BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
Studio RSR
      09-04-2014, 11:05 AM   #133
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
Thanks for this DIY, instructions are excellent.
Done in 10 minutes by following all steps described without breaking anything or hurting myself
      10-13-2014, 08:14 PM   #134
YeaG30
YeaG30's Avatar
Drives: 2017 540i
So easy. Thank you OP for the DIY. Did the bumper pulled forward method and the first grill was hard but then the second is much easier to access.
Its so weird how much of an improvement black kidneys make; so awesome now.
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
      11-02-2014, 03:18 PM   #135
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Replaced originals with M4 Kidneys...Stupid easy! Removed screws, pulled bumper a little forward, used screw driver to press down tabs on top of kidneys to loosen top, then grabbed grill and forcefully pulled right off! Took about 10min from start to finish!
      11-30-2014, 10:41 AM   #136
evan15281
Scotland
86
Drives: 335d
I used this guide to fix a parking sensor issue I had.
http://f30.bimmerpost.com/forums/sho....php?t=1063961
Excellent - thanks for write-up
      12-03-2014, 08:57 PM   #137
Chuckbuster
29
Drives: 2014 328i Estoril Blue
2014 BMW 328i  [10.00]
After reading this thread I just did it directly from the front...no tools...no moving the bumper...and no damage to the original grill (or my hands).
Just put your hand in to depress the middle of each tab while wiggling the whole grill straight out away from the engine. Each tab out gives you more leverage on the next and the whole thing just slides right out.
For reference, here are all the slots where the grill tabs sit.
      12-05-2014, 05:01 PM   #138
acebrigade
acebrigade's Avatar
Drives: 2014 320i
Originally Posted by tdizzle View Post
Just did this in about 7 mins taking my time. No need to take the bumper off or use any tools for that matter.
I just looked at the new grills to understand where the tabs where and started on the edge and top and put my hand between the slots and pushed down on the tabs while pulling on the grill. Don't be afraid to use a bit of force. I got around the top tabs starting from the outside and gave it a good tug and the whole top pulled out and left only the bottom. Those were slightly harder but once you got one loose the others were easy. The middle seemed the be the last one standing. Once you have the top loose you can see the bottom tabs and it makes it a bit easier.
Leave the grill out and work on the other one and that one takes about 1 min to pop out. To put back in takes about 30 seconds for both.
Super easy mod, no need to take the bumper off or have any tools. (the grill slots flex a bit so you can get your hand in there without worry - at least I was able to). I thought I may break something at first when I tugged so hard but nothing was remotely damaged and the old grills look in perfect condition.
thanks mate. After i realized I was missing one of the tools, I tried this. I also have big (not fat) hands and holy crap was this easy. Took 2 min tops and I did no damage. Also a note, I am by NO means a handy man. SUPER easy. Much appreciated!
      12-07-2014, 04:23 PM   #139
Soothsayr
Drives: Silver 2013 328i xDrive
thanks to the OP for the original DIY. Finally did mine today. Went from this:
to:
      12-14-2014, 12:12 AM   #140
nickgeorge25
nickgeorge25's Avatar
Drives: 2018 440i M Sport Coupe
Super helpful DIY, thanks! Took me about 15 minutes.
      12-19-2014, 10:59 AM   #141
MailmanOdd
Drives: 2015 328i Estoril Blue II
I just did this on my car without removing the bumper. I was able to squeeze my hands through the slats. Took about 10 minutes.
      12-21-2014, 11:53 AM   #142
R_C_S_//X3M
Launch Control Specialist
R_C_S_//X3M's Avatar
Drives: 2018 Mineral White BMW M3 CP
For anyone wondering...... This DIY works great on the F36 as well. Just finished. 10 minutes and a little elbow grease.
      12-21-2014, 12:48 PM   #143
TBolts10
41
Drives: '13 F30
Has anyone done this on an Imperial Blue F30? Just looking for some pics before I paint my grills. Also anyone tried Plasti-dip on these?
