FORUMS
- 5
| Please visit one of the specific Bimmerpost sites above |
| 12-09-2008, 06:08 PM | #2 |
| 12-09-2008, 06:10 PM | #3 |
![]() Drives: '07 Z4 M Coupe Join Date: May 2006
| 12-09-2008, 06:11 PM | #4 | |
Meat Puppet
Drives: 07 Jet Black 335i e92 Join Date: Dec 2008
| 12-09-2008, 06:16 PM | #6 | |
Cpt. Buzzkill
CS2 -Auto Level (shift+ctrl+L) -Auto Contrast (alt+shift+ctrl+L) -Auto Color (shift+ctrl+B) -Level (ctrl+L): Drag the middle slider slightly to the right, and adjust the left and right slider until you think it makes the image pop out enough. Don't overdo it. -Hue/Saturation (ctrl+U): I just decrease the saturation slightly. It's not necessary, but I do it on some pics. -Filter>Sharpen>Unsharp Mask: This is hard for me to explain how to use, but it helps the image pop out more. -Filter>Noise>Reduce Noise: This is a MUST HAVE tool when it comes to crappy images. When you have a picture with lots of noise, try using this. The pic you posted could go without this tool. -Gradient tool (G): Set to radial mode. Use a gradient that goes from white to black. Set the mode to multiply. It provides the darkened borders.
_.[In a love/hate relationship with...] E92 335i: Space Grey|Coral Red|Aluminum Trim
![]() _________VMR V710s|M-Sport Rear Bumper & Rockers|M3 Spoiler|Golf-T__________Moved on to the misc. Later, brahs. |
| 12-09-2008, 06:18 PM | #8 |
Thanks alot guys, but how can this guy do this? does he photoshop this pic?
http://farm4.static.flickr.com/3098/...8d7dd08c_b.jpg |
| 12-09-2008, 06:20 PM | #9 | |
Meat Puppet
| 12-09-2008, 06:24 PM | #11 |
| 12-09-2008, 06:24 PM | #12 | |
Cpt. Buzzkill
Search HDR on google.
| 12-09-2008, 07:51 PM | #15 |
Bad MOFO
you can take multiple shots using a tripod and then create a single HDR image OR..
You can make a pseudo HDR image. Take an image, make 2 over exposed copies of it and two under exposed copies of it. You can then use the merge to HDR command in photoshop and create something similar to a real HDR shot. Im not sure if you can tone map a pseudo HDR image to make it look like the pictures posted above. Maybe someone more knowledgeable can chime in here. I can show u an example.... BEFORE... AFTER... ![]() BEFORE... ![]() ![]() AFTER... ![]() ![]()
[img]http://************/acj2ur[/img]
| 12-09-2008, 07:51 PM | #16 |
| 12-09-2008, 08:09 PM | #18 |
Cpt. Buzzkill
| 12-09-2008, 08:56 PM | #20 |
HDR is done,by combining a number of shots of the same object under different exposures. So you would take lets say 5 shots of you car, under different exposures.
Open Photoshop depending what you use, go under File --> Automate--> Merge to HDR and follow instructions. Hope that helps.
![]() Retired: |2008 328i Sedan|Montego Blue|AT|Nav/Idrive|PDC|Xenon Headlights| Black Leatherette Seats, Silver trim| COTM April 2010 Mods:PIAA, H&R Sport, Blacklines, BBS LM-R, Eisenman Race Quad Exhaust , Koni yellows, Full Mtech, Gloss Black Vinyl Roof |
| 12-09-2008, 09:11 PM | #21 | |
Bad MOFO
| Bookmarks |
| Thread Tools | Search this Thread |
