BMW M3 Forum (E90 E92)
Mporium BMW
      01-31-2009, 08:45 AM   #1
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Be careful with self tapping screws
I installed the OEM aluminum pedals in my car yesterday. The installation was was very easy if you know how drill holes on steel (brake pedal / clutch pedal too). We took a short cut and used self tapping screws for the gas pedal. Immediately after installation, the gas pedal didn't feel right. It has a lot more resistance when I try to step on it. Turns out the self tapping screw in the bottom right corner, closest to the center console, is hitting the pedal mechanism. I removed that screw and now it works fine. I guess I have to replace the screws with the OEM screws and nuts next time I go into the shop.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      02-13-2009, 04:30 PM   #2
FOXYCaymanS
_
FOXYCaymanS's Avatar
Drives: Cayman S / Rover
You're lucky you were able to get the screw out and that it didn't cause an accident. Was the screw sticking out that much behind the pedal? Can you not use a smaller one or was this a short one that was just TOO close?
      02-14-2009, 02:22 AM   #3
Cab5er
Cab5er's Avatar
China
80
Drives: 09 E90 M3 (Sold) 13 A1
Stupid question but does anyone know what kind of screws you need for aftermarket pedals? I've got unltimate pedals coming but they didn't come with mounting hardware. What kind of screws and nuts are the oem ones?
E90 ///M3/ AW/ Fox Red
      02-14-2009, 12:33 PM   #4
endofanera7
endofanera7's Avatar
514
Drives: 08 JB E92 M3
OEM pedals do have any screw... They are wrapped with plastic pieces.
      01-28-2016, 09:14 PM   #5
Scottyvh
Scottyvh's Avatar
Australia
9
Drives: 2011 E90 M3 Pure
. We took a short cut and used self tapping screws for the gas pedal. Immediately after installation, the gas pedal didn't feel right. It has a lot more resistance when I try to step on it. Turns out the self tapping screw in the bottom right corner.
This happened to me this morning first drive after installing mine last night. I was driving to work and had to stop and I thought maybe I had left something behind the pedals while drilling.
Hoping I can get the self tapping screw out and then cut a bit off or grind a bit off the end. Problem is the hole is going to be a bit off a mess and be slightly more loose.
      01-29-2016, 03:38 PM   #6
JDM_CL9
JDM_CL9's Avatar
92
Drives: ///M3
2009 BMW E93 M3  [0.00]
Just use the proper hardware from the get go. It's a car, not a piece of drywall?
Your local hardware store should sell the proper drill bits to drill through steel.
2009 BMW E93 6MT///M3 - SG/FR
2011 BMW E90 DCT///M3 - JB/FR (Sold)
      01-31-2016, 01:48 PM   #7
Richbot
Drives: Jerez Black E90
You need a couple screws loose to do this in the first place. Wtf.
      01-31-2016, 05:10 PM   #8
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
Heh. I see what you did there.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
m3post
