| Please visit one of the specific Bimmerpost sites above |
| 01-28-2009, 09:03 PM | #1 |
Tyre Pressures
Right guys/gals,
Silly question... but heard some random advice from a garage just a few days ago. I'm currently running: Front: R19/35/235 - Pirelli P-Zero Nero Rear: R19/30/265 - Pirellia P-Nero Zero Now I've always assumed the correct typre pressure was 32 PSi. But the other day some random garage was telling me I should be running them at 38 PSi. That sounds awfully high........ any comment? |
| 01-28-2009, 10:14 PM | #2 |
![]() Drives: E90 330i Monaco Blue/Beige Join Date: Nov 2007
I am not so sure about 19", but I am running my 18" at 40 PSI (280 kPa).
E90 330i VB36 Monaco Blue/Beige/BurledWalnut - Prodrive GC-014I Forged 18" 8.5J/9.5J British Black + Potenza RE-11 225/255 + SACHS Performance + H&R ARBs + ACS bodykit + Brembo Gran Turismo Brake Kit 355-6F/345-4R + Rogue Engineering IKON exhaust kit + Simota Intake V2 + MFD Scoops + Blackline w/ red bulbs + PIAA H11 4700K fog + PIAA 6500K White Angel Eyes + PIAA H-492 license plate LED + GS-55 front doors LED + Valentine-1
| 01-29-2009, 06:26 AM | #3 |
In The Flesh
I have 19" 235/30 front and 255/30 Rear. Tyre pressure varies depending on temp/season... I run mine at 35PSI front, 33PSI Rear
In general tires lose 1-2 PSI per month in hot weather, you might want to add a +1PSI to your current setup than. |
| 02-08-2009, 11:34 AM | #4 |
think manufacturer usually quote cold psi numbers, if you want to be clinical abut this, get a pressure gauge and a pump. you might want to consider nitrogen as well.
| 02-11-2009, 03:17 AM | #6 |
yes, 40!?
isn't it too high? u didn't feel slippy ma??? |
| 02-11-2009, 09:25 AM | #8 |
yes wor, I usually maintain them at around 40psi...
| 02-11-2009, 10:52 AM | #9 |
2.7 bar is 39psi....
![]() i guess it's a recommendation for very smooth roads and highway? i dun think it's acceptable for rough roads like hk! |
| 02-11-2009, 10:46 PM | #11 |
i will be a consideration of balancing off ride comfort and gas consumption
| 02-12-2009, 12:29 AM | #12 |
umm, after how bmw brag about their 50-50 weight ratio, they recommend different tyre pressures front and rear (also for 225/45 size)??
| 02-16-2009, 11:46 AM | #13 |
I run 33 and 35 psi on my 19" 235/35 and 275/30 Mich PS2s (measured cold). But then I prefer a slightly heavier steering. The nose gets considerably lighter as you go from 32 to 34-35.
I used to run 32 all around to make the ride more comfy for the HK Island roads. But I went for the better handling after a while, comfort be damned ![]() |
| 03-20-2009, 01:57 AM | #15 |
Okies,
After bouncing round a few garages and asking numerous mechanics... it turns out the general consensus is the settings I'm running: 36 PSi (Front) & 38 PSi (Rear). You can tweak it +/- 2 PSi either way depending on your preference for handling. |
| Bookmarks |
| Thread Tools | |
