app.
08-25-2014, 02:44 PM | #9 | ||
8115
Rep 18,809
Drives: BMW
08-25-2014, 02:55 PM | #10 |
14
Rep 80
09-30-2014, 09:42 PM | #11 |
8115
Rep 18,809
Drives: BMW
Had a couple of V1 wiring inquires, bumping to the top of the list.
10-06-2014, 12:44 PM | #12 |
Rep 4
Great idea with the scotchlock wire clips and tapping behind the mirror. I set out to install my V1 Hardwire Kit this weekend, only to be tripped up on the "ground the black wire" step. There is absolutely no metal to be found under that carbon fiber roof! Now,off to Radio Shack...
10-09-2014, 05:51 PM | #14 |
8115
Rep 18,809
Drives: BMW
Not aware of any that do not go into sleep mode in that particular location, sorry.
11-30-2014, 06:13 PM | #15 | |
Rep 521
2015 Alpine White ///M3 | Sakhir Orange/Black Extended Merino Leather | 6MT | Lighting Package | Harmon Kardon | H&R Sport Springs (F32) | iND Cosmetic Treatment | M Performance Spoiler | 19" HRE 301M Frozen Red| Mode Carbon Trophy R1 Diffuser
12-01-2014, 11:37 AM | #16 |
8115
Rep 18,809
Drives: BMW
There's a small space above the driver's side visor everything can tuck into. Wouldn't hurt to add some insulation to keep the splitter from rattling around.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 12-01-2014 at 11:47 AM.. |
12-01-2014, 06:40 PM | #17 | |
Rep 521
03-15-2015, 07:49 PM | #18 | |
Rep 23
03-15-2015, 07:55 PM | #19 |
Rep 23
By the way I did it on my M4 conv so the dome light housing is different. It has 4 metal clips that hold it in (2 front. 2 backside) Plus you have to remove a trim bezel first. I just pulled the rain sensor/mirror windshield trim apart grasping it from the top.
03-16-2015, 09:02 AM | #20 |
Rep 67
Drives: F33 M Sport 435i
Can you post a pic of your install in your M4 convertible? I have a 435 Convertible and thinking of hardwiring my V-1.
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk |
03-31-2015, 07:32 PM | #21 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
Thanks for the writeup.
Two questions / requests for confirmation: 1) Does this work well without the sunroof? Any risk of "burning" the wires as the V1 will draw more current than they were designed for? 2) Does the V1 turn on/off as the start/stop function is enabled?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
03-31-2015, 08:09 PM | #22 | |
8115
Rep 18,809
Drives: BMW
No issues with Start/Stop.
eas, hardwire, radar, valentine |
