BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      09-01-2011, 01:56 PM   #1
stefan
stefan's Avatar
2350
Drives: M2 Comp
DIY: Passport radar detector hardwire (using Add-A-Circuit & Safe-N-Sound wire)
The E92 M3 without sunroof does not have a proper grounding screw above the map lights. Therefore, tapping into a hot lead above the map lights as some DIYs suggest will not work unless you have a sunroof and a ground. Furthermore, any electronic malfunction, from a dealership perspective, can actually be blamed on tapping into wires. So, here is the other method.
I am expanding on E92Vancouver's DIY here: http://www.e90post.com/forums/showthread.php?t=111583 using the Safe-N-Sound radar hardwire kit.
I am adding more detail, and this method will NOT remove trim.
Here are the tools you will need.
- A directwire kit of some type. This one is the Safe-N-Sound kit (see ebay; very affordable)
- Add-A-Circuit mini (about $15 at most automotive stores)
- 3 amp fuse provided in the Add-A-Circuit kit
- A larger ground loop
- Grips (small set for accuracy, big clamps for smashing the connectors together)
- 4mm hex head screwdriver
- Snips
- Zip ties
Step 1: Run wires
Place the detector where you want it and approximate the amount of wire you will need. This will come in handy when you decide where to bunch up the extra or if you even have enough in the first place.
This DIY suggest you run along the headliner towards the passenger A pillar. Then, run around that A-pillar at the joint until you hit the door trim (where it meets the A-pillar). Then, tuck all the way down the door rubber until you hit the entrance to the glovebox.
Step 2: Access fuse panel, and thread into the glovebox
Access the fuse panel by opening the glove box and turning the two retaining bolts on either side of the back of the glovebox 90* each so they are vertical. The panel should fall forward exposing the fuse box.
Tuck into the glovebox where you find an opening near the bottom. You can see it in this photo, taken from the floor looking up.
Step 3: Wire your add-a-circuit and ground loop
The kit from safe-n-sound does not come with a large enough ground loop to fit the screw we will use. Pull it off and crimp a larger one on. This ground wire will be attached to the large hex head screw found to the left of the fuses. Before you screw it on, wire your hot lead!
You will need to replace the connector provided by safe-n-sound on the hot +12v lead to your add-a-circuit. In my case, I had a t-tap kit on there designed to be the female end of a wire tap. Pull it off, and crimp on the add-a-circuit. The Add-a-circuit has two slots for fuses. The bottom one/slot A/closest to the fuse plug is the "original" fuse you will be replacing with. Slot B (top one) will be used for the detector.
Step 4: Plug into fuse #8 and screw in the ground
Pull out the 20A fuse and plug it into slot A of the add-a-circuit. Plug the 3A fuse provided with the kit into slot B of the add-a-circuit. Plug the add-a-circuit into fuse position 8. Fuse #8 corresponds to the cigarette lighter aka accessory plug. So it makes sense to use this and will turn off with the vehicle.
Pull the screw off and place your ground loop between the chassis and the screw head.
Step 5: Conceal wiring
Tuck the wire all along the headliner until you reach the a pillar. Get out a trim kit tool and push into the A-pillar until you reach the trim joint about an inch down from the roof. Follow the trim joint around until you reach the door rubber. Tuck under the door rubber all the way down until you reach your entry point to the glovebox. This was incredibly annoying. I actually didn't even get the wire completely concealed between the glovebox and door rubber near the bottom. Thankfully, it isn't noticeable. Recommend a good amount of beer for this step.
Clean up in the fusebox by using zipties to secure your wires to the main harness. Close up the fusebox by aligning the tabs on the fuse panel vertically and turning them horizontally 90*
///M Power
      12-09-2011, 09:22 PM   #2
SROC3
The limit of adhesion is my home.
SROC3's Avatar
Drives: Like a Boss.
THANK YOU FOR THIS DIY. DA BOMB. And the last part isn't too hard actually. once you pry it open once you can wiggle your finger in there and then guide the wire all the way to the top, flatten it out by the front window and tuck all the way to the center and stuff the excess wire in there Thanks again man!!! perfect DIY!!!!
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      12-10-2011, 09:20 AM   #3
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
I believe this is the same way that mike Benvo suggests that you do i.
      12-14-2011, 08:29 AM   #4
THE TECH
THE TECH's Avatar
307
Just finished doing mine (V1) last night using this method. Works flawlessly!
      12-14-2011, 08:52 AM   #5
stefan
stefan's Avatar
2350
Drives: M2 Comp
Awesome guys.. glad it could help!
///M Power
      12-27-2011, 06:08 PM   #6
cghempel
25
Drives: M3
Just used this DIY today...Worked great! Thanks for the guide!
      01-20-2013, 08:54 AM   #7
cc_bavarian
cc_bavarian's Avatar
Hong Kong
13
Drives: 2007+ E90 330i
2007 E90 330i  [0.00]
Hope to get an answer from this old thread. My google search lead me here. This Add-a-circuit devices says max 10A for both slots. But the cigarette lighter is 20A. Seems like the device is working for you and for some.
      01-20-2013, 09:00 AM   #8
6spdg37s
Drives: none
what is fuse 8? I used fuse 5 and it worked flawlessly
      01-23-2013, 05:31 PM   #9
jqsmooth
jqsmooth's Avatar
Drives: M6
I've been meaning to do this. Thanks for the extra detail.
2008 E64 M6
2011 E92 l SSII l Fox Red - 145k and Totaled. 2012 Toyota Prius C - 145k and Totaled. 2002 Nissan Pathfinder - 301.6K and Junked. 2000 Mitsubishi Montero Sport - Rolled & Totaled. 1995 Cadillac Fleetwood - RIP.
      07-13-2014, 01:00 PM   #10
rgoose18
rgoose18's Avatar
21
Drives: 2008 Audi RS 4
Any way to get these photos back? Really need to do this
2008 Audi RS4 Daytona Grey - Daily
2009 BMW M3 AW
      10-24-2014, 01:48 PM   #11
WhiteFlashE90
WhiteFlashE90's Avatar
Drives: '21 GT4, '20 X3M and T3P
This would be great with photos!
2021 718 GT4, 2020 X3M, 2021 Tesla 3 perf.
SOLD: 2019 M2 Competition, 2018 X6 35i
2015 981 GTS, 2013 991.1 C2, 2016 AMG C63S, 2016 M4 Grey Metallic, 2014 SQ5, 2013 Audi RS5 Ibis White, 2012 650i AW, 2008 Merc. C63 AMG, 2011 335i DCT Crimson Red, 2008 E90 AW M3 DCT, 2011 E70 X5 35d, 2005 E46 M3 Convertible, 2007 E90 335i, 2009 Audi A5
      10-28-2014, 11:48 AM   #12
modkrazy
modkrazy's Avatar
171
Drives: m3
+1!
      11-19-2015, 10:41 AM   #13
warrior3313
warrior3313's Avatar
Drives: Searching
The pictures seem to have broken links. Do you have them somewhere where I can take a look? I am planning on doing this this weekend.
- Snips
- Zip ties
Step 1: Run wires
///SEARCHING///
ESS Tune, ESS Performance DCT Software,
Dinan Pulley, Dinan X-Pipe, LUX H8 V4,
Macht Schnell Intake Scoops
diy, e92 m3, hardwire, passport, radar
m3post
