03-28-2008, 10:18 AM | #1 |
gone baby gone
381
Rep 1,052
DIY: Install / Wiring of M Illuminated SMG knob
Hey fellow Z4 SMG owners (all 4 of you!)
Have you ever ridden in an M5 or M6 SMG and thought, wow, I really love that shifter! Well, I have, and thanks to a great deal from Tischer on the knob, the ingenuity of the M3 crew who adapted it for their cars, and a bit of my own time and patience; I present to you, the illuminated M SMG knob in an SMG Z4! How To: First, the required parts: - OEM M5 SMG Shift Knob: 25-16-2-282-750 - SHIFT KNOB - Connector Plug: 61-13-6-909-058 - Connector UNIVERSAL SOCKET HOUSING UNCODED - 6 x Connector wires: 61-13-0-005-197 - BUSHING CONTACT Getting the connector and contacts will ensure a 100% plug-and-play install / removal of the knob. Highly recommended. Optional, highly recommended part: micro potentiometer. I got one from my local Radio Shack, part # 271-284 I'll call this out later in the Stage 2 install. First, we will need to modify the base of the new knob. The small circular attachment ring will not fit our shift boots, and we will not be able to install it under our boots with that ring on, it has to go. I used a sharp utility knife and slowly, carefully, separated the leather from the plastic ring. It is just held on with some strong glue. Work slowly and surely around it and you'll get it. Taking a look at the M5 SMG shift knob, we see it has a 6 pin harness coming out to control the illumination. Build your harness by inserting the 6 bushing contacts into the new socket housing. The wires will need to be connected as follows: Pin# - Description 1 = Zone Reverse (switched GND) 2 = Zone Neutral (switched GND) 3 = Zone Drive A/S (switched GND) 4 = Night Illumination (GND) 5 = Night Illumination (switched +12v) 6 = Zone Lighting (switched/constant +12v) I also tag labelled the ends of my wires to make it easier to keep track. Stage 1 Install: enable dimly illuminated knob face for night-time driving. To install: Pins 4, 5 This step is easy, and makes the whole thing worthwhile. T-Tap pin 4 to the brown / black-stipe wire in the white harness for the gear selection LEDs. T-Tap pin 5 to the blue / red-stripe wire in the white harness for the gear selection LEDs. A sample of what you get here (sorry for the blurry pic, night illumination was very hard to photograph well): Stage 2 (Optional) Install: enable Zone Lighting (not for the weak). To install: Pins 1,2,3,6 This step is unfortunatly no small task of making connections to pre-existing wires. Without a good technical manual to the car, I performed extensive trial-and-error tests with a digital multimeter. I determined that unlike the M3's SMG II, our gear select lever emits an adjusted voltage signal to signal the ECU which gear the user wants to be in. (Not final selection of course, ECU can override). The M3 emits a switched ground for each position, so those guys got off easy. They can connect wires 1,2,3 with some T-Taps and be done. We will have to build our own leads. I had a hunch the position select LED indicator just below the shifter operates on the same switched ground principle, since when I tested its leads it had no discrete switching signal, instead it utilized 2 adjustible voltage signals to feed gear selection information to the small PCB that the LEDs are mounted to. Luckily, I was right (or I would have been really mad) and what we need to do here is extend 3 leads from the negative side of the gear select LEDs. Solder a small wire (I used 30ga, color coded) to the right side of each indicator LED. These are the small ones, make sure not to tap the general illumination LEDs (the bigger ones). Route the wires carefully out the sides and re-assemble the housing. With the switched grounds installed, connect up the 1 last wire, +12 for zone illumination. I connected it to the Red / yellow wire in the same white harness going to the gear selection LEDs, this way whenever there is illumination of the panel LEDs, the knob will light up also. This gives you position indication when you hit a button on the fob (before starting the car, or before key in the ignition) as well as after leaving. It will go out on its own a minute or so after leaving / locking the vehicle too. Testing, double-checking, and more testing: It works! Something I noticed: Zone Illumination is BRIGHT! Like, retinal burning, distracting from driving bright at night. In the M5 I suspect this is controlled via central illumination, but here we are just cramming 12v through a very intense LED. So, to dim it down, I installed the potentiometer mentioned above. Splice it into the middle of wire 6, constant / switched +12. This gives you a nice turn-dial that will allow you to fine-tune and pick how bright you want your zone illumination to be, and then hide the mini-pot under the shifter. If you ever want to change the brightness, just pull up on the boot, adjust, and re-install. Quite easy and effective, not to mention $1.49 + 5% tax locally. Re-installation: Pull the harness and leather of the M5 knob through the hole in your Z4's shift boot. Its a tight fit, but you can get all of that material through there. Slowly work the wires down, being very careful not to pinch anything, and get the knob onto the shift stalk. Pull the Z4 shift boot up tight around the base of the M5 knob once more, and then push everything back into place. A comparison of the two knobs: The new knob is slightly lower, feels better, and most importantly, looks great! Credit and Sources: I would not have started this project were it not for some extremely helpful threads on other boards, specifically: M3 DIY, from which much was borrowed / learned: http://www.m3forum.net/m3forum/showthread.php?t=100928 Original knob swap thread, long but it had many helpful tidbits: http://m3forum.net/m3forum/showthread.php?t=83712 Tischer's great special on the knob: http://www.mileoneparts.com/partloca...catalogid=4462 |
03-28-2008, 10:21 AM | #2 |
My favorite sign.
167
Rep 4,333
You know there is a DIY section, right?
03-28-2008, 10:24 AM | #3 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Though I never considered replacing the chrome stubby on my M3's shifter, this is definately an imrovement in your case. Great job, I approve!
03-28-2008, 11:24 AM | #4 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
And to Reach of all people!
Reach, I definitely like the upgrade! 100% better.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
03-28-2008, 12:35 PM | #6 |
gone baby gone
381
Rep 1,052
It is wired to the dimmer, that provides night illumination. It is a soft glow throughout all of the knob and is tied to central illumination control.
Zone illumination was its own unique challenge. We lack any kind of stock circuity to run it, so I had to make some. The mini pot will have to suffice as the best way to change the brightness of zone illumination. It is the kind of thing that you pick where you want it and leave it alone anyway, so I don't anticipate the need to make it an external knob or anything, I'll just leave the mini pot under the shift boot, and if I ever want to tweak it I can just go there. |
03-28-2008, 06:15 PM | #8 |
Rep 490
I like it, but who is going to be first to call him a poser for having an M part on a non M car?
On a related subject, today I saw as 318 ///M and a 325 Alpina. Both cars were total rust buckets and one was on temp registration. Gotta love nitwits and E-bay.
03-28-2008, 07:02 PM | #10 |
Rep 5,069
Not me, only cuz he is not trying to pass it off an Mcoupe or M3 like some poeple. I say +1 for a cool Mod! Also, on the related topic, my first car after I gratuated from college in 98 was a brand new 318ti. It was covered in ///M emblems (side molding, shift knob, rear spoiler) and it had the ///M front bumper, side sills, and diffuser, the sport packages came that way. FYI
03-29-2008, 01:18 AM | #11 |
Rep 615
thank you reach
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers -*MY PICTURE THREAD*- |