      12-25-2014, 03:41 AM   #144
jswiss310
Drives: 328i 2014
Exclamation Carbon Fiber Grills
Hey everyone,
I installed a fresh pair of Carbon Fiber grills on my F30 328i. Used the no tools method, didn't even open the hood! Fairly easy install about 30 mins, (I like to wipe everything around once the old grills are off so it looks clean as possible. ) was able to find all the top and side clips with my hand easily, pressing them down one at a time, gently pulling the grill loose as I went. Once those top clips are disconnected, I was able to get the bottom clips off in the same manner. Seems easy enough but it can be tricky! I choose the Carbon Fiber grills, they look awesome as I expected very clean and sporty. I didn't see many people posting pictures of the CF Grills so here it is!
      12-25-2014, 03:22 PM   #145
jamoka3
Assassin
jamoka3's Avatar
Drives: 2013 F30 335i Xdrive M-SPORT
I like those carbon fiber blacked out ones, where did you get yours at?
      01-11-2015, 08:27 PM   #146
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
This DIY was super helpful, the one piece of advice I would suggest anyone doing this mod use is:
"When you are pushing on the tabs, pull out on the grille at the same time. Otherwise, those darn tabs will never get out of their locked position."
I know this was mentioned in the original post, but I glanced over that incredibly crucial piece of info.
Front
Side
      01-21-2015, 09:26 AM   #147
richardhurst
16
Drives: April '10 525DSE
I've just purchased the F34 Gran Turismo and in the UK they don't do a black kidney grill surround. The slats themselves are black but the outside bit is chrome effect. My only options are to have them sprayed or find a guy that does Vinyl coverings but really want this done.
Update: Just found a set online so have ordered them in high gloss black. Should be with me Tuesday/Wednesay next week, can't wait!
      02-16-2015, 11:04 AM   #148
TriniJots
Driver
Drives: 2021 M340i
Is this the same way for an F32?
      02-16-2015, 12:27 PM   #149
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I think its easier to just reach through the slats and press the tabs.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      02-16-2015, 12:41 PM   #150
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
How small are your hands? I can't get past my knuckles trying to go through. No matter, removing the top screws is easy enough, and the F34 has rubber in the way anyway.
      02-16-2015, 12:58 PM   #151
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
I had to break my old ones off due to extreme cold lol.
It was so cold in NY when I got my grills that the bumper would not flex enough for me to fit my hand in there after removing the 6 top screws or so.
Only other option was from the front but I couldn't get my hands in there good enough to actually release the clips, so I went ahead and cut two of the slats out LOL! I figure I can leave the black grill on on return in 3 years or I can just buy one right side grill, it won't kill me.
I will recommend people just don't even bother to do this when its freezing cold out. I came close to breaking a tab on the bumper itself due to lack of flex and one of the plastic pieces from the grill getting bent and then stuck in one of the clips. If I didn't break it then I came damn near close LOL but I'm pretty sure I did not because my grills sit perfectly flush.
      02-16-2015, 09:00 PM   #152
TriniJots
Driver
Drives: 2021 M340i
Thanks for the DIY
Just finished my install.
Took a little longer than expected because I didn't line up the bumper correctly when screwing it back on, the hood looked way too close to the bumper, so I had to open up and readjust.
Other than that it was pretty straight forward. Just remember to pull the grill as you are unclipping the tabs. Second grill was much quicker than the first.
      02-16-2015, 09:10 PM   #153
Mike_L
Thats why my flat black ones are still on the car. I'll put on the gloss ones when I get to Florida. They don't take up that much space that I can't take them.
      02-22-2015, 04:35 PM   #154
clippersfan
Drives: 2014 320i
thanks for the guide 1.fresh.f30.335! Just installed the M Grills on my 320i...your instructions were DYNO-MITE!
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
Search this Thread:
